电子发烧友论坛|
我编写了一个程序,原来都在RAM里面跑都正常,后来程序大了,就想烧写到FLASH里面进行调试,不过无论怎么修改,当烧写成功后,重新上电都没法启动,不知道是什么原因,而且当烧写完之后,如果不下电,只是把仿真器拔掉是可以正常运行的。不知大家是否有遇到过这种问题?是不是只是在RAM里面运行,而程序没把代码烧写到FLASH里面?或者没调用? 附上CMD代码: MEMORY [ PAGE 0: progRAM : origin = 0x008000, length = 0x001000 /* on-chip RAM (L0-L2)*/ OTP : origin = 0x3D7800, length = 0x000400 /* on-chip OTP */ FLASHH : origin = 0x3E8000, length = 0x002000 /* on-chip FLASH */ FLASHG : origin = 0x3EA000, length = 0x002000 /* on-chip FLASH */ FLASHF : origin = 0x3EC000, length = 0x002000 /* on-chip FLASH */ FLASHE : origin = 0x3EE000, length = 0x002000 /* on-chip FLASH */ FLASHD : origin = 0x3F0000, length = 0x002000 /* on-chip FLASH */ FLASHC : origin = 0x3F2000, length = 0x002000 /* on-chip FLASH */ FLASHA : origin = 0x3F6000, length = 0x001F80 /* on-chip FLASH */ CSM_RSVD : origin = 0x3F7F80, length = 0x000076 /* Part of FLASHA. Program with all 0x0000 when CSM is in use. */ BEGIN : origin = 0x3F7FF6, length = 0x000002 /* Part of FLASHA. Used for "boot to Flash" bootloader mode. */ CSM_PWL : origin = 0x3F7FF8, length = 0x000008 /* Part of FLASHA. CSM password locations in FLASHA */ IQTABLES : origin = 0x3FE000, length = 0x000B50 /* IQ Math Tables in Boot ROM */ IQTABLES2 : origin = 0x3FEB50, length = 0x00008C /* IQ Math Tables in Boot ROM */ IQTABLES3 : origin = 0x3FEBDC, length = 0x0000AA /* IQ Math Tables in Boot ROM */ BOOTROM : origin = 0x3FF27C, length = 0x000D44 /* Boot ROM */ RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM */ VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM */ PAGE 1 : BOOT_RSVD : origin = 0x000000, length = 0x000050 /* Part of M0, BOOT rom will use this for stack */ RAMM0 : origin = 0x000050, length = 0x0003B0 /* on-chip RAM block M0 */ RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */ dataRAM : origin = 0x009000, length = 0x001000 /* data RAM (L3) */ FLASHB : origin = 0x3F4000, length = 0x002000 /* on-chip FLASH */ CLA_CPU_MSGRAM : origin = 0x001480, length = 0x000080 /* CLA-R/W, CPU-R message RAM */ CPU_CLA_MSGRAM : origin = 0x001500, length = 0x000080 /* CPU-R/W, CLA-R message RAM */ ] SECTIONS [ /* Allocate program areas: */ .cinit : > FLASHA, PAGE = 0 .pinit : > FLASHA, PAGE = 0 .text : > FLASHA, PAGE = 0 codestart : > BEGIN PAGE = 0 ramfuncs : LOAD = FLASHA, RUN = progRAM, LOAD_START(_RamfuncsLoadStart), LOAD_END(_RamfuncsLoadEnd), RUN_START(_RamfuncsRunStart), PAGE = 0 csmpasswds : > CSM_PWL PAGE = 0 csm_rsvd : > CSM_RSVD PAGE = 0 /* Allocate uninitalized data sections: */ .stack : > RAMM0, PAGE = 1 .ebss : > dataRAM, PAGE = 1 .esysmem : > dataRAM, PAGE = 1 /* Initalized sections go in Flash */ /* For SDFlash to program these, they must be allocated to page 0 */ .econst : > FLASHC PAGE = 0 .switch : > FLASHA PAGE = 0 /* Allocate IQ math areas: */ IQmath : > FLASHA PAGE = 0 /* Math Code */ IQmathTables : > IQTABLES PAGE = 0, TYPE = NOLOAD /* Math Tables In ROM */ Cla1ToCpuMsgRAM : > CLA_CPU_MSGRAM PAGE = 1 CpuToCla1MsgRAM : > CPU_CLA_MSGRAM PAGE = 1 .reset : > RESET, PAGE = 0, TYPE = DSECT vectors : > VECTORS PAGE = 0, TYPE = DSECT DLOG : > dataRAM, PAGE = 1 ] 主程序为: void main(void) [ MemCopy(&RamfuncsLoadStart, &RamfuncsLoadEnd, &RamfuncsRunStart); InitFlash(); DINT; InitSysCtrl(); //系统初始化 InitPieCtrl(); //外设初始化 InitGpio(); //IO初始化 InitEPwm1Gpio(); //PWM口初始化 InitEPwm3Gpio(); //PWM口初始化 InitSciaGpio(); //通信口初始化 IER = 0x0000; IFR = 0x0000; InitPieVectTable();//外部中断初始化 InitCpuTimers(); //CPU时钟初始化 InitAdc(); //init the ADC InitSci(); //SCI通信初始化 ...... ] |
2个回答
Sam,
看起来确实像引导模式没有配置好,你应该确认一下GPIO34,GPIO37是否都是高电平,因为这两个引脚如果没有外接电路的话,默认上电时上拉使能的,因此可以自动引导到Flash,所以你要查看一下这两个引脚硬件的状态。另外你的工程里面应该有一个DSP2803x_CodeStartBranch.asm源代码,这是Flash入口地址时最开始执行的一些初始化的东西,才会跑到main。关于CMD,我的建议是可以先用TI提高的CMD文件,在controlSUITE中都有,是满足前提的开发的,避免一些错误。另外从TI提供的例程去开始你的项目,在上面做修改,在controlSUITE上也有28035_Flash的工程,你可以导入烧写。 所以肯定是可以烧写到Flash的,至于有没有烧写进入,可以在编译状态通过memory窗口查看。 新年快乐!万事如意! Eric - ERIC |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 09:24 , Processed in 0.675046 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3616
