扫一扫,分享给好友
Hi, CCS v5 or V4 suppor the daisy chain.
In CCS when you setup the target configuration, you simply add a bypass device. Here is a screen shot from CCSv5.1: I clicked "New" to add the emulator, and then with the emulator selected I clicked "Add" to add the C28xx and the bypass. Make sure the set the number of bypass bits for the CPLD. The bypass is listed at the bottom of the 'Cpus' tab when you add a component: CCSv4 is probably different, but similar. 如果您认为此问题已被解答,请在“这是否解答您的问题” 后,点击“是”按钮! 谢谢您的合作! |
www033 发表于 2018-6-11 08:48 I want datasheet for detail. Would you tell me which document present the daisy-chain? |
tvtsterwerw 发表于 2018-6-11 08:58 Sorry, there is no application note. You can refer my answer as last reply. 如果您认为此问题已被解答,请在“这是否解答您的问题” 后,点击“是”按钮! 谢谢您的合作! |
www033 发表于 2018-6-11 09:10 Ok. Thanks for your reply! |
www.ti.com/lit/SPRA439 Wish the app note Emulation Fundamentals for TI's DSP Solutions can be help for you, also you can refer to chapter 7 for other references. If a post answers your question, please mark it with the "verify answer" button. |
只有小组成员才能发言,加入小组>>
336 浏览 1 评论
529 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
774 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
651 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1130 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
56浏览 29评论
134浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
252浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
201浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
57浏览 13评论
GMT+8, 2024-12-23 04:46 , Processed in 1.060002 second(s), Total 87, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
