自己做的3358板子,使用ddr3(和BBB一样),nand启动; 使用sdk8.0的uboot和kernel,修改了uboot中的read_eeprom、sdram_init中config_ddr使用和BBB一样的参数。 在启动时,串口信息如下: U-Boot SPL 2014.07-00107-gd28f2b9-dirty (Jan 23 2017 - 16:27:26) The Expected Linux image was not found. Please check your NAND configuration. Trying to start u-boot now... U-Boot 2014.07-00107-gd28f2b9-dirty (Jan 23 2017 - 16:27:26) I2C: ready DRAM: 512 MiB NAND: 256 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 *** Warning - bad CRC, using default environment Net: NAND read: device 0 offset 0x80000, size 0x40000 262144 bytes read: OK NAND read: device 0 offset 0x200000, size 0x500000 5242880 bytes read: OK Kernel image @ 0x82000000 [ 0x000000 - 0x415a48 ] ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8fff3000, end 8ffff933 ... OK Starting kernel ... 卡在这里不动。 请问下,这是有哪里没有修改到吗?(使用开源社区的BBB的uboot和kernel启动能够正常,但开源社区的UBI挂载有问题) 谢谢! |
4个回答
进入uboot命令界面,输入printenv,截图看一下传参
1、uboot参数不对的话,kernel会起不来吗?(我理解是kernel起来后运行不正常) 2、uboot参数如下: U-Boot SPL 2014.07-00107-gd28f2b9-dirty (Jan 23 2017 - 20:57:24) The Expected Linux image was not found. Please check your NAND configuration. Trying to start u-boot now... U-Boot 2014.07-00107-gd28f2b9-dirty (Jan 23 2017 - 20:57:24) I2C: ready DRAM: 512 MiB NAND: 256 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 *** Warning - bad CRC, using default environment Net: cpsw, u***_ether Hit any key to stop autoboot: 0 U-Boot# U-Boot# printenv arch=arm baudrate=115200 board=am335x board_name=A335X_SK board_rev=00C0 boot_fdt=try bootcmd=run findfdt; run mmcboot;setenv mmcdev 1; setenv bootpart 1:2; run mmcboot;run nandboot; bootcount=1 bootdelay=1 bootdir=/boot bootenv=uEnv.txt bootfile=zImage bootm_size=0x10000000 bootpart=0:2 console=ttyO0,115200n8 cpu=armv7 dfu_alt_info_emmc=rawemmc raw 0 3751936;boot part 1 1;rootfs part 1 2;MLO fat 1 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x400;spl-os-args.raw raw 0x80 0x80;spl-os-image.raw raw 0x900 0x2000;spl-os-args fat 1 1;spl-os-image fat 1 1;u-boot.img fat 1 1;uEnv.txt fat 1 1 dfu_alt_info_mmc=boot part 0 1;rootfs part 0 2;MLO fat 0 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x400;spl-os-args.raw raw 0x80 0x80;spl-os-image.raw raw 0x900 0x2000;spl-os-args fat 0 1;spl-os-image fat 0 1;u-boot.img fat 0 1;uEnv.txt fat 0 1 dfu_alt_info_nand=SPL part 0 1;SPL.backup1 part 0 2;SPL.backup2 part 0 3;SPL.backup3 part 0 4;u-boot part 0 5;u-boot-spl-os part 0 6;kernel part 0 8;rootfs part 0 9 dfu_alt_info_ram=kernel ram 0x80200000 0xD80000;fdt ram 0x80F80000 0x80000;ramdisk ram 0x81000000 0x4000000 eth1addr=f4:5e:ab:58:90:2e ethact=cpsw ethaddr=f4:5e:ab:58:90:2c fdt_addr_r=0x88000000 fdtaddr=0x88000000 fdtfile=undefined findfdt=if test $board_name = A335BONE; then setenv fdtfile am335x-bone.dtb; fi; if test $board_name = A335BNLT; then setenv fdtfile am335x-boneblack.dtb; fi; if test $board_name = A33515BB; then setenv fdtfile am335x-evm.dtb; fi; if test $board_name = A335X_SK; then setenv fdtfile am335x-evmsk.dtb; fi; if test $fdtfile = undefined; then echo WARNING: Could not determine device tree to use; fi; importbootenv=echo Importing environment from mmc ...; env import -t -r $loadaddr $filesize kernel_addr_r=0x82000000 loadaddr=0x82000000 loadbootenv=load mmc $[mmcdev] $[loadaddr] $[bootenv] loadfdt=load mmc $[bootpart] $[fdtaddr] $[bootdir]/$[fdtfile] loadimage=load