注意:开发主机请使用ubuntu 12.04.5 x86-64(桌面版或服务器版均可),使用其他发行版的Linux或Ubuntu的其它版本可能会遇到的不必要的问题。 Note: The development host should use ubuntu 12.04.5 x86-64(desktop and server version are available),Using other distribution of Linux and other versions of Ubuntu may encounter unnecessary problems 操作说明 (operation instruction)1)文档中以“$”开头的行,其后是Linux命令。 The line in the document which begins with “$”,which is followed by the Linux command. 2)文档中所有的Linux命令建议手动输入到Linux主机执行(直接复制、粘贴到Linux主机上执行,可能会执行失败)。 All the Linux commands in the document are recommended to be entered into the host manually for execution.(Copying ,pasting to the host directly to execute may fail) 3)文档中的Linux执行命令,如果空格后的下一个字符是“-”的(如:sudo apt-get –y install之类的),请手动输入到Linux主机执行(直接复制、粘贴到Linux主机上执行,通常会执行失败)。 In all the Linux execution commands of the document,if the next character after the space is "-",(example:sudo apt-get –y install),please enter into Linux host to execute manually.(Copying ,pasting to the host directly to execute may fail ) 4)文档中所有一行没写完的Linux命令请手动输入到Linux主机执行,(因为复制、粘贴命令不能包含类似“换行符”之类的特殊字符)。 any line of Linux commands whichi is not finished is recommended to be entered into the host for execution. (Because copy or paste commands cannot contain special character such as "line breaks") 5)按文档输入并执行Linux命令时注意观察命令的执行结果与文档图片中的是否一致,以确认命令是否输入有误及是否执行失败。 Note whether the execution result is consistent with the document image when you enter and execute the command. check the command was entered incorrectly or failed to execute. 6)第一遍编译请严格按照文档进行,否则可能出现莫名其妙的错误。 Please follow the document strictly to compile for the first time.Otherwise ,there may be unexpected error 截图说明(screenshots instruction)为使视图看起来简洁整齐,截图中的命令提示符统一使用myzr$。 To make the view look neat and tidy , the command prompt in the screenshot should use myzr$ uniformly 图片中的Linux命令(Linux command in the image)在文档的图片中观察“linyn@u12045-serv:~$”开头的行可以直观的看到输入的linux命令。 In the image of the document, you can see the input Linux command visually from the lines that start with “linyn@u12045-serv:~$”。 准备源码及相关文件(prepare source code and relevant files) 源码文件(source code)评估板对应的Linux版本及对应的源码文件见下表: The corresponding Linux version of the evaluation board and the corresponding source code files are shown in the table below:
Linux program cross compilation tool:gcc-4.4.4-glibc-2.11.1-multilib-1.0.tar.bz2 Linux交叉编译工具配置文件:gcc-4.4.4-glibc-2.11.1-multilib-env Linux cross compilation tool configuration file:gcc-4.4.4-glibc-2.11.1-multilib-env 创建工作目录(creat working directory)1)源码目录 source code directory $ mkdir -p ~/my-imx28/02_source 2)工具目录 tool directory $ mkdir -p ~/my-imx28/03_tools 3)镜像目录 image directory $ mkdir -p ~/my-imx28/04_image 4)应用程序目录 application directory $ mkdir -p ~/my-imx28/01_application 准备开发环境(prepare development environment) 更新主机的源列表(update source list of host)$ sudo apt-get update 更新完成后如下图所示: it looks like below after the update 安装aptitude包管理工具和ia32-libs(install management tool of aptitude package and ia32-libs)提示:如果编译主机的Linux是32位的,可以跳过此步骤。 tips: if Linux of compilation host is 32bit,then you can skip this step 安装aptitude包管理工具(install management tool of aptitude package)$ sudo apt-get -y install aptitude 提示:上图为安装过aptitude后,再次执行安装命令的截图。 tips: the above image is the screenshots after re-execution of installation command when intallation of aptitude was completed 使用aptitude安装ia32-libs(install ia32-libs with aptitude)$ sudo aptitude -y install ia32-libs 提示:上图为安装过aptitude和ia32-libs后,再次执行安装命令的截图。 tips: the above image is the screenshots after re-execution of installation command when intallation of aptitude and ia32-libs was completed 安装mkimage工具(install mkimage tool)$ sudo apt-get -y install uboot-mkimage 提示:下图为安装过mkimage工具后,再次执行安装命令的截图。 tips: the following image is the screenshots after re-execution of installation command when intallation of mkimage was completed 安装ncurses-dev(install ncurses-dev)make menuconfig对其具有依赖性质 make menuconfig is dependant to it $ sudo aptitude -y install ncurses-dev 提示:上图为安装过ncurses-dev工具后,再次执行安装命令的截图。 