电子发烧友论坛扫一扫,分享给好友
请问ti工程师:
在Cap+Dis的link 链中,Capture的输出格式pCaptureOutPrm->dataFormat只能是SYSTEM_DF_YUV422I_YUYV 么? 我需要输出的422SP的格式,DSP方便处理,然后Display出来。只有这一种格式可以 captures+display 正常 我修改为SYSTEM_DF_YUV422SP_UV系列,都是报错如下: 2763:!!!SLAVE CORE [VPSS-M3] DOWN!!! SystemLink_copySlaveCoreExceptionContext:146 mmap of [0xbe9e0000:36864] mmap virt addresss:0x400c7000 munmap of [0x400c7000:36864] SystemLink_copySlaveCoreExceptionContext:153 SystemLink_handleSlaveCoreException:173 SystemLink_handleSlaveCoreException:178 [m3vpss ] 15762: CAPTURE: VIP0 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!! [m3vpss ] 15763: Assertion @ Line: 779 in links_m3vpss/capture/captureLink_drv.c: pInst->captureVipHandle != NULL : failed !!! 附录部分代码: Void Chains_doubleChCapDis(Chains_Ctrl *chainsCfg) [ /*********************************************************************************/ for(i=0; i vipInstId = SYSTEM_CAPTURE_INST_VIP0_PORTA + 2*i; pCaptureInstPrm = &capturePrm.vipInst; pCaptureInstPrm->vipInstId = vipInstId%SYSTEM_CAPTURE_INST_MAX; pCaptureInstPrm->videoDecoderId = SYSTEM_DEVICE_VID_DEC_SII9233A_DRV; pCaptureInstPrm->inDataFormat = SYSTEM_DF_YUV422P; pCaptureInstPrm->standard = chainsCfg->displayRes; pCaptureInstPrm->numOutput = 1; pCaptureInstPrm->numChPerOutput = 1; pCaptureInstPrm->frameCaptureMode = FALSE; pCaptureInstPrm->fieldsMerged = FALSE; pCaptureOutPrm = &pCaptureInstPrm->outParams[0]; pCaptureOutPrm->dataFormat = SYSTEM_DF_YUV422I_YUYV; pCaptureOutPrm->scEnable = FALSE; pCaptureOutPrm->scOutWidth = chainsCfg->channelConf.width; pCaptureOutPrm->scOutHeight = chainsCfg->channelConf.height; pCaptureOutPrm->outQueId = i; ] capturePrm.outQueParams[0].nextLink = displayId[0]; System_linkCreate(captureId, &capturePrm, sizeof(capturePrm)); chainsCfg->displayRes[0] = capturePrm.vipInst[0].standard; for (i=0; i<1; i++) [ displayPrm.displayRes = chainsCfg->displayRes; displayPrm.numInputQueues = 1; displayPrm.activeQueue = 0; displayPrm.inQueParams[0].prevLinkId = captureId; displayPrm.inQueParams[0].prevLinkQueId = i; displayPrm.forceFieldSeparatedInputMode = FALSE; ] Chains_displayCtrlInit(chainsCfg->displayRes); System_linkCreate(displayId[0], &displayPrm[0], sizeof(displayPrm[0])); Chains_memPrintHeapStatus(); /*********************************************************************************/ ] |
5个回答
Ternence,非常感谢您对问题的关注, 1. Capture的输出格式pCaptureOutPrm->dataFormat是可以支持yuv420_sp和其他的格式,但前提是不需要display。因为我们做的视频存储就是capture输出yuv422SP的 格式存储的。 2.只要是有display的link,我看了例程,所有的capture都是输出SYSTEM_DF_YUV422I_YUYV格式,其余格式我基本都试过,不行。 YUV这样的交替存储,对于我后续的DSP人脸识别处理很麻烦,我还需要重新排序,如果单纯的存储不用display也是没有问题的。 3.我用的dvrrdk3.0版本。 再次感谢您的帮助!! |
Songki 发表于 2018-6-21 06:08 你好; 1、display link 是可以支持 除yuv422I_yuyv之外的其他格式的,需要修改一下display的 displayInstId 路径; (在rdk3.0 中需要到mcfw/src_bios6/links_m3vpss/display/displayLink_drv.c中修改,如果在rdk4.0 中已经把接口留到外面了,可以在Usecase中直接配置) default: case SYSTEM_LINK_ID_DISPLAY_0: pObj->displayInstId = VPS_DISP_INST_BP0; pFormat->scanFormat = FVID2_SF_PROGRESSIVE; break; case SYSTEM_LINK_ID_DISPLAY_1: pObj->displayInstId = VPS_DISP_INST_BP1; pFormat->scanFormat = FVID2_SF_PROGRESSIVE; break; case SYSTEM_LINK_ID_DISPLAY_2: pObj->displayInstId = VPS_DISP_INST_SEC1; pFormat->scanFormat = FVID2_SF_INTERLACED; break; 2、如果是因为display的问题,你可以通过link来做格式转换,输出yuv422I给display(sc5,或者swms link); |
Greatwayer 发表于 2018-6-21 06:22 在rdk3.0 mcfw/src_bios6/links_m3vpss/display/displayLink_drv.c中 找到了 default: case SYSTEM_LINK_ID_DISPLAY_0: pObj->displayInstId = VPS_DISP_INST_BP0; pFormat->scanFormat = FVID2_SF_PROGRESSIVE; break; case SYSTEM_LINK_ID_DISPLAY_1: pObj->displayInstId = VPS_DISP_INST_BP1; pFormat->scanFormat = FVID2_SF_PROGRESSIVE; break; case SYSTEM_LINK_ID_DISPLAY_2: pObj->displayInstId = VPS_DISP_INST_SEC1; pFormat->scanFormat = FVID2_SF_INTERLACED; break;如何修改呢?2.如果是想采集到的图像,让DSP来处理Y,UV部分,然后再display出来,您有什么样的建议? 我目前是想在OSD的例程上去改,准备加一个Display link,然后之前加上swms link来转化为yuv422I格式,您觉得如何?caps link -- nsf link-- vpssout -- swms link---vpssin link -- display link | processlink-- DspIn link -- osd link |
Greatwayer 发表于 2018-6-21 06:22 非常感谢,我已经解决了格式的问题,您的建议很管用,谢谢~ |
只有小组成员才能发言,加入小组>>
550 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1514 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1338 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1759浏览 29评论
2786浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1726浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1636浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1647浏览 13评论
/9
GMT+8, 2025-12-2 21:20 , Processed in 0.887081 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4287
