电子发烧友论坛扫一扫,分享给好友
各位工程师好,本人想把ndk和ipc工程合并,用的是helloworld_evmc6678l和shmIPCBenchmark_c6678l工程,合并步骤如下:
1.将shmIpcBenchmark工程的cfg配置文件拷贝到helloworld.cfg文件下; 2.改写helloworld.c文件,将ipc相关的头文件和函数加入其中; 3.编译可以通过,但是下载到core0.core1后有问题;显示: [C66xx_0] timerFreq.lo = 1000000000. timerFreq.hi = 0 [C66xx_0] cpuFreq.lo = 1000000000. cpuFreq.hi = 0 [C66xx_0] Core ("CORE0") starting [C66xx_1] Invalid CIO command (24) in the CIO buffer at address (0x80693380) was not recognized. Please check the device and program memory maps. [C66xx_1] cpuFreq.lo = 1000000000. cpuFreq.hi = 0 [C66xx_1] Core ("CORE1") starting 发现程序一直停留在语句attachAll(numCores),无法进入下一语句。请问是怎么回事?望哪位工程师解答一下,谢谢。 cfg文件: /* * helloWorld.cfg * * Memory Map and Program intiializations for the helloWorld example Utility * * Copyright (C) 2010-2011 Texas Instruments Incorporated - http://www.ti.com/ * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /* * @file helloWorld.cfg * * @brief * Memory Map and Program intiializations for the HPDSP Utility. * */ var System = xdc.useModule('xdc.runtime.System'); var BIOS = xdc.useModule('ti.sy***ios.BIOS'); /******************************************************************************************************************** * Specify all needed RTSC MOudles and ocnfigure them. * ********************************************************************************************************************/ var Memory = xdc.useModule('xdc.runtime.Memory'); var Task = xdc.useModule('ti.sy***ios.knl.Task'); var HeapBuf = xdc.useModule('ti.sy***ios.heaps.HeapBuf'); var Log = xdc.useModule('xdc.runtime.Log'); /* ** Allow storing of task names. By default if you name a task with a friendly display name it will not be saved ** to conserve RAM. This must be set to true to allow it. We use friendly names on the Task List display. */ //Defaults.common$.namedInstance = true; Task.common$.namedInstance = true; var Clock = xdc.useModule ('ti.sy***ios.knl.Clock'); /* ** Interface with IPC. Depending on the version of BIOS you are using the ** module name may have changed. */ /* Use this for pre BIOS 6.30 */ /* var Sem = xdc.useModule ('ti.sy***ios.ipc.Semaphore'); */ /* Use this for BIOS 6.30 plus to get the IPC module */ var Sem = xdc.useModule ('ti.sy***ios.knl.Semaphore'); var Hwi = xdc.useModule ('ti.sy***ios.hal.Hwi'); var Ecm = xdc.useModule ('ti.sy***ios.family.c64p.EventCombiner'); /* ** Configure this to turn on the CPU Load Module for BIOS. ** */ /* var Load = xdc.useModule('ti.sy***ios.utils.Load'); Load.common$.diags_USER4 = Diags.ALWAYS_ON; */ var Diags = xdc.useModule('xdc.runtime.Diags'); /* Load the CSL package */ var Csl = xdc.useModule('ti.csl.Settings'); /* Load the CPPI package */ var Cppi = xdc.loadPackage('ti.drv.cppi'); /* Load the QMSS package */ var Qmss = xdc.loadPackage('ti.drv.qmss'); /* Load the PA package */ var Pa = xdc.useModule('ti.drv.pa.Settings'); /* Load the Platform/NDK Transport packages */ var PlatformLib = xdc.loadPackage('ti.platform.evmc6678l'); var NdkTransport = xdc.loadPackage('ti.transport.ndk'); /* ** Sets up the exception log so you can read it with ROV in CCS */ var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf'); var Exc = xdc.useModule('ti.sy***ios.family.c64p.Exception'); Exc.common$.logger = LoggerBuf.create(); Exc.enablePrint = true; /* prints exception details to the CCS console */ /* ** Give the Load module it's own LoggerBuf to make sure the ** events are not overwritten. */ /* var loggerBufParams = new LoggerBuf.Params(); loggerBufParams.exitFlush = true; loggerBufParams.numEntries = 64; Load.common$.logger = LoggerBuf.create(loggerBufParams); */ /* ** Use this load to configure NDK 2.2 and above using RTSC. In previous versions of ** the NDK RTSC configuration was not supported and you should comment this out. */ var Global = xdc.useModule('ti.ndk.config.Global'); /* ** This allows the heart beat (poll function) to be created but does not generate the stack threads ** ** Look in the cdoc (help files) to see what CfgAddEntry items can be configured. We tell it NOT ** to create any stack threads (services) as we configure those ourselves in our Main Task ** thread hpdspuaStart. */ Global.enableCodeGeneration = false; /* Define a variable to set the MAR mode for MSMCSRAM as all cacheable */ var Cache = xdc.useModule('ti.sy***ios.family.c66.Cache'); //Cache.MAR224_255 = 0x0000000f; var Startup = xdc.useModule('xdc.runtime.Startup'); /* ** Create a Heap. */ var HeapMem = xdc.useModule('ti.sy***ios.heaps.HeapMem'); var heapMemParams = new HeapMem.Params(); heapMemParams.size = 0x600000; heapMemParams.sectionName = "systemHeap"; Program.global.heap0 = HeapMem.create(heapMemParams); /* This is the default memory heap. */ Memory.defaultHeapInstance = Program.global.heap0; //=======================================================由DDR3改成MSMCSRAM-----------开始 Program.sectMap["sharedL2"] = "DDR3"; Program.sectMap["systemHeap"] = "DDR3"; Program.sectMap[".sysmem"] = "DDR3"; Program.sectMap[".args"] = "DDR3"; Program.sectMap[".cio"] = "DDR3"; Program.sectMap[".far"] = "DDR3"; Program.sectMap[".rodata"] = "DDR3"; Program.sectMap[".neardata"] = "DDR3"; Program.sectMap[".cppi"] = "DDR3"; Program.sectMap[".init_array"] = "DDR3"; Program.sectMap[".qmss"] = "DDR3"; Program.sectMap[".cinit"] = "DDR3"; Program.sectMap[".bss"] = "DDR3"; Program.sectMap[".const"] = "DDR3"; Program.sectMap[".text"] = "DDR3"; Program.sectMap[".code"] = "DDR3"; Program.sectMap[".switch"] = "DDR3"; Program.sectMap[".data"] = "DDR3"; Program.sectMap[".fardata"] = "DDR3"; Program.sectMap[".args"] = "DDR3"; Program.sectMap[".cio"] = "DDR3"; Program.sectMap[".vecs"] = "DDR3"; Program.sectMap["platform_lib"] = "DDR3"; //=======================================================由DDR3改成MSMCSRAM-----------结束 Program.sectMap[".far:taskStackSection"] = "L2SRAM"; Program.sectMap[".stack"] = "L2SRAM"; Program.sectMap[".nimu_eth_ll2"] = "L2SRAM"; Program.sectMap[".resmgr_memregion"] = [loadSegment: "L2SRAM", loadAlign:128]; // QMSS descriptors region Program.sectMap[".resmgr_handles"] = [loadSegment: "L2SRAM", loadAlign:16]; // CPPI/QMSS/PA Handles Program.sectMap[".resmgr_pa"] = [loadSegment: "L2SRAM", loadAlign:8]; // PA Memory Program.sectMap[".far:IMAGEDATA"] = [loadSegment: "L2SRAM", loadAlign: 8]; Program.sectMap[".far:NDK_OBJMEM"] = [loadSegment: "L2SRAM", loadAlign: 8]; Program.sectMap[".far:NDK_PACKETMEM"] = [loadSegment: "L2SRAM", loadAlign: 128]; /* Required if using System_printf to output on the console */ SysStd = xdc.useModule('xdc.runtime.SysStd'); System.SupportProxy = SysStd; /******************************************************************************************************************** * Define hooks and static tasks that will always be running. * ********************************************************************************************************************/ /* ** Register an EVM Init handler with BIOS. This will initialize the hardware. BIOS calls before it starts. ** ** If yuo are debugging with CCS, then this function will execute as CCS loads it if the option in your ** Target Configuraiton file (.ccxml) has the option set to execute all code before Main. That is the ** default. */ Startup.lastFxns.