All rights reserved.
No part of this document may be reproduced, stored, or transmitted, in any form or by any means without the prior written permission of Norel Systems. Data contained in this document is subject to change without notice. Norel Systems makes no warranties of any kind, of functionality or suitability. Norel Systems assumes no responsibility for any errors that may appear in this document. Norel Systems assumes no responsibility or liability for any use of the information contained herein. Introduction NS5530 is a long reach SD and HD video transmitters supporting Advanced Video Transport (AVT) technology with visually lossless digital video compression. It also supports uncompressed video transmission and is compatible with SMPTE SD-SDI, HD-SDI and 3G-SDI. NS5530 supports most VESA and HDTV video formats up to HD 1080p50/60. NS5530 employs Norelsys’ advanced video compression technologies and can extend the reach of HD video over UTP or coaxial cable at a serial data rate configurable from 135Mbps to 2.97Gbps. A programmable Reed-Solomon FEC block is implemented for increased reliability. NS5530 provides channels for downstream and upstream audio transmission. NS5530 also provides data channels for the transmission of I2C, UART, IR and PS2 signals on both downstream and upstream directions. Configuration Registers Video Capture Logic Audio Logic Power Management PLL with Low Noise VCO Host Interface Real-time Compression, Audio Embedding & Ancillary Data Insertion 8B/10B Encoder, Scrambler & Serializer Reed-Solomon FEC Video Data Audio Data Serial Cable Driver NS5530 SDO SDO SPI, I2C, UART & GPIO Figure 1. Functional Block Diagram 1.1. Related Documents EDN-5096, NS5531 Full HD Video Receiver EDN-5078, NS2539 Advanced Video Transport (AVT) Repeater 1.2. Applications HDMI and DisplayPort video extension KVM video and control transmission Zero-client video transmitter |
1575 浏览 0 评论
5258 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9771 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2948 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2372 浏览 1 评论
/9
GMT+8, 2025-12-14 16:59 , Processed in 0.516819 second(s), Total 66, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
