电子发烧友论坛扫一扫,分享给好友
您好:
在用SPI DMA SLAVE 方式与设备传输时,大概率出现数据传输错误,感觉像是CLK不匹配导致。现在MASTER SPI CLK是12M,SLAVE方式时CLK 应该与MASTER同步。cc3200对时钟有什么要求么?需要连续时钟吗?有没有特殊的同步机制。下面是spi的初始化代码,麻烦帮忙看看有什么问题,谢谢。 MAP_SPIConfigSetExpClk(GSPI_BASE,MAP_PRCMPeripheralClockGet(PRCM_GSPI), SPI_IF_BIT_RATE,mode,SPI_SUB_MODE_3, (chip_select | SPI_4PIN_MODE | SPI_TURBO_OFF | SPI_CS_ACtiVELOW | SPI_WL_8)); MAP_SPIIntRegister(GSPI_BASE,interrupt_handler); MAP_SPIFIFOLevelSet(GSPI_BASE, 1, 1); MAP_SPIFIFOEnable(GSPI_BASE, SPI_RX_FIFO); MAP_SPIFIFOEnable(GSPI_BASE, SPI_TX_FIFO); MAP_SPIDmaEnable(GSPI_BASE,SPI_RX_DMA); MAP_SPIDmaEnable(GSPI_BASE,SPI_TX_DMA); MAP_SPIWordCountSet(GSPI_BASE, SPI_DMA_MAX_LENGTH); MAP_SPIIntEnable(GSPI_BASE, SPI_INT_EOW); MAP_SPIEnable(GSPI_BASE); SPI_DMA_MAX_LENGTH 为1024; Transfer的设置: MAP_SPIDisable(GSPI_BASE); UDMASetupTransfer(UDMA_CH30_GSPI_RX, UDMA_MODE_BASIC, dma_size, UDMA_SIZE_8, UDMA_ARB_1, (void *) (GSPI_BASE + MCSPI_O_RX0), UDMA_SRC_INC_NONE, rx, UDMA_DST_INC_8); UDMASetupTransfer(UDMA_CH31_GSPI_TX, UDMA_MODE_BASIC, dma_size, UDMA_SIZE_8, UDMA_ARB_1, tx, UDMA_SRC_INC_8, (void *) (GSPI_BASE + MCSPI_O_TX0), UDMA_DST_INC_NONE); MAP_SPIEnable(GSPI_BASE); |
4个回答
作为主机模式应该没有大问题吧?是全错误呢,还是偶尔错误。你降低一下CLK试试有没有改观。
其中TI给的有那个例程,看看有没有类似的例子,我知道有个主机模式的例子。没试过从机,最近重装没安装那个软件。 |
可以参考一个SPI DMA的例子,
https://github.com/severin-kacianka/cc3200_dma_spi_example/ cc3200_dma_spi_example Here are two examples that show how to use SPI with DMA and FIFO on the CC3200. I hope that they are a useful starting point for anyone, who wants to work on SPI and DMA in the future. The examples are compiling fine on Linux with gcc 4.9.3 from http://launchpad.net/gcc-arm-embedded. All you need to change is the path for the SDK in the Makefile. The hardware setup is similar to the SPI example in the SDK: just connect two CC3200 via cable (Pins GND, P05, P06, P07 and P08). I have set the following jumpers: J6, J7, J8. J9. J10, J11, J12, J13. simple_spi_transfer is an example of an SPI transfer without DMA and FIFO. The master sends a buffer to the slave, reads it back in the next transfers and verifies the checksums. transfer_1024_byte implements a simple SPI/DMA transfer that will transfer 1024 (or whatever DMA_SIZE is set to) bytes from the master to the slave and back. It then calculates the buffer's CRC checksum and (on the master) compares the send checksum to the received checksum. transfer_64k shows how to transfer a 64k buffer from the master to the slave and back again. windows contains a Makefile send to me by Matt van de Werken that also works using the Launchpad tools in a Cygwin enviroment |
潘涛12345 发表于 2018-6-21 02:11 谢谢,dma可以跑通,最后查出来是飞线干扰的问题 |
asa1253 发表于 2018-6-21 02:27 谢谢,dma可以跑通,最后查出来是飞线干扰的问题 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 03:31 , Processed in 0.666233 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2518