$add('&EVM_init'); /* ** Create a Periodic task to handle all NDK polling functions. ** If you are using RTSC configuration with NDK 2.2 and above, this is done by default and ** you do not need to do this. */ /*var prdNdkClkParams = new Clock.Params (); prdNdkClkParams.period = 0x64; prdNdkClkParams.startFlag = true; Program.global.clockInst1 = Clock.create("&llTimerTick", 5, prdNdkClkParams); */ /* ** If you are using RTSC configuration with NDK 2.2 and above, this is done by default, else ** register hooks so that the stack can track all Task creation */ Task.common$.namedInstance = true; Task.addHookSet ([ registerFxn: '&NDK_hookInit', createFxn: '&NDK_hookCreate', ]); /* Enable BIOS Task Scheduler */ //BIOS.taskEnabled = true; /* * Enable Event Groups here and registering of ISR for specific GEM INTC is done * using EventCombiner_dispatchPlug() and Hwi_eventMap() APIs */ Ecm.eventGroupHwiNum[0] = 7; Ecm.eventGroupHwiNum[1] = 8; Ecm.eventGroupHwiNum[2] = 9; Ecm.eventGroupHwiNum[3] = 10; var Task = xdc.useModule('ti.sy***ios.knl.Task'); var tskParams = new Task.Params; tskParams.instance.name = "tsk0"; Program.global.task0 = Task.create('&tsk0', tskParams); /* Benchmark Task */ var Semaphore = xdc.useModule('ti.sy***ios.knl.Semaphore'); Semaphore.supportsEvents = false; //var Agent = xdc.useModule('ti.sy***ios.rta.Agent'); //Agent.transport = Agent.Transport_STOP_MODE_ONLY; //var Load = xdc.useModule('ti.sy***ios.utils.Load'); //Load.hwiEnabled = false; //Load.swiEnabled = false; //Load.taskEnabled = false; var System = xdc.useModule('xdc.runtime.System'); var Startup = xdc.useModule('xdc.runtime.Startup'); var SysStd = xdc.useModule('xdc.runtime.SysStd'); System.SupportProxy = SysStd; System.extendedFormats = "%f"; var BIOS = xdc.useModule('ti.sy***ios.BIOS'); BIOS.clockEnabled = true; BIOS.heapSize = 0x10000; var Timestamp = xdc.useModule("xdc.runtime.Timestamp"); Program.sectMap[".msgQ_ptrs"] = new Program.SectionSpec(); Program.sectMap[".msgQ_ptrs"] = "L2SRAM"; Program.sectMap["platform_lib"] = new Program.SectionSpec(); Program.sectMap["platform_lib"] = "L2SRAM"; var PlatformLib = xdc.loadPackage('ti.platform.evmc6678l'); /* ** Register an EVM Init handler with BIOS. This will initialize the hardware. BIOS calls before it starts. ** ** If debugging with CCS, then this function will execute as CCS loads it if the option in your ** Target Configuration file (.ccxml) has the option set to execute all code before Main. That is the ** default. */ Startup.firstFxns.$add('&initPlatform'); var cslSettings = xdc.useModule ('ti.csl.Settings'); var cacheEnabled = true; var cacheLineSize = 128; var procName = null; var procNameList = []; var Settings = xdc.module('ti.sdo.ipc.family.Settings'); var Cache = xdc.useModule('ti.sy***ios.family.c66.Cache'); var MessageQ = xdc.module('ti.sdo.ipc.MessageQ'); var Notify = xdc.module('ti.sdo.ipc.Notify'); var Ipc = xdc.useModule('ti.sdo.ipc.Ipc'); Notify.SetupProxy = xdc.module(Settings.getNotifySetupDelegate()); MessageQ.SetupTransportProxy= xdc.module(Settings.getMessageQSetupDelegate()); /* Use shared memory IPC */ Notify.SetupProxy = xdc.module('ti.sdo.ipc.family.c647x.NotifyCircSetup'); MessageQ.SetupTransportProxy = xdc.module('ti.sdo.ipc.transports.TransportShmNotifySetup'); /* Set to disable error printouts */ /* var Error = xdc.useModule('xdc.runtime.Error'); */ /* Error.raiseHook = null; */ Program.global.NOTIFYSETUP = Notify.SetupProxy.delegate$.$name; Program.global.TRANSPORTSETUP = MessageQ.SetupTransportProxy.delegate$.