求大家帮忙看看 实在找不出错了,代码是教程实验中的代码,如下
#include #include #include "inc/hw_memmap.h" #include "inc/hw_types.h" #include "inc/hw_ints.h" #include "driverlib/gpio.h" //#define PART_TM4C123GH6PM #include "driverlib/pin_map.h" #include "driverlib/sysctl.h" #include "driverlib/uart.h" #include "driverlib/interrupt.h" #ifdef DEBUG void __error__(char *pcFilename, uint32_t ui32Line) [ ] #endif //***************************************************************************** // // Send a string to the UART. // //***************************************************************************** void UARTSend(const uint8_t *pui8Buffer, uint32_t ui32Count) [ // // Loop while there are more characters to send. // while(ui32Count--) [ // // Write the next character to the UART. // UARTCharPutNonBlocking(UART0_BASE, *pui8Buffer++); ] ] int main(void) [ SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ);//50MHz SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);//启用UART0 SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);//启用GPIOA GPIOPinConfigure(GPIO_PA0_U0RX);//GPIO管脚复用配置 GPIOPinConfigure(GPIO_PA1_U0TX); GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);//管脚UART功能配置PA0 PA1 SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);//启用GPIOF GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_2); UARTConfigSetExpClk(UART0_BASE, SysCtlClockGet(), 115200, (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE | UART_CONFIG_PAR_NONE)); //UART时钟为系统时钟,波特率为115200,数据类型为数据位为8,停止位1,无奇偶校验位 IntMasterEnable(); //enable processor interrupts IntEnable(INT_UART0); //enable the UART interrupt UARtintEnable(UART0_BASE, UART_INT_RX | UART_INT_RT); //only enable RX and TX interrupts UARTSend((uint8_t *)"Enter text: ", 10); while (1) [ if (UARTCharsAvail(UART0_BASE)) UARTCharPut(UART0_BASE, UARTCharGet(UART0_BASE)); ] ] void UARTIntHandler(void) [ uint32_t ui32Status; ui32Status = UARTIntStatus(UART0_BASE, true); //get interrupt status UARTIntClear(UART0_BASE, ui32Status); //clear the asserted interrupts while(UARTCharsAvail(UART0_BASE)) //loop while there are chars [ UARTCharPutNonBlocking(UART0_BASE, UARTCharGetNonBlocking(UART0_BASE)); //echo character GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, GPIO_PIN_2); //blink LED SysCtlDelay(SysCtlClockGet() / (1000 * 3)); //delay ~1 msec GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, 0); //turn off LED ] ] |
5 个讨论
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1912 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3669 浏览 4 评论
5042 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1741 浏览 1 评论
9426 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
690浏览 2评论
738浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
709浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1211浏览 1评论
1794浏览 1评论
GMT+8, 2024-5-14 22:29 , Processed in 0.828624 second(s), Total 76, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
