我有一个关于OTA升级的问题。
我实现了一个OTA升级参考文件的97060列出在下面的URL。 我使用了文档中所描述的示例源代码。 HTTP://www. CyPress .COM/DCONtiSON/Appult- NoSe/AN97060-PSOC-4-BLE和PRO-BU-O-OTE空固件升级 我使用的是“CY8C4248LQI-BL43”装置。 我实现了“5.4添加一个可升级的堆栈OTA Bootloader”在文档中描述。 在这个配置中,固件由三部分组成。 1、应用 2.堆栈应用 3发射装置 我将修改“应用程序”的源代码,并创建内置的固件。 我可以通过OTA升级来升级固件而不会出现问题。 然而,当我升级通过修改“BLE Stand应用程序”源代码创建的固件时,我遇到了一些问题。 虽然OTA升级本身将成功,但它在第一次应用程序启动时的SRAM初始化过程中停止。 请告诉我如何解决这个问题。 以上来自于百度翻译 以下为原文 I have a question about OTA upgrade. I implemented an OTA upgrade with reference to the document of AN 97060 listed in the following URL. I used the source code of the sample as described in the document as well. http://www.cypress.com/documentation/application-notes/an97060-psoc-4-ble-and-proc-ble-over-air-ota-device-firmware-upgrade I am using the device of "CY8C4248LQI-BL483". I implemented "5.4 Adding an Upgradable Stack OTA Bootloader" described in the document. In this configuration, the firmware consists of three parts. 1.Application 2.BLE Stack Application 3.Launcher I will modify the source code of the "Application" and create the built firmware. And I can upgrade that firmware by OTA upgrade without problems. However, when I upgrade the firmware created by modifying the source code of "BLE Stack Application", I have problems. Although the OTA upgrade itself will succeed, it stops within the SRAM initialization process that is done the first time Application is launched. Please tell me how to solve this problem. |
6个回答
你好,
请分享你的工作了解栈项目的修改和重新发布。 当做, 吉昂 以上来自于百度翻译 以下为原文 Hi, Please share your workspace to understand the modifications in stack project and recreate the issue. Regards, Geon |
嗨,Geon 我附上我使用的开发环境。 改变GPIO口的LED,SW,uart TX根据环境使用。 当做, 塔卡 奥塔试验 14.5兆字节 以上来自于百度翻译 以下为原文 Hi, Geon I attached the development environment I am using. Change the GPIO port of LED, SW, UART tx according to the environment being used. Regards, Taka
你好,
是否尝试使用单独的文件模式升级堆栈和应用程序? 当做。 以上来自于百度翻译 以下为原文 Hi, Did you try to upgrade both stack and application by using the separate files mode? Regards. |
你好, 我尝试通过组合文件模式来升级堆栈和应用程序。 正如您所建议的,使用单独的文件模式进行升级是成功的。 如果我修改了OTA堆栈,我必须使用单独的文件模式吗? 当做。 以上来自于百度翻译 以下为原文 Hi, I tried to upgrade both stack and application by using the combined files mode. And as you advised, upgrading using the separate files mode succeeded. If I modified the OTA stack, do I have to use the separate files mode? Regards. |
我发现组合文件模式不太好。 所以答案是肯定的,你必须使用单独的文件模式。 只是提醒一下,当升级IDE版本,即IE 4.1到4.2时,需要使用单独的文件模式升级堆栈和应用程序。 当做。 以上来自于百度翻译 以下为原文 I find combined files mode is not working well. So the answer is yes, you have to use separate files mode. Just a reminder, when you upgrade IDE version, ie 4.1 to 4.2, you need to upgrade both stack and application using separate files mode. Regards. |
dd66666 发表于 2018-8-17 07:26 多亏了你的建议,我才了解到升级的原因。非常感谢。 当做。 以上来自于百度翻译 以下为原文 Thanks to your advice I understood about the upgrade. Thank you very much. Regards. |
只有小组成员才能发言,加入小组>>
719个成员聚集在这个小组
加入小组1913 浏览 1 评论
1667 浏览 1 评论
3419 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1584 浏览 6 评论
1389 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
210浏览 2评论
195浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
343浏览 2评论
369浏览 1评论
76浏览 1评论
GMT+8, 2024-5-16 00:15 , Processed in 1.424520 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