$name; switch (Program.platformName) [ case "ti.sdo.ipc.examples.platforms.evm6678.core0": case "ti.platforms.evm6678": Program.global.USING_C6678 = 1; procNameList = ["CORE0", "CORE1"]; Program.global.shmBase = 0x0C000000; Program.global.shmSize = 0x00100000; /* Sized for greater than 8000 128 byte messageQ messages */ break; case "ti.sdo.ipc.examples.platforms.evm6670.core0": case "ti.platforms.evm6670": Program.global.USING_C6670 = 1; procNameList = ["CORE0", "CORE1"]; Program.global.shmBase = 0x0C000000; Program.global.shmSize = 0x00100000; /* Sized for greater than 8000 128 byte messageQ messages */ break; default: throw("Unsupported platform: " + Program.platformName); ] var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc'); MultiProc.setConfig(procName, procNameList); Program.global.DEVICENAME = Program.cpu.deviceName; Program.global.PROCNAMES = procNameList.join(","); Program.global.BUILDPROFILE = Program.build.profile; var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion'); SharedRegion.translate = false; SharedRegion.setEntryMeta(0, [ base: Program.global.shmBase, len: Program.global.shmSize, ownerProcId: 0, isValid: true, cacheEnable: cacheEnabled, cacheLineSize: cacheLineSize, /* Aligns allocated messages to a cache line */ name: "internal_shared_mem", ]); /* Optimization stuff */ Diags = xdc.useModule("xdc.runtime.Diags"); var Defaults = xdc.useModule('xdc.runtime.Defaults'); //Defaults.common$.diags_ASSERT = Diags.ALWAYS_OFF; Defaults.common$.logger = null; var Semaphore = xdc.useModule('ti.sy***ios.knl.Semaphore'); Semaphore.supportsEvents = false; BIOS.libType = BIOS.LibType_Custom; main函数: int main() [ char coreID = CSL_chipReadReg (CSL_CHIP_DNUM); Int status ; Task_Params taskPara; Task_Params taskParams; #if 1 Int32 result = 0; Types_Timestamp64 time64; UInt64 timeStamp = 0; Timestamp_getFreq(&timerFreq); System_printf("timerFreq.lo = %d. timerFreq.hi = %dn", timerFreq.lo, timerFreq.hi); BIOS_getCpuFreq(&cpuFreq); System_printf("cpuFreq.lo = %d. cpuFreq.hi = %dn", cpuFreq.lo, cpuFreq.hi); cpuTimerFreqRatio = (Float)cpuFreq.lo / (Float)timerFreq.lo; Timestamp_get64(&time64); timeStamp = TIMESTAMP64_TO_UINT64(time64.hi,time64.lo); timeAdj = TIMESTAMP64_TO_UINT64(time64.hi,time64.lo) - timeStamp; selfId = CSL_chipReadReg (CSL_CHIP_DNUM); System_printf("Core ("%s") startingn", MultiProc_getName(selfId)); if (numCores == 0) [ numCores = MultiProc_getNumProcessors(); ] /* Attach all cores */ attachAll(numCores); prevCoreId = (selfId - 1 + numCores) % numCores; System_sprintf(localQueueName, "CORE%d", selfId); System_sprintf(nextQueueName, "CORE%d", ((selfId + 1) % numCores)); System_sprintf(prevQueueName, "CORE%d", prevCoreId); System_printf("localQueueName=%s. nextQueueName=%s. prevQueueName=%sn", localQueueName, nextQueueName, prevQueueName); /* Create a message queue. */ messageQ = MessageQ_create(localQueueName, NULL); if (messageQ == NULL) [ System_abort("MessageQ_create failedn" ); ] #endif #if 1 if(coreID == 0) [ Task_Params_init(&taskParams); taskParams.priority = 1; taskParams.stackSize = 4096; tsk1 = Task_create (StackTest, &taskParams, NULL); ] #endif /* Start the BIOS 6 Scheduler */ BIOS_start (); ] |
2个回答
单步调试时候,发现core0能够运行attachAll(numCores)直到bios_start;但是core1一直跳不出attachAll(numCores)中的如下循环:
if (MultiProc_self() != entry.ownerProcId) [ do [ status = Ipc_attach(entry.ownerProcId); ] while (status < 0); ] status == -11,查了下,-11表示Operation was not ready,那么需要修改什么呢? |
fb3544 发表于 2018-6-21 16:21 在cfg中修改IPC sync mode为IPC.ProcSync_ALL,此时可以把代码中的ipc attach去掉,试试。 |
只有小组成员才能发言,加入小组>>
606 浏览 0 评论
1659 浏览 0 评论
2102 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1550 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1393 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1800浏览 29评论
2827浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1753浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1671浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1686浏览 13评论
/9
GMT+8, 2025-12-17 16:52 , Processed in 1.050463 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2496
