我刚刚买了ti DM6168 EVM评估板。拿到开发板后,按照DM816x/C6A816x/AM389x Evaluation Module Quick Start Guide ,上电启动,视频输出错误,我的启动开关SW3,SW4配置如下图, 但是没有视频输出,查了下串口打印输出 ..... EXT3-fs: barriers not enabled kjournald starting. Commit interval 5 seconds EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended EXT3-fs (mmcblk0p2): using internal journal EXT3-fs (mmcblk0p2): recovery complete EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode VFS: Mounted root (ext3 filesystem) on device 179:2. devtmpfs: mounted Freeing init memory: 180K INIT: version 2.86 bootingPlease wait: booting... Error opening /dev/fb0: No such file or directory Starting udev udevd (80): /proc/80/oom_adj is deprecated, please use /proc/80/oom_score_adj instead. Remounting root file system... Caching udev devnodes Populating dev cachemv: cannot rename '/tmp/devices': No such file or directory ALSA: Restoring mixer settings... EXT3-fs: barriers not enabled Configuring netwkjournald starting. Commit interval 5 seconds ork interfaces..EXT3-fs (mmcblk0p3): . warning: maximal mount count reached, running e2fsck is recommended EXT3-fs (mmcblk0p3): using internal journal EXT3-fs (mmcblk0p3): recovery complete EXT3-fs (mmcblk0p3): mounted filesystem with writeback data mode No state is present for card EVM Found hardware: "" "" "" "" "" Hardware is initialized using a generic method ifup: can't open '/var/run/ifstate': No such file or directory done. No state is present for card EVM Setting up IP spoofing protection: rp_filter. hwclock: can't open '/dev/misc/rtc': No such file or directory Wed Jun 1 15:06:00 UTC 2011 hwclock: can't open '/dev/misc/rtc': No such file or directory SysLink version : 02.00.00.68_beta1 SysLink module created on Date:Jun 1 2011 Time:12:56:17 Entered KnlUtilsDrv_initializeModule .... 附件里是完整的串口打印信息 请教下各位专家,是什么原因导致的么? |
3个回答
我建议你把SD卡格式化,然后重新编译一下,把MLO,uboot.bin和kernel放在SD卡的第一分区。在linux下进行操作。
还有文件系统,用TIezsdk包里的filesystem下面的argao什么的。解压,放在sd卡的rootfs。我有一系列关于DM8168的文章,你可以参考下。wenku.baidu.com/.../6de8c91e6bd97f192279e9e2.html |
binro 发表于 2018-6-11 09:55 按照alvin lu 的文章,制作一张SD卡,但是当我设置为SD卡启动时,串口没有任何输出信息,不知道为什么啊?急救!! |
如果SD卡是用ezsdk里的脚本格式化的,应该没有问题,串口没有输出则检查接线去。。。。 如果是自己在linux下用命令行格式的SD卡,其中的FAT分区建议回去XP下去重新格式化一次,然后把MLO,uImage,u-boot.bin拷贝进去,一般都可以正常启动,注意拨码开关的配置。。。 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1903 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3660 浏览 4 评论
5038 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1738 浏览 1 评论
9402 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
678浏览 2评论
726浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
694浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1204浏览 1评论
1788浏览 1评论
GMT+8, 2024-5-3 07:50 , Processed in 0.568398 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