tips: the above image is the screenshots after re-execution of installation command when intallation of ncurses-dev was completed 安装配置交叉编译工具链(install and configure cross compiler tool chain) 安装Linux交叉编译工具链(install cross compilation tool chain)1)进入交叉编译工具链目录 enter cross compilation tool chain diretory $ cd ~/my-imx28/03_tools/ 2)复制Linux交叉编译工具到目录 copy Linux cross compilation tool to directory 将gcc-4.4.4-glibc-2.11.1-multilib-1.0.tar.bz2复制到“~/my-imx28/03_tools”,这一步自己采取相应的方式完成。 copy gcc-4.4.4-glibc-2.11.1-multilib-1.0.tar.bz2 to“~/my-imx28/03_tools”,this step should be done in your own way 3)解压Linux交叉编译工具 decompress Linux cross compilation tool $ tar jxf gcc-4.4.4-glibc-2.11.1-multilib-1.0.tar.bz2 4)复制交叉编译工具配置文件 copy congigured file of cross compilation tool 将gcc-4.4.4-glibc-2.11.1-multilib-env复制到“~/my-imx28/03_tools”,这一步自己采取相应的方式完成。 copy gcc-4.4.4-glibc-2.11.1-multilib-env to“~/my-imx28/03_tools”,this step should be done in your own way 5)检查安装 check installation $ source gcc-4.4.4-glibc-2.11.1-multilib-env $ ${CROSS_COMPILE}gcc –v U-Boot编译(U-Boot compilation) 准备编译(prepare compilation)复制源码包到开发主机中(copy source code package to development host)将下载的“u-boot源码”复制到Linux开发主机的“~/my-imx28/02_source”。 copy“u-boot source code”downloaded to “~/my-imx28/02_source”of Linux development host 这一步自己采取相应的方式完成。 this step should be done in your own way 解压u-boot源码包(decompress u-boot source code)$ cd ~/my-imx28/02_source/ $ tar jxf u-boot-2009.08.tar.bz2 $ tar jxf imx-bootlets-src-10.12.01.tar.bz2 编译(compile)使编译配置文件生效(validate configured file of compilation)$ source ~/my-imx28/03_tools/gcc-4.4.4-glibc-2.11.1-multilib-env 进入u-boot源码目录(enter u-boot source code directory)$ cd ~/my-imx28/02_source/u-boot-2009.08 清除u-boot临时文件(remove u-boot temporary file)$ make distclean 配置u-boot(configure)
$ make mx28_evk_config 执行编译(execute compilation)$ make 提示:这里为了提高编译速度,在make后面加了“-j4”。这里编译的Linux主机是双核4线程的,所以“-j”后面用了4,也就是采用4线程编译。“-j”后面的数字可以根据系统资源分配,但是不应该超过编译主机最大支持的线程数。 Tips:To speed up the compilation,add "-j4" after make.The Linux host used to compile is dual-core ,4 threads .So "-j" is followed by 4, which takes 4 threads to compile. The number behind "-j" is allocated based on system resources,but It should not exceed the maximum threads the host support.
提示:imx28_ivt_uboot.***是烧写的镜像。 tips: imx28_ivt_uboot.*** is the image programmed $ cp u-boot ../imx-bootlets-src-10.12.01 $ cd ../imx-bootlets-src-10.12.01/ $ sudo cp elfto*** /usr/bin/ $ ./build 目标文件(target file)
编译完成后通过ls命令即可看到编译得到的文件imx28_ivt_uboot.*** you can get the compiled file imx28_ivt_uboot.*** with ls command after compilation. $ ls
MY-IMX28系列评估板的u-boot配置对应的目标文件名见下表: The corresponding name of target file for u-boot configuration of MY-IMX28 series evaluation board is shown in the table below:
准备编译(prepare compilation)复制源码包到开发主机中(copy source code package to the development host)将下载的“linux源码”复制到Linux开发主机的“~/my-imx28/02_source”。 copy“linux source code” to “~/my-imx28/02_source”of Linux development host 这一步自己采取相应的方式完成。 this step should be done in your own way 解压linux源码包(decompress Linux source code package)$ cd ~/my-imx28/02_source/ $ tar jxf linux-2.6.35.3.tar.bz2 内核编译配置(configuration of kernel compilation)使编译配置文件生效(validate configured file of compilation)$ source ~/my-imx28/03_tools/gcc-4.4.4-glibc-2.11.1-multilib-env 清除内核临时文件(remove kernel temporary file)
$ cd ~/my-imx28/02_source/linux-2.6.35.3
$ make distclean 内核配置(kernel configuration)$ cp .mx28_config .config 编译内核(compile kernel)
$ make zImage -j4
arch/arm/boot/uImage即为编译得到的内核文件,使用ls命令可查看文件信息。 arch/arm/boot/uImage is the kernel file compiled,you can check the file information with ls command $ ls arch/arm/boot/uImage -la 编译模块 (compile module)
$ make modules
$ make modules_install INSTALL_MOD_PATH=./modules
$ cd modules $ tar cjf ../modules.tar.bz2 * 应用程序编译(compile application) Linux应用程序编译(compilation of Linux application)编写应用程序 (write application)
$ cd ~/my-imx28/01_application/
$ vim hello.c 写入以下代码并保存 write and save the following code
{ printf("Hello, MYZR!n"); return; }
$ cat hello.c 编译应用程序 (compile application)
$ ${CROSS_COMPILE}gcc hello.c -o hello.out 注意:上面的命令有包含“$”号,即“${CROSS_COMPILE}gcc”,是引用我们source时产生的环境变量。 Note:The above command contains “$”,which is “${CROSS_COMPILE}gcc”. It is the environment variable generated when referring to our source.
