电子发烧友论坛|
请问c6748必须要接ddr吗,我直接做了一款板子,没有接ddr,jtag testing通过,但是挂载gel文件时出现:
C674X_0: Output: Target Connected. C674X_0: Output: --------------------------------------------- C674X_0: Output: Memory Map Cleared. C674X_0: Output: --------------------------------------------- C674X_0: Output: Memory Map Setup Complete. C674X_0: Output: --------------------------------------------- C674X_0: Output: PSC Enable Complete. C674X_0: Output: --------------------------------------------- C674X_0: Output: PLL0 init done for Core:456MHz, EMIFA:114MHz C674X_0: Output: DDR initialization is in progress.... C674X_0: Trouble Reading Memory Block at 0x1c14188 on Page 0 of Length 0x4: (Error -1060 @ 0x1C14188) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C674X_0: GEL: Error while executing OnTargetConnect(): Target failed to read 0x01C14188 at (*((unsigned int *) (0x01C14000+0x188))&=~(0x00000020)) [Tronlong_C6748.gel:237] at device_PLL1(12, 0, 0, 1, 2) [Tronlong_C6748.gel:431] at Set_DDRPLL_156MHz() [Tronlong_C6748.gel:437] at Set_DDR2_156MHz() [Tronlong_C6748.gel:444] at Core_456MHz_DDR2_156MHz() [Tronlong_C6748.gel:261] at CPU_PLL_PSC_DDR_Init() [Tronlong_C6748.gel:251] at OnTargetConnect() . C674X_0: Trouble Reading Register CSR: (Error -1060 @ 0x41) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C674X_0: Trouble Reading Register CSR: (Error -1060 @ 0x41) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) 好像是配置到ddr的时钟时出错了,请问是需要修改gel文件吗?还是必须要接一块ddr? |
1 个讨论
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 08:23 , Processed in 0.645852 second(s), Total 62, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2082
