ADC采集的八路数据并没有被DMA传到储存器,导致输出的八路数据都是0;其他定时器、LED,按键模块都没问题 请看代码:
#include "dma.h" #include "STM32f10x.h" void dma_init(u32 peradd,u32 memadd,u16 num){ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE); DMA_InitTypeDef dmainit; DMA_DeInit(DMA1_Channel1); dmainit.DMA_PeripheralBaseAddr = peradd; //外设地址 dmainit.DMA_MemoryBaseAddr = memadd; //储存器地址 dmainit.DMA_DIR = DMA_DIR_PeripheralSRC; //外设做数据来源 dmainit.DMA_BufferSize = num; //DMA通道缓存大小 dmainit.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址不递增 dmainit.DMA_MemoryInc = DMA_PeripheralInc_Enable;//储存器地址递增 dmainit.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//外设数据宽度16位 dmainit.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;//储存器数据宽度16位 dmainit.DMA_Mode = DMA_Mode_Normal;//普通模式 dmainit.DMA_Priority = DMA_Priority_VeryHigh;//优先级最高 dmainit.DMA_M2M = DMA_M2M_Disable;//不使能内存到内存传输 DMA_Init(DMA1_Channel1,&dmainit); } void dma_run(u16 num){ DMA_Cmd(DMA1_Channel1,DISABLE); DMA_SetCurrDataCounter(DMA1_Channel1,num); DMA_Cmd(DMA1_Channel1,ENABLE); } #include "stm32f10x.h" #include "adc.h" void adc_init(){ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOA |RCC_APB2Periph_ADC1,ENABLE); GPIO_InitTypeDef gpio_init; ADC_InitTypeDef adc_init; gpio_init.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5| GPIO_Pin_6|GPIO_Pin_7; gpio_init.GPIO_Speed = GPIO_Speed_50MHz; gpio_init.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOA,&gpio_init); gpio_init.GPIO_Pin = GPIO_Pin_0; gpio_init.GPIO_Speed = GPIO_Speed_50MHz; gpio_init.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOB,&gpio_init); adc_init.ADC_Mode = ADC_Mode_Independent;//独立模式 adc_init.ADC_ScanConvMode = ENABLE;//多通道 adc_init.ADC_ContinuousConvMode = DISABLE;//单词转换 adc_init.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//软件触发 adc_init.ADC_DataAlign = ADC_DataAlign_Right;//右对齐 adc_init.ADC_NbrOfChannel = 8;//8个通道 ADC_Init(ADC1,&adc_init); ADC_RegularChannelConfig(ADC1,ADC_Channel_1,1,ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_2,2,ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_3,3,ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_4,4,ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_5,5,ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_6,6,ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_7,7,ADC_SampleTime_239Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_8,8,ADC_SampleTime_239Cycles5); RCC_ADCCLKConfig(RCC_PCLK2_Div6); ADC_Cmd(ADC1,ENABLE); ADC_DMACmd(ADC1,ENABLE); ADC_ResetCalibration(ADC1); while(ADC_GetResetCalibrationStatus(ADC1)); ADC_StartCalibration(ADC1); while(ADC_GetCalibrationStatus(ADC1)); } #include "stm32f10x.h" #include "delay.h" #include "stdio.h" #include "my_usart.h" #include "led.h" #include "key.h" #include "timer.h" #include "adc.h" #include "dma.h" u16 key_flag = 0; uint8_t buf[4]; u16 data_buf[9]; void se_send(){ unsigned char i; GPIO_ResetBits(GPIOB,GPIO_Pin_5); delay_ms(30); for(i=0;i<4;i++){ USART_SendData(USART1,buf); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET); } GPIO_SetBits(GPIOB,GPIO_Pin_5); } void val_real(){ float temp; unsigned char i; unsigned int temp_int; uint8_t ge,shi,bai; for(i=0;i<8;i++){ temp = (float)(data_buf*3.3/4096); temp_int = temp*100; ge = temp_int%10; shi = temp_int/10%10; bai = temp_int/100; buf[0] = bai+0x30; buf[1] = '.'; buf[2] = shi+0x30; buf[3] = ge+0x30; se_send(); //串口发送 } } int main(){ my_usart_init(115200); led_init(); NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); delay_init(); init_key(); timer_init(4999,7199);// adc_init(); dma_init((u32)&ADC1->DR,(u32)&data_buf[0],8); while(1){ if(keyscan(0)==1) key_flag = ~key_flag; else ; } } void TIM3_IRQHandler(void){ if(TIM_GetITStatus(TIM3,TIM_IT_Update) != RESET&&key_flag){ dma_run(8); ADC_SoftwareStartConvCmd(ADC1,ENABLE); while(1){ if(DMA_GetFlagStatus(DMA1_FLAG_TC1)!=RESET){ DMA_ClearFlag(DMA1_FLAG_TC1); GPIO_SetBits(GPIOE,GPIO_Pin_5); break; } GPIO_ResetBits(GPIOE,GPIO_Pin_5); } val_real();//数据处理 } TIM_ClearITPendingBit(TIM3,TIM_IT_Update); } |
1个回答
没人回答吗 求大神指导哎
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1390 浏览 1 评论
1132 浏览 1 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
648 浏览 0 评论
自定义系统时钟频率后,用库函数和微带两种方式点亮LED灯,为什么灯的闪烁频率不一致?
1658 浏览 2 评论
1893 浏览 2 评论
GMT+8, 2024-4-28 05:38 , Processed in 0.506861 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
