扫一扫,分享给好友
大家好!
请问一下dm365支持视频的缩放的功能吗?现在要想用dm365 编一个720p的264的编码,然后以任意分辨率(小于720p的分辨率)输出到电视上,是不是要用到resizer的功能呀? IMP_MODE_SINGLE_SHOT、IMP_MODE_CONtiNUOUS 两种模式到底是是什么意思,有什么区别呀? 谢谢! |
4个回答
现在用dmai下的resize demo程序(dvsdk_2_10_01_18dmai_1_21_00_10packagestisdodmaiappsvideo_loopback_resize),运行时出现了以下信息 rsz_dev.users:0 davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:108 davinci_previewer davinci_previewer.2: ipipe_set_preview_config davinci_previewer davinci_previewer.2: ipipe_set_preview_config vpfe ccdc capture vpfe ccdc capture.1: IMP chained vpfe ccdc capture vpfe ccdc capture.1: Resizer present vpfe ccdc capture vpfe ccdc capture.1: hpitch = 720, vpitch = 576, bpp = 1 vpfe ccdc capture vpfe ccdc capture.1: hpitch = 720, vpitch = 576, bpp = 1 Starting ccdc_config_ycbcr...<7> starting ccdc_reset...<7> End of ccdc_reset...<7> Starting ccdc_setwin...<7>ipipe_set_resizer, resizer - A enabled DavinciDisplay DavinciDisplay.1: Before finishing with S_FMT: layer.pix_fmt.bytesperline = 736, layer.pix_fmt.width = 720, layer.pix_fmt.height = 576, layer.pix_fmt.sizeimage =635904 DavinciDisplay DavinciDisplay.1: pixfmt->width = 720, layer->layer_info.config.line_length= 736 rsz_dev.users:1 //这个是我在内核加的打印,由于这个值不等于 0 导致了下面错误信息的打印 davinci_resizer davinci_resizer.2: mode doesn't allow multiple instances //这个是内核中的打印 @10,493,095us: [+7 T:0x4001fd40] ti.sdo.dmai - [Resize] Failed to open /dev/davinci_resizer Failed to create resize job 请问哪里出现问题了?导致了Resize_create 创建失败?我在bootagrs已经配置成 CONTS模式,我也试配置成sigle shot mode,但是程序仍然运行不起来,只是提示的错误信息不一样("Operation mode doesn't match with current hw mode")。 bootargs=console=ttyS0,115200n8 noinitrd rw ip=192.168.2.42:255.255.255.0:192.168.2.1 root=/dev/nfs nfsroot=192.168.2.67:/home/qinjian/nfs/solo/fs,nolock mem=80M video=davincifb:vid0=OFF:vid1=OFF:osd0=720x576x16,4050K dm365_imp.oper_mode=0 davinci_capture.device_type=4 " |
kingnet_5220 发表于 2018-6-21 08:11 我也遇到了同样的问题,求帮忙分享一下? davinci_resizer davinci_resizer.2: Operation mode doesn't match with current hw mode vren init ok Failed to create resize job exit from video render thread begin i2c_adapter i2c-0: TVP7002 - clocks per line detected = 216 End of querystd function. vpfe ccdc capture vpfe ccdc capture.1: hpitch = 1280, vpitch = 720, bpp = 1 vpfe ccdc capture vpfe ccdc capture.1: hpitch = 1280, vpitch = 720, bpp = 1 Starting ccdc_config_ycbcr...<7> starting ccdc_reset...<7> End of ccdc_reset...<7> Starting ccdc_setwin...<7>ipipe_set_resizer, resizer - A enabled video encode buffer size = 1382400 venc init ok writer init ok |
大小姐丶阿怡 发表于 2018-6-21 08:27 这边人水平不行,还是去ti e2e官网问吧 |
只有小组成员才能发言,加入小组>>
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
497 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
957 浏览 1 评论
558 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
435 浏览 1 评论
979 浏览 0 评论
GMT+8, 2024-10-12 06:32 , Processed in 0.689392 second(s), Total 86, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
