您可以参考之前的帖子
http://www.deyisupport.com/question_answer/wireless_connectivity/f/45/t/144632.aspx |
官网上的CC1310 LaunchPad硬件上是按868/915频段匹配的,你可以通过软件参数设置使其工作在433频段,但是传输性能会有所下降。
官网上的LAUNCHXL-CC1350-4上的sub-1GHz部分硬件上是按433频段匹配的,你可以选用这一款。 The LAUNCHXL-CC1350-4 module (CC1350 dual band Launchpad for 433 MHz/2.4 GHz) [17] combines a Bluetooth® Smart with a 433 MHz radio for the ultimate combination of easy mobile phone integration with long range connectivity including a 32-bit ARM® Cortex®-M3 processor on a single chip. The module can be used as a LaunchPad kit and as well as in SmartRF™ evaluation board application. The module is equipped with BoosterPack™ plug-in module headers, which allows using Boosterpack modules to develop different applications. The built-in on-board emulator allows to get started with instant code development in CCS cloud. The module is equipped with a separate integrated PCB trace antennae for both 433 MHz and 2.4 GHz frequency bands and also equipped with SMA connectors on each path for testing purpose and also to facilitate an external antenna connection. The LAUNCHXL-CC1350-4 module (CC1350 dual band LaunchPad for 433 MHz/2.4GHz) [17] is designed to operate in both 433 MHz and 2.4 GHz Bluetooth low energy frequency bands. The module is equipped with a separate integrated PCB trace antennas for both 433 MHz and 2.4 GHz frequency bands. The module is also equipped with SMA connectors for testing purpose and also to mount and use an external antenna for better efficiency and range. |
CC1310 433频段参考设计
http://www.ti.com/general/docs/lit/getliterature.tsp?baseLiteratureNumber=swrc330&fileType=zip |
个人用户 发表于 2018-6-6 05:00 非常感谢你们的回复。 我想咨询一下,由于cc1310中的引脚中没有USB功能接口,在电路设计时,怎么样去实现USB的功能呢?TI有没有一些电路参考设计及软件编程资料呢? 希望得到您的帮助,再次表示感谢。 |
只有小组成员才能发言,加入小组>>
762 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1973 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3721 浏览 4 评论
5086 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1788 浏览 1 评论
CC3100BOOST使用CC3200lunchXL进行烧录
766浏览 2评论
817浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
792浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1263浏览 1评论
1854浏览 1评论
GMT+8, 2024-6-26 20:39 , Processed in 1.054589 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