$ file hello.out 可以看到目标文件 hello.out 的属性。 you can see the property of target file hello.out 文件系统(file system) 文件系统rootfs.tar.bz2(file system rootfs.tar.bz2)用以下的方式增加自己的应用:(把MY-IMX28_Born_ToolProfilesMX28 Linux UpdateOS Firmwarefilesimage-linux-2635/rootfs.tar.bz2复制到“~/my-imx28/04_image/”目录下)。 add your own application in following ways:( copy MY-IMX28_Born_ToolProfilesMX28 Linux UpdateOS Firmwarefilesimage-linux-2635/rootfs.tar.bz2 to the directory of “~/my-imx28/04_image/”) 文件系统rootfs.ubifs(file system rootfs.ubifs)复制mkfs.ubifs,ubinize到电脑的“/usr/bin”目录下(如果电脑有这两个应用就不需要复制了);复制build_rootfs和ubinize.cfg到“~/my-imx28/04_image/”目录。 copy mkfs.ubifs,ubinize to“/usr/bin”directory of computer(copy is not needed if the computer has these two applications);copy build_rootfs和ubinize.cfg to“~/my-imx28/04_image/”directory 烧写方式(way of programming) 至此,我们在“~/my-imx28/02_source/”得到了除文件系统以外的一套烧录文件。包括“imx28_ivt_uboot.***”、“uImage”、“rootfs.tar.bz2”。 so far,we get a set of programming files except file system from“~/my-imx28/02_source/”,including“imx28_ivt_uboot.***”、“uImage”、“rootfs.tar.bz2” 使用MFGTOOL烧写(program with MFGTOOL)把文件“imx28_ivt_uboot.***”、“uImage”、“rootfs.tar.bz2复制到“MY-IMX28_Born_ToolProfilesMX28 Linux UpdateOS Firmwarefilesimage-linux-2635”目录下。按住REC按键,插上MINI USB线和电源线,接着打开MfgTool.exe,点击“扫描设备”,检测到HID设备时,松开REC按键,如下所示: copy “imx28_ivt_uboot.***”、“uImage”、“rootfs.tar.bz2 to the directory of “MY-IMX28_Born_ToolProfilesMX28 Linux UpdateOS Firmwarefilesimage-linux-2635”。hold REC key,plug in MINI USB line and power line,then open MfgTool.exe,click"scan device",release REC key when HID device is detected,as below: 点击菜单的“Options”,然后在选项“Profiles”选择“MY-IMX28-2.6.35 NAND with uboot”,接着点击“确定”,最后点击“开始”。 click"Options" in the menu,select “MY-IMX28-2.6.35 NAND with uboot”in the option “Profiles”,then click"Enter",finally click"start" 烧写成功后,点击“停止”就OK了。 when programming is succeeded,click"stop",to finish 注意:如果你用的文件系统是rootfs-qt.tar.bz2,请选择“QT-MY-IMX28-2.6.35 NAND with uboot”烧写镜像。 note: if the file system you are using is rootfs-qt.tar.bz2,please choose “QT-MY-IMX28-2.6.35 NAND with uboot”as programming image 使用网络烧写(program via network)搭建TFTP (ubuntu系统)(establish TFTP (ubuntu system))(1) Setup tftp server files |
GMT+8, 2025-12-14 07:48 , Processed in 1.042544 second(s), Total 65, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