mmc $[bootpart] $[loadaddr] $[bootdir]/$[bootfile] loadramdisk=load mmc $[mmcdev] $[rdaddr] ramdisk.gz mmcargs=setenv bootargs console=$[console] $[optargs] root=$[mmcroot] rootfstype=$[mmcrootfstype] mmcboot=mmc dev $[mmcdev]; if mmc rescan; then echo SD/MMC found on device $[mmcdev];if run loadbootenv; then echo Loaded environment from $[bootenv];run importbootenv;fi;if test -n $uenvcmd; then echo Running uenvcmd ...;run uenvcmd;fi;if run loadimage; then run mmcloados;fi;fi; mmcdev=0 mmcloados=run mmcargs; if test $[boot_fdt] = yes || test $[boot_fdt] = try; then if run loadfdt; then bootz $[loadaddr] - $[fdtaddr]; else if test $[boot_fdt] = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi; mmcroot=/dev/mmcblk0p2 ro mmcrootfstype=ext4 rootwait mtdids=nand0=omap2-nand.0 mtdparts=mtdparts=omap2-nand.0:128k(SPL),128k(SPL.backup1),128k(SPL.backup2),128k(SPL.backup3),256k(u-boot-spl-os),1m(u-boot),128k(u-boot-env),128k(u-boot-env.backup1),5m(kernel),-(rootfs) nandargs=setenv bootargs console=$[console] $[optargs] root=$[nandroot] rootfstype=$[nandrootfstype] nandboot=echo Booting from nand ...; run nandargs; nand read $[fdtaddr] u-boot-spl-os; nand read $[loadaddr] kernel; bootz $[loadaddr] - $[fdtaddr] nandroot=ubi0:rootfs rw ubi.mtd=9,2048 nandrootfstype=ubifs rootwait=1 netargs=setenv bootargs console=$[console] $[optargs] root=/dev/nfs nfsroot=$[serverip]:$[rootpath],$[nfsopts] rw ip=dhcp netboot=echo Booting from network ...; setenv autoload no; dhcp; tftp $[loadaddr] $[bootfile]; tftp $[fdtaddr] $[fdtfile]; run netargs; bootz $[loadaddr] - $[fdtaddr] nfsopts=nolock partitions=uuid_disk=$[uuid_gpt_disk];name=rootfs,start=2MiB,size=-,uuid=$[uuid_gpt_rootfs] ramargs=setenv bootargs console=$[console] $[optargs] root=$[ramroot] rootfstype=$[ramrootfstype] ramboot=echo Booting from ramdisk ...; run ramargs; bootz $[loadaddr] $[rdaddr] $[fdtaddr] ramdisk_addr_r=0x88080000 ramroot=/dev/ram0 rw ramrootfstype=ext2 rdaddr=0x88080000 rootpath=/export/rootfs soc=am33xx spiargs=setenv bootargs console=$[console] $[optargs] root=$[spiroot] rootfstype=$[spirootfstype] spiboot=echo Booting from spi ...; run spiargs; sf probe $[spibusno]:0; sf read $[loadaddr] $[spisrcaddr] $[spiimgsize]; bootz $[loadaddr] spibusno=0 spiimgsize=0x362000 spiroot=/dev/mtdblock4 rw spirootfstype=jffs2 spisrcaddr=0xe0000 static_ip=$[ipaddr]:$[serverip]:$[gatewayip]:$[netmask]:$[hostname]::off stderr=serial stdin=serial stdout=serial u***net_devaddr=f4:5e:ab:58:90:2e vendor=ti ver=U-Boot 2014.07-00107-gd28f2b9-dirty (Jan 23 2017 - 20:57:24) Environment size: 4641/131067 bytes U-Boot# U-Boot# 请看看有什么问题吗? 谢谢! |
hongqiaolian 发表于 2018-6-21 08:04 问题解决了,原因是我们用的是BBB的电源管理,移植时电源管理没有进行初始化,因此当CPU频率大于300M时运行不稳定。 |
只有小组成员才能发言,加入小组>>
348 浏览 1 评论
542 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
786 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
658 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1140 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
74浏览 29评论
245浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
261浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
209浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
67浏览 13评论
GMT+8, 2024-12-26 10:05 , Processed in 1.109026 second(s), Total 85, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
