电子发烧友论坛扫一扫,分享给好友
网页控制cc3200
板子在AP模式下进入网页,将其修改成sta模式,sta连上 ssid为4499的wifi上 (重启之后生效这个过程应该怎么制作出来?) 将其设置为sta 设置连接到4499的wifi上 重启之后怎么让他自动连接到4499的wifi上呢? |
3个回答
论坛有类似问题,请参考这边: https://www.deyisupport.com/question_answer/wireless_connectivity/wifi/f/105/t/81794.aspx
bctwerwer 发表于 2018-6-23 05:36 我在网页上修改AP的名称和密码 我想重启后 AP设置为我网页上修改的那个 我应该怎么做呢? 重启后好像只有AP名称是上一次ap的 密码直接为open 我想重启后直接为上次ap的配置 包括密码 |
zsl1220548 发表于 2018-6-23 05:50 CC3200在连接到AP后保存Profile,在CC3200再次启动后,注意不要将所有的Profile删除,否则就无法连接到你之前记录的路由器AP上了,在程序中查找 //***************************************************************************** //! brief This function puts the device in its default state. It: //! - Set the mode to STATION //! - Configures connection policy to Auto and AutoSmartConfig //! - Deletes all the stored profiles -----------------------------------------------------------这个地方不要打开,否则会删除所有的Profile //! - Enables DHCP //! - Disables Scan policy //! - Sets Tx power to maximum //! - Sets power policy to normal //! - Unregister mDNS services //! - Remove all filters //! //! param none //! return On success, zero is returned. On error, negative is returned //***************************************************************************** static long ConfigureSimpleLinkToDefaultState() SlVersionFull ver = [0]; _WlanRxFilterOperationCommandBuff_t RxFilterIdMask = [0]; unsigned char ucVal = 1; unsigned char ucConfigOpt = 0; unsigned char ucConfigLen = 0; unsigned char ucPower = 0; long lRetVal = -1; long lMode = -1; lMode = sl_Start(0, 0, 0); ASSERT_ON_ERROR(lMode); // If the device is not in station-mode, try configuring it in station-mode if (ROLE_STA != lMode) [ if (ROLE_AP == lMode) [ // If the device is in AP mode, we need to wait for this event // before doing anything while(!IS_IP_ACQUIRED(g_ulStatus)) [ #ifndef SL_PLATFORM_MULTI_THREADED _SlNonOsMainLoopTask(); #endif ] ] // Switch to STA role and restart lRetVal = sl_WlanSetMode(ROLE_STA); ASSERT_ON_ERROR(lRetVal); lRetVal = sl_Stop(0xFF); ASSERT_ON_ERROR(lRetVal); lRetVal = sl_Start(0, 0, 0); ASSERT_ON_ERROR(lRetVal); // Check if the device is in station again if (ROLE_STA != lRetVal) [ // We don't want to proceed if the device is not coming up in STA-mode return DEVICE_NOT_IN_STATION_MODE; ] ] // Get the device's version-information ucConfigOpt = SL_DEVICE_GENERAL_VERSION; ucConfigLen = sizeof(ver); lRetVal = sl_DevGet(SL_DEVICE_GENERAL_CONFIGURATION, &ucConfigOpt, &ucConfigLen, (unsigned char *)(&ver)); ASSERT_ON_ERROR(lRetVal); UART_PRINT("Host Driver Version: %snr",SL_DRIVER_VERSION); UART_PRINT("Build Version %d.%d.%d.%d.31.%d.%d.%d.%d.%d.%d.%d.%dnr", ver.NwpVersion[0],ver.NwpVersion[1],ver.NwpVersion[2],ver.NwpVersion[3], ver.ChipFwAndPhyVersion.FwVersion[0],ver.ChipFwAndPhyVersion.FwVersion[1], ver.ChipFwAndPhyVersion.FwVersion[2],ver.ChipFwAndPhyVersion.FwVersion[3], ver.ChipFwAndPhyVersion.PhyVersion[0],ver.ChipFwAndPhyVersion.PhyVersion[1], ver.ChipFwAndPhyVersion.PhyVersion[2],ver.ChipFwAndPhyVersion.PhyVersion[3]); // Set connection policy to Auto + SmartConfig // (Device's default connection policy) lRetVal = sl_WlanPolicySet(SL_POLICY_CONNECTION, SL_CONNECTION_POLICY(1, 0, 0, 0, 1), NULL, 0); ASSERT_ON_ERROR(lRetVal); // Remove all profiles lRetVal = sl_WlanProfileDel(0xFF);------------------------------------------------------------------不要删除所有的Profile ASSERT_ON_ERROR(lRetVal); // // Device in station-mode. Disconnect previous connection if any // The function returns 0 if 'Disconnected done', negative number if already // disconnected Wait for 'disconnection' event if 0 is returned, Ignore // other return-codes // lRetVal = sl_WlanDisconnect(); //会把标志位置位,中断是在后面发生的!在后面清除标志位 if(0 == lRetVal) [ // Wait while(IS_CONNECTED(g_ulStatus)) [ #ifndef SL_PLATFORM_MULTI_THREADED _SlNonOsMainLoopTask(); #endif ] ] // Enable DHCP client lRetVal = sl_NetCfgSet(SL_IPV4_STA_P2P_CL_DHCP_ENABLE,1,1,&ucVal); ASSERT_ON_ERROR(lRetVal); // Disable scan ucConfigOpt = SL_SCAN_POLICY(0); lRetVal = sl_WlanPolicySet(SL_POLICY_SCAN , ucConfigOpt, NULL, 0); ASSERT_ON_ERROR(lRetVal); // Set Tx power level for station mode // Number between 0-15, as dB offset from max power - 0 will set max power ucPower = 0; lRetVal = sl_WlanSet(SL_WLAN_CFG_GENERAL_PARAM_ID, WLAN_GENERAL_PARAM_OPT_STA_TX_POWER, 1, (unsigned char *)&ucPower); ASSERT_ON_ERROR(lRetVal); //add //lRetVal = sl_WlanPolicySet(SL_POLICY_CONNECTION , SL_CONNECTION_POLICY(1,1,0,0,0), 0, 0); // Set PM policy to normal lRetVal = sl_WlanPolicySet(SL_POLICY_PM , SL_NORMAL_POLICY, NULL, 0); ASSERT_ON_ERROR(lRetVal); // Unregister mDNS services lRetVal = sl_NetAppMDNSUnRegisterService(0, 0); ASSERT_ON_ERROR(lRetVal); // Remove all 64 filters (8*8) memset(RxFilterIdMask.FilterIdMask, 0xFF, 8); lRetVal = sl_WlanRxFilterSet(SL_REMOVE_RX_FILTER, (_u8 *)&RxFilterIdMask, sizeof(_WlanRxFilterOperationCommandBuff_t)); ASSERT_ON_ERROR(lRetVal); lRetVal = sl_Stop(SL_STOP_TIMEOUT); ASSERT_ON_ERROR(lRetVal); InitializeAppVariables(); return lRetVal; // Success ] |
只有小组成员才能发言,加入小组>>
601 浏览 0 评论
1654 浏览 0 评论
2096 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1542 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1386 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1794浏览 29评论
2821浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1667浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1681浏览 13评论
/9
GMT+8, 2025-12-15 03:44 , Processed in 0.814065 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3897
