大家好,我用 am5728 evm的编码的时候,发生了内存泄漏,之前没有使用 g_signal_connect 也是会发生内存泄露,这个问题困扰了我很久,希望大家给看一下。内存泄露需要使用 top 命令 观察大概 5-10分钟就可以看到结果开发包是 ti-processor-sdk-linux-am57xx-evm-03.03.00.04 系统使用的ubuntu14.04。/* * * * gst-launch-1.0 -v -e v4l2src device=/dev/video1 io-mode=2 ! * 'video/x-raw, format=(string)NV12, width=(int)640, height=(int)480, framerate=(fraction)30/1,bitrate=(int)30' ! * ducatih264enc ! h264parse ! ducatih264dec ! waylandsink sync=false * **/#include #include #include #include #include #include #include #include #include #include #include #define waylandsink#define v4l2srctypedef struct _App App;struct _App[ GstElement *pipeline; GstElement *appsrc; GstElement *encode; GstElement *parse; GstElement *sink; GstElement *decode; GstBus *bus; GstMessage *msg; GMainLoop *loop; guint bus_watch_id;];App s_app;int ret, idx, fd;#define NBUF 3#define FRAME_SIZE 152064 //352*288*1.5int width = 352, height = 288;void *buffer_addr[NBUF];int size[NBUF];static voidfeed_data (GstElement * appsrc, guint size, App * app)[// while(1)// [// fd_set fds;// struct timeval tv;// int r=0;// FD_ZERO(&fds);// FD_SET(fd,&fds);// tv.tv_sec=0;// tv.tv_usec=1000*100;// r=select(fd+1,&fds,NULL,NULL,&tv);// if(-1==r)// [// printf("1111rn");// continue;// ]// if(0==r)// [// printf("2222rn");// return FALSE;// ] printf("feed-data....n"); struct v4l2_buffer buf; /* Dequeue one buffer */ memset(&buf, 0, sizeof(buf)); buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; buf.memory = V4L2_MEMORY_MMAP; if(-1 == xioctl(fd, VIDIOC_DQBUF, &buf)) [ perror("Queue Buffer"); return FALSE; ] idx = buf.index; GstBuffer *buffer; GstFlowReturn ret; buffer = gst_buffer_new_allocate(NULL,FRAME_SIZE,NULL); GstMapInfo info; gst_buffer_map(buffer,&info,GST_MAP_WRITE); unsigned char * buff = info.data;// if((void*)buf.m.userptr!=0)// [// memcpy(buff,buf.m.userptr,FRAME_SIZE);// ] memcpy(buff,buffer_addr[idx],FRAME_SIZE); gst_buffer_unmap(buffer,&info); g_signal_emit_by_name(app->appsrc,"push-buffer",buffer,&ret); printf("ret:%dn",ret); if (ret != GST_FLOW_OK) [ /* some error, stop sending data */ printf("push error...n"); return FALSE; ] gst_buffer_unref(buffer); memset(&buf, 0, sizeof(buf)); buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; buf.memory = V4L2_MEMORY_MMAP; buf.index = idx; if(-1 == xioctl(fd, VIDIOC_QBUF, &buf)) [ perror("Queue Buffer"); return FALSE; ] return TRUE;// ]]int xioctl(int fd, int request, void *arg)[ int r; do r = ioctl (fd, request, arg); while (-1 == r && EINTR == errno); return r;]int init_device(int fd) [ unsigned int i; struct v4l2_capability caps; struct v4l2_format fmt; struct v4l2_requestbuffers req; struct v4l2_buffer buf; /* Check for capture device */ memset(&caps, 0, sizeof(caps)); if (-1 == xioctl(fd, VIDIOC_QUERYCAP, &caps)) [ perror("Setting Pixel Format"); return 1; ] printf("Driver: %sncaps: %8x", caps.driver, caps.capabilities); if (~caps.capabilities & V4L2_CAP_VIDEO_CAPTURE) [ printf("Not a capture device"); return 1; ] /* Set capture format to UYVY */ memset(&fmt, 0, sizeof(fmt)); fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; fmt.fmt.pix.width = width; fmt.fmt.pix.height = height; fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_NV12; // fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_UYVY; fmt.fmt.pix.field = V4L2_FIELD_NONE; if (-1 == xioctl(fd, VIDIOC_S_FMT, &fmt)) [ perror("Setting Pixel Format"); return 1; ] printf("Selected Camera Mode:n" " Width: %dn" " Height: %dn" " Field: %d", fmt.fmt.pix.width, fmt.fmt.pix.height, fmt.fmt.pix.field); printf(" PixFmt = %c%c%c%cn", fmt.fmt.pix.pixelformat & 0xFF, (fmt.fmt.pix.pixelformat >> 8) & 0xFF, (fmt.fmt.pix.pixelformat >> 16) & 0xFF, (fmt.fmt.pix.pixelformat >> 24) &0xFF); /* Currently driver supports only mmap buffers * Request memory mapped buffers */ memset(&req, 0, sizeof(req)); req.count = NBUF; req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; req.memory = V4L2_MEMORY_MMAP; if (-1 == xioctl(fd, VIDIOC_REQBUFS, &req)) [ perror("Requesting Buffer"); return 1; ] printf("Total buffer num %dn", req.count); for (i = 0; i < req.count; i++) [ memset(&buf, 0, sizeof(buf)); buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; buf.memory = V4L2_MEMORY_MMAP; buf.index = i; if (-1 == xioctl(fd, VIDIOC_QUERYBUF, &buf)) [ perror("Querying Buffer"); return 1; ] /* Memory map all the buffers and save the addresses */ buffer_addr = mmap(NULL, buf.length, PROT_READ | PROT_WRITE, MAP_SHARED, fd, buf.m.offset); //buffer_addr=(void*)malloc(FRAME_SIZE); size = buf.length; printf("Address %p, size %d, image size: %d n", buffer_addr, buf.length, buf.bytesused); /* Queue the buffer for capture */ memset(&buf, 0, sizeof(buf)); buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; buf.memory = V4L2_MEMORY_MMAP; buf.index = i; if (-1 == xioctl(fd, VIDIOC_QBUF, &buf)) [ perror("Queue Buffer"); return 1; ] printf("12345rn"); ] if (-1 == xioctl(fd, VIDIOC_STREAMON, &buf.type)) [ perror("Start Capture"); return 1; ] return 0;]void release_device(int fd)[ int type = V4L2_BUF_TYPE_VIDEO_CAPTURE; xioctl(fd, VIDIOC_STREAMOFF, &type); close(fd);]gboolean bus_call(GstBus *bus, GstMessage *msg, gpointer data)[ GMainLoop *loop = (GMainLoop *) data; switch (GST_MESSAGE_TYPE (msg)) [ case GST_MESSAGE_EOS: fprintf(stderr, "End of streamn"); g_main_loop_quit(loop); break; case GST_MESSAGE_ERROR: [ gchar *debug; GError *error; gst_message_parse_error(msg, &error, &debug); g_free(debug); g_printerr("Error: %sn", error->message); g_error_free(error); g_main_loop_quit(loop); break; ] default: break; ] return TRUE;]int main(int argc, char **argv)[ App *app = &s_app; printf("==========n"); char devnode[100] = "/dev/video1"; fd = open(devnode, O_RDWR); if (fd == -1) [ perror("Opening video device"); return 1; ] ret = init_device(fd); if (0 != ret) [ printf("Exiting"); return ret; ] gst_init(NULL,NULL); app->pipeline = gst_pipeline_new("encode"); g_assert(app->pipeline); app->appsrc = gst_element_factory_make("appsrc","srcElement"); g_assert(app->appsrc); app->encode = gst_element_factory_make("ducatih264enc","encodeElement"); g_assert(app->encode); app->parse = gst_element_factory_make("h264parse","parseElement"); g_assert(app->parse); app->decode = gst_element_factory_make("ducatih264dec","decodeElement"); g_assert(app->decode);#ifdef waylandsink app->sink = gst_element_factory_make("waylandsink","sinkElement");#else app->sink = gst_element_factory_make("appsink","sinkElement");#endif g_assert(app->sink); printf("element creat successn"); GstCaps *capsappsrc2H264enc; capsappsrc2H264enc = gst_caps_new_simple("video/x-raw", "format",G_TYPE_STRING, "NV12", "width", G_TYPE_INT, 352, "height",G_TYPE_INT, 288, "framerate", GST_TYPE_FRACTION, 30, 1, NULL); g_object_set(G_OBJECT (app->sink), "sync", FALSE, NULL); app->loop = g_main_loop_new(NULL,FALSE); app->bus = gst_pipeline_get_bus(GST_PIPELINE(app->pipeline)); app->bus_watch_id = gst_bus_add_watch(app->bus,bus_call,app->loop); gst_object_unref(app->bus); gst_bin_add_many(GST_BIN(app->pipeline), app->appsrc,app->encode, app->parse,app->decode,app->sink, NULL); gboolean bLinkOk=gst_element_link_filtered(app->appsrc, app->encode, capsappsrc2H264enc); if(!bLinkOk)[ g_warning("Failed to link src encode n"); return -5; ] bLinkOk= gst_element_link_many(app->encode, app->parse,app->decode,app->sink,NULL); if(!bLinkOk)[ g_warning("Failed to link many 1n"); return -5; ] g_signal_connect(app->appsrc, "need-data", G_CALLBACK(feed_data), app); gst_element_set_state (app->pipeline, GST_STATE_PLAYING); printf("run....1n"); g_main_loop_run(app->loop); printf("run....2n"); app->msg = gst_bus_timed_pop_filtered (app->bus, GST_CLOCK_TIME_NONE, GST_MESSAGE_ERROR | GST_MESSAGE_EOS); if (app->msg != NULL) gst_message_unref (app->msg); gst_object_unref (app->bus); gst_element_set_state (app->pipeline, GST_STATE_NULL); gst_object_unref (app->pipeline); gst_object_unref(app->appsrc); gst_object_unref(app->encode); gst_object_unref(app->parse); gst_object_unref(app->decode); gst_object_unref(app->sink); printf("close...n"); return 0;]编译命令: ARM-linux-gnueabihf-gcc app-camera.c -o app `pkg-config --cflags --libs gstreamer-1.0 gstreamer-base-1.0 gstreamer-app-1.0`
2个回答
