#include
#include #define uchar unsigned char #define uint unsigned int uint f,speed;//初始定义测速的F为记录的脉冲,speed为速度,time为定时次数, uchar time; //1602定义// unsigned char code digit[10]={"0123456789"}; //定义字符数组显示数字 ***it RS = P1^0; //定义端口 ***it RW = P1^1; ***it EN = P2^5; ***it DU = P2^0; ***it WE = P2^1; #define RS_CLR RS=0 #define RS_SET RS=1 #define RW_CLR RW=0 #define RW_SET RW=1 #define EN_CLR EN=0 #define EN_SET EN=1 #define DataPort P0 //计时器0// void timer0 () { TMOD=0x51;//设置定时器0.方式1 TH0=(65536-5000)/256;//定时50ms TL0=(65536-5000)%256; EA=1; ET0=1; TR0=1; } //计数器1,用来记录光电测速的脉冲// //定时器0中断分别执行调速和测速// void time0 (void) interrupt 1 { TH0=(65536-5000)/256;//定时1ms TL0=(65536-5000)%256; //测速// time=time++; } //显示模块// void cmg88()//关数码管,点阵函数 { DU=1; P0=0X00; DU=0; } /*------------------------------------------------ uS延时函数,含有输入参数 unsigned char t,无返回值 unsigned char 是定义无符号字符变量,其值的范围是 0~255 这里使用晶振12M,精确延时请使用汇编,大致延时 长度如下 T=tx2+5 uS ------------------------------------------------*/ void DelayUs2x(unsigned char t) { while(--t); } /*------------------------------------------------ mS延时函数,含有输入参数 unsigned char t,无返回值 unsigned char 是定义无符号字符变量,其值的范围是 0~255 这里使用晶振12M,精确延时请使用汇编 ------------------------------------------------*/ void DelayMs(unsigned char t) { while(t--) { //大致延时1mS DelayUs2x(245); DelayUs2x(245); } } /*------------------------------------------------ 判忙函数 ------------------------------------------------*/ bit LCD_Check_Busy(void) { DataPort= 0xFF; RS_CLR; RW_SET; EN_CLR; _nop_(); EN_SET; return (bit)(DataPort & 0x80); } /*------------------------------------------------ 写入命令函数 ------------------------------------------------*/ void LCD_Write_Com(unsigned char com) { while(LCD_Check_Busy()); //忙则等待 RS_CLR; RW_CLR; EN_SET; DataPort= com; _nop_(); EN_CLR; } /*------------------------------------------------ 写入数据函数 ------------------------------------------------*/ void LCD_Write_Data(unsigned char Data) { while(LCD_Check_Busy()); //忙则等待 RS_SET; RW_CLR; EN_SET; DataPort= Data; _nop_(); EN_CLR; } /*------------------------------------------------ 清屏函数 ------------------------------------------------*/ void LCD_Clear(void) { LCD_Write_Com(0x01); DelayMs(5); } /*------------------------------------------------ 写入字符串函数 ------------------------------------------------*/ void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s) { if (y == 0) { LCD_Write_Com(0x80 + x); //表示第一行 } else { LCD_Write_Com(0xC0 + x); //表示第二行 } while (*s) { LCD_Write_Data( *s); s ++; } } /*------------------------------------------------ 写入字符函数 ------------------------------------------------*/ void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data) { if (y == 0) { LCD_Write_Com(0x80 + x); } else { LCD_Write_Com(0xC0 + x); } LCD_Write_Data( Data); } /*------------------------------------------------ 初始化函数 ------------------------------------------------*/ void LCD_Init(void) { LCD_Write_Com(0x38); /*显示模式设置*/ DelayMs(5); LCD_Write_Com(0x38); DelayMs(5); LCD_Write_Com(0x38); DelayMs(5); LCD_Write_Com(0x38); LCD_Write_Com(0x08); /*显示关闭*/ LCD_Write_Com(0x01); /*显示清屏*/ LCD_Write_Com(0x06); /*显示光标移动设置*/ DelayMs(5); LCD_Write_Com(0x0C); /*显示开及光标设置*/ } //将速度数据送到显示屏// void dectobit(uint dec) { unsigned char ge,shi,bai,qian; ge=dec%10; shi=dec%100/10; bai=dec%1000/100; qian=dec/1000; LCD_Write_Char(4,0,digit[ge]); LCD_Write_Char(3,0,digit[shi]); LCD_Write_Char(2,0,digit[bai]); LCD_Write_Char(1,0,digit[qian]); LCD_Write_String(1,1,"zhuan su"); } //主函数// void main() { cmg88();//关数码管,点阵函数 LCD_Init(); LCD_Clear();//清屏 timer0(); TH1=0x00; TL1=0x00; ET1=1; TR1=1; while(1) { if(time==20)//判断时间是否到1S了,50ms*20=1S { TR0=0; TR1=0;//到了时间,停止计数器1 time=0;//清零 f=TH1; f=f<<8; f=f+TL1; dectobit(f); TH1=0x00; TL0=0x00; TR0=1; TR1=1; } } } 程序是这个,但是我试了,电机匀速时,它只能不断累积脉冲数,就是一直增加,直到溢出重新累加,显示就如0000,0030,0060,....就是不能显示出速度,而且当电机停止后,显示不清零的 |
3个回答
main()里定时器1的TL1没有清0。定义的“F为记录的脉冲,speed为速度”都没有在程序中运算,dectobit(f);只显示脉冲数。 |
转速单位应该是转/每分钟,你如果是测1秒的转速,那还需要乘以60
我改了,但是在没有脉冲情况下,等了很久它都没有清零。按理说,下一秒没脉冲后,TI都没记录到脉冲,不是应该为0么,然后显示屏上显示0了么? |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2024年上海海思MCU开发者体验官招募,手机/MatePad大奖等你拿!
1111 浏览 0 评论
【xG24 Matter开发套件试用体验】蓝牙控制板载LED
876 浏览 0 评论
1043 浏览 0 评论
电赛:mspm0l1306的开发板可以烧录程序,但是程序运行不了,怎么解决这个问题?
1094 浏览 1 评论
【xG24 Matter开发套件试用体验】Silicon Labs 基于 EFR32MG24 Explorer Kit 开发板 开箱试用体验
857 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
10524 浏览 31 评论
浏览过的版块 |
GMT+8, 2024-8-6 19:24 , Processed in 0.765516 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
