扫一扫,分享给好友
程序编译没问题,如下:(愁死了,一直都不行,使用的是USART3,无输出。如果换成USART1,程序做响应的修改,而且在配置option里选中use microlib 是可以的,但是为什么要选中use microlib?而且怎么才能使用USART3)用的STM32f107VC芯片串口调试助手没任何显示:
#include"stm32f10x.h" #include void Delay_MS(u16 dly); void COM_Configuration(void); u8 tab[]="nHello! everyone,welcome to class!"; int main(void) { u8 i; COM_Configuration(); printf("n Hello, very good,t %d",0x55); printf("nr WWW.ARMJISHU.COM! n"); printf("nr WWW.ARMJISHU.COM! n"); while(1) { for(i=0;i<33;i++) { USART_SendData(USART3, tab); Delay_MS(2000); } } } void Delay_MS(u16 dly) { u16 i,j; for(i=0;i } void COM_Configuration() { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef U3; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB ,ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOB,&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOB,&GPIO_InitStructure); U3.USART_BaudRate =115200; U3.USART_WordLength = USART_WordLength_8b; U3.USART_StopBits = USART_StopBits_1; U3.USART_Parity = USART_Parity_No; U3.USART_Mode = USART_Mode_Rx|USART_Mode_Tx; U3.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_Init(USART3, &U3); USART_Cmd(USART3,ENABLE); USART_ClearFlag(USART3, USART_FLAG_TXE); } int fputc(int ch, FILE *f) { /* e.g. write a character to the USART */ USART_SendData(USART3, (uint8_t) ch); /* Loop until the end of transmission */ while(USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET); return ch; } int fgetc(FILE *fp) { int ch = 0; while(USART_GetFlagStatus(USART3, USART_FLAG_RXNE) == RESET); ch = (int)USART3->DR & 0xFF; putchar(ch); return ch; } |
11个回答
Mr_RMS 发表于 2017-4-12 10:57 这个要多看一下相关资料 别急慢慢来
最佳答案
原因找到了,是我根本没理解USART串口的连接,,每个串口硬件电路上都是连接好的,比如232串口一接的就是USART1的相关管脚,232串口2接的是USART2的相关管脚,、配置好USART3,使用232串口一这样是不行的,而是要在硬件电路上有个232串口接的是USART3的相关管脚。。。我根本就没搞懂串口通信硬件上的意义和方式,也没搞懂232的实际用法和电路,自己学的太肤浅太粗糙了,不过刚开始学,很多都不懂
在主程序里要包含stdio文件啊
这些问题根本不用回答,太幼稚
您牛逼,不过您也不是一开始就这么牛逼吧?您现在觉着您自己幼稚吗?肯定不幼稚,那么您觉着您儿童时您幼稚吗?您觉着您小时候穿开裆裤的时候幼稚吗? |
我也出在这个问题上了。不过您这个答案我没太看明白
我当时出现的错误是硬件和程序对应的问题,我在程序上使用了USART3,在开发板硬件电路上使用的232串口1,而硬件电路上的232串口1的管脚连接是连接到USART1的管脚,这样USART3与串口1间是没办法通信的。要使用USART3,在硬件电路上,就要使用一个管脚与USART3的管脚相连的232串口,而不是一个管脚连接到USART1管脚的串口。。。。这是我出现错误的原因 不是知道是不是您出现问题的原因 |
Mr_RMS 发表于 2018-4-11 10:39 今早刚解决这个问题。我的usart3乱码的原因是因为,我的板子上带了一块max3232电平转换芯片,我买了一个u***转串口的小器件,因此实际转换了两次。另外,我还有一点搞不明白的是,为什么我不加printf()函数重定向,只用usart_senddata()与usart_receivedata()是可以使用串口助手发送接收数据的,只不过程序刚开始运行时点击发送快一些,接收会乱码,但是过一段时间会稳定。这是我现在疑惑地。不过项目进度很赶,还没有时间搞清楚这个问题。 |
伟伟weiwei 发表于 2018-4-14 15:36 ARM嵌入式单片机学习群 524872455 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2105 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
1941 浏览 3 评论
4537 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2084 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
2599 浏览 1 评论
GMT+8, 2024-12-22 14:49 , Processed in 0.813743 second(s), Total 95, Slave 77 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
