电子发烧友论坛扫一扫,分享给好友
16个回答
您好, 你是想用VPFE还是SD输出来做这个bootlogo?
感谢回复~昨天晚上我已经基本实现了,就是配置一下内核选项,/kernel/device drivers/graphics support/logo configuration 。根据help说明,需要FB或者SGI_NEWPORT_CONSOLE的支持,我不知道SGI_NEWPORT_CONSOLE是什么,于是我配置了Frame buffer support。 重新编译烧写,果然可以看见开机logo,但是有一个问题,系统总是会卡住,不能继续运行,在没有配置logo之前,绝对没有这个现象,不知道我哪里少选了,还是哪里冲突了? 多谢指教~ |
60user34 发表于 2018-6-22 07:40 是停在kernel还是停在哪里?按你说的,也不是每次都卡住,还是说每次卡住的地方不一样? 可能需要你提供一下当时的log 顺便想问一下,因为你这个是kernel下的logo,从系统加电到出现logo大致需要多久? |
sunsiyi92 发表于 2018-6-22 07:55 恩,确实不是每次都停,但阻塞的时候居多,程序阻塞在了AVSERVER UI: Initializing 的上一行,也就说没有能进入到avserver ui initial里面。请看下面的log: 从上电到出现logo大约6-7s的样子。我本来是想在uboot里面实现logo,但由于之前没做过,加上看到kernel里面有logo可以配置,就图省事了。 U-Boot 2010.12-rc2-svn2 (Sep 28 2012 - 15:31:51) Cores: ARM 297 MHz DDR: 243 MHz I2C: ready DRAM: 128 MiB NAND: 256 MiB MMC: davinci: 0, davinci: 1 Bad block table found at page 131008, version 0x01 Bad block table found at page 130944, version 0x01 Net: Ethernet PHY: GENERIC @ 0x00 DaVinci-EMAC Hit any key to stop autoboot: 0 123 Loading from nand0, offset 0x400000 Image Name: Linux-2.6.18_pro500-davinci_IPNC Created: 2013-06-04 9:21:44 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1666660 Bytes = 1.6 MiB Load Address: 80008000 Entry Point: 80008000 ## Booting kernel from Legacy Image at 80700000 ... Image Name: Linux-2.6.18_pro500-davinci_IPNC Created: 2013-06-04 9:21:44 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1666660 Bytes = 1.6 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux............................................................. Linux version 2.6.18_pro500-davinci_IPNC_1.5 (touptek@touptek-laptop) (gcc vers3 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 Machine: DaVinci DM365 IPNC Memory policy: ECC disabled, Data cache writeback DaVinci DM0365 variant 0x8 PLL0: fixedrate: 24000000, commonrate: 121500000, vpssrate: 243000000 PLL0: vencrate_sd: 27000000, ddrrate: 243000000 mmcsdrate: 121500000 PLL1: armrate: 297000000, voicerate: 20482758, vencrate_hd: 74250000 CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets Built 1 zonelists. Total pages: 13824 Kernel command line: mem=54M console=ttyS0,115200n8 root=/dev/mtdblock3 rootfstf PID hash table entries: 256 (order: 8, 1024 bytes) Clock event device timer0_0 configured with caps set: 07 Console: colour dummy device 80x30 Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 54MB = 54MB total Memory: 51072KB available (2832K code, 585K data, 172K init) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 DaVinci: 104 gpio irqs MUX: initialized GPIO20 MUX: initialized I2C_SCL MUX: initialized GIO50 MUX: initialized GIO51 MUX: initialized VOUT_B0 MUX: initialized VOUT_B1 MUX: initialized VOUT_B2 MUX: initialized VOUT_G0 MUX: initialized VOUT_G1 MUX: initialized VOUT_R0 MUX: initialized VOUT_R1 MUX: initialized VOUT_R2 ch0 default output "LCD", mode "1280x720" parallel rgb mode! parallel rgb mode! parallel rgb mode! MUX: initialized VOUT_COUTL_EN VPBE Encoder Initialized NET: Registered protocol family 2 IP route cache hash table entries: 512 (order: -1, 2048 bytes) TCP established hash table entries: 2048 (order: 1, 8192 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 2048 bind 1024) TCP reno registered VFS: Disk quotas dquot_6.5.1 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) squashfs: version 3.1 (2006/08/19) Phillip Lougher JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc. yaffs Jun 4 2013 17:04:50 Installing. SGI XFS with no debug enabled io scheduler noop registered io scheduler anticipatory registered (default) LTT : ltt-facilities init LTT : ltt-facility-core init in kernel Console: switching to colour frame buffer device 160x45 davincifb davincifb.0: dm_osd0_fb: 1280x720x16@0,0 with framebuffer size 1800KB davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 2700KB davincifb davincifb.0: dm_osd1_fb: 1280x720x4@0,0 with framebuffer size 1800KB davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 2700KB DAVINCI-WDT: DaVinci Watchdog Timer: heartbeat 60 sec Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled serial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfbc20000 (irq = 40) is a 16550A serial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550A RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize Linux video capture interface: v2.00 Trying to register davinci display video device. layer=c04f7800,layer->video_dev=c04f7960 Trying to register davinci display video device. layer=c04f7600,layer->video_dev=c04f7760 davinci_init:DaVinci V4L2 Display Driver V1.0 loaded i2c /dev entries driver nand_davinci nand_davinci.0: Using 4-bit hardware ECC NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron NAND 256MiB 3,3V 8-bi) Creating 5 MTD partitions on "nand_davinci.0": 0x00000000-0x003c0000 : "bootloader" 0x003c0000-0x00400000 : "params" 0x00400000-0x00800000 : "kernel" 0x00800000-0x02800000 : "/" 0x02800000-0x10000000 : "data" nand_davinci nand_davinci.0: hardware revision: 2.3 DaVinci DM365 Keypad Driver MUX: initialized KEYPAD input: dm365_keypad as /class/input/input0 Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50. ASoC version 0.13.1 CQ0093 Voice Codec 0.1 asoc: cq93vc <-> davinci-vcif mapping ok ALSA device list: #0: On-chip voice codec (cq93vc) IPv4 over IPv4 tunneling driver NET: Registered protocol family 1 NET: Registered protocol family 17 ieee80211: 802.11 data/management/control stack, git-1.1.13 ieee80211: Copyright (C) 2004-2005 Intel Corporation Time: timer0_1 clocksource has been installed. Clock event device timer0_0 configured with caps set: 08 Switched to high resolution mode on CPU 0 VFS: Mounted root (cramfs filesystem) readonly. Freeing init memory: 172K INIT: version 2.86 booting 0 mkdir: Cannot create directory `/dev/.test': Read-only file system Starting the hotplug events dispatcher: udevd. Synthesizing the initial hotplug events...done. Waiting for /dev to be fully populated...done. 0 insmod: /opt/ipnc/modules/g_media.ko: No such file or directory CSL: Module install successful, device major num = 254 CSL: Module version 0.10.00, built on Jun 4 2013 17:07:07 I2C: Module install successful, device major num = 253 DMA: Module install successful, device major num = 252 DRV: Module install successful DRV: Module built on Jun 4 2013 17:07:09 DRV: EDMACC.QUEPRI = 00000777 DRV: SYSTEM.MSTPRI0 = 00550011 DRV: SYSTEM.MSTPRI1 = 00000444 DRV: ISP.BCR = 00000002 CMEMK module: built on Jun 4 2013 at 17:06:49 Reference Linux version 2.6.18 File /data/work/ipnc_dm365/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdc allocated heap buffer 0xc4000000 of size 0x4800000 CMEM Range Overlaps Kernel Physical - allowing overlap CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83600000) cmemk initialized EDMAK module: built on Jun 4 2013 at 17:06:51 Reference Linux version 2.6.18 File /data/work/ipnc_dm365/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdc IRQK module: built on Jun 4 2013 at 17:06:51 Reference Linux version 2.6.18 File /data/work/ipnc_dm365/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdc irqk initialized Starting mounting local filesystems: mount none on /dev/shm type tmpfs (rw,size) none on /var/run type tmpfs (rw) none on /tmp type tmpfs (rw,sync) io scheduler cfq registeredCreat queue id:0 queue id:0 Creat queue id:32769 queue id:32769 queue id:32769 Creat queue id:65538 queue id:65538 IPNC_1.5 (touptek@touptek-laptop) (gcc version 4.2.0 (MontaVist queue id:65538 DEMOCFG Value: 0 nVideocodecmode = 0 nVideocodecres = 0 ./av_server.out AEWB APPRO2A 720P H264 4000000 CVBR MJPEG 97 MENUOFF & Check_device_version : DEVICE VER = 1 !! insmod: /opt/ipnc/modules/exportfs.ko: No such file or directory davinci-mmc davinci-mmc.0: Supporting 4-bit mode davinci-mmc davinci-mmc.0: Using DMA mode ApproDrvInit: 7 Creat queue id:98307 queue id:98307 |
sunsiyi92 发表于 2018-6-22 07:55 请问如何在uboot里面实现呢?如果可以在uboot里面实现是最好的了~ |
uboot里面是可以做的,不过需要你自己去配置寄存器了。可以参考开发板自带的VPFE工程去做这个 |
o,好的,多谢,我去看看。 |
哦 ,关于内核配置这个阻塞问题,不知道您有什么看法么? |
我猜是内核已经做了一些显示部分的初始化,后面跑应用的时候又做了一遍,之间可能就有配置打架了 具体要看到底停在哪里了,因为你log中打印出来的东西停在哪里,代码里未必是在那个地方的 |
sunsiyi92 发表于 2018-6-22 08:56 哦,好的,虽然我还不知道怎么解决他,不过非常感谢您的耐心回答~~等我弄好了贴出来办法,希望可以帮助其他人。 |
Excuse me, 我找不到你说的VPFE工程,可否告诉我在哪里可以下载到? |
sunsiyi92 发表于 2018-6-22 08:56 查资料说很有可能是在VPSS初始化部分冲突了,内核默认VPSS是未初始化的,但配置LOGO后,其实是已经初始化过了,应该是这里冲突了,请问您知道内核中VPSS初始化这个该怎么修改下么。。 |
60user34 发表于 2018-6-22 09:24 http://support.spectrumdigital.com/boards/evmdm368/revg/ |
您好。请问现在知道卡在哪里了吗。我也在启动内核时有时会卡住。我是在uboot加入logo... |
这个问题叫u-boot splash 给你一个参考的CCS工程,你可以把里面的代码加到u-boot里来实现开机界面 (多看看初始化VPBE的流程) 但是kernel起来之后,kernel里的framebuffer驱动起来之后会重新初始化VPBE, 这样会导致闪屏 比较好的做法是,u-boot里初始化VPBE,修改kernel里的framebuffer里的驱动,用ioremmap把u-boot里配置好的VPBE OSD/video窗口的地址映射到kernel空间来(注意地址冲突) |
你好,请问你是怎么在Uboot下面添加的LOGO呢?我也想添加,不知道如何下手,能指点下吗?谢谢~~~ |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 10:01 , Processed in 1.053032 second(s), Total 105, Slave 88 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1869
