型号 厂商 封装
10MQ100NTRPBF VISHAY SMA 12CWQ04FNTRPBF VISHAY D-PAK 12CWQ06FNTRPBF VISHAY D-PAK 12CWQ10FNTRPBF VISHAY D-PAK 16CTQ100PBF VISHAY TO-220A 16CTU04STRLPBF VISHAY D2-PAK 1N4148W-7-F DIODES SOD-123 1N4746A ST DO-41 1N5248B-TAP VISHAY DO-35 1N5819RLG ON AXIAL L 1SMA10AT3G ON SMA-2 1SMA40AT3G ON SMA-2 1SMA5.0AT3G ON SMA-2 20CTH03PBF VISHAY TO-220A 2N4403RLRAG ON TO-92 2N7002-7-F DIODES SOT-23 2N7002LT1G ON SOT-23 2SA1020-YTE6.F.M TOSHIBA TO-92 2SA1037AKT146R ROHM SOT-23 2SC2655-YTE6.FM TOSHIBA TO-92 2SK2962 TOSHIBA TO-92 2SK3569(STA4QM) TOSHIBA TO-220F 2SK3673 FUJI TO-220F 2SK4106STA4QT TOSHIBA TO-220F 30CPQ060PBF VISHAY TO-247A 30CPQ100PBF VISHAY TO-247A 30CPQ150PBF VISHAY TO-247 30CTQ060PBF VISHAY TO-220 30CTQ100PBF VISHAY TO-220 40CPQ045PBF VISHAY TO-247 40CPQ060PBF VISHAY TO-247A 40L15CTPBF VISHAY TO-220 60CPU02-F VISHAY TO-247 60CTQ150PBF VISHAY TO-220 63CPQ100PBF VISHAY TO-247 6CWQ10FNTRPBF VISHAY D-PAK ABS10F 天津中环 SO-4 AIT8455PK DSP 1 B230-13-F DIODES SMB B340A-13-F DIODES SMA BAS16TW-7-F DIODES SOT-363 BAV116W-7-F DIODES SOD-123 BAV21W TAK CHE SOD-123 BAV70 NXP SOT-23 BAV70LT1G ON SOT-23 BAV99 NXP SOT-23 BAV99LT1G ON SOT-23 BAW56 NXP SOT-23 BC847BPN115 NXP SOT-363 BC847BS NXP SOT-363 BCP56-16 NXP SOT-223 BCR402U E6327 INFINEON SC74-6 BCX53 NXP SOT-89 BCX53-16 NXP SOT-89 BCX56 NXP SOT-89- BCX56-16 NXP SOT-89 BSC014N04LSI INFINEON SO-8 BSC018N04LSG INFINEON SO-8 BSC020N03LSG INFINEON TDSON-8 BSC027N04LSG INFINEON PG-TDSO BSC035N04LSG INFINEON TDSON-8 BSC042N03MSG INFINEON SOIC-8 BSC057N08NS3G INFINEON PG-TDSO BSC060N10NS3G INFINEON SO-8 BSC077N12NS3G INFINEON SO-8 BSC0908NS INFINEON SO-8 BSC105N10LS INFINEON SOP-8 BSC123N10LSG INFINEON SOIC-8 BSC520N15NS3G INFINEON PG-TDSO BSC883N03MSG INFINEON SO-8 BSC889N03LSGE8178 INFINEON PG-TDSO BSO080P03S INFINEON DSO-8 BSS123LT1G ON SOT-23 BSS138LT1G ON SOT-23- BSS84LT1G ON SOT-23- BYC10-600 NXP TO-220A BYC10X-600 NXP TO-220F BYC15-600 NXP TO-220A BYC20-600 NXP TO-220A BYC8-600 NXP TO-220A BYC8X-600 NXP TO-220F BYQ28E-200 NXP TO-220A BYQ28X-200 NXP TO-220F BYV26C-TAP VISHAY SOD-57 BYV26E-TAP VISHAY SOD-57 BYV32E-200 NXP TO-220A BYV42E-200 NXP T0-220A BYW29-200G ON TO-220 BZX84-C24 NXP SOT-23 BZX84-C27 NXP SOT-23 BZX84-C68 NXP SOT-23 C3D04060A CREE TO-220 C3D06060A CREE TO-220A C3D06060G-TR CREE TO-263 C3D08060A CREE TO-220A CNY17F-2-X001 INFINEON DIP-6 DTC123JKA ROHM SOT-23 EL817M(B)(PI)-F EVERLIG TO FAN4802LMY FAIRCHI SOP-16 FAN4802NY FAIRCHI DIP-16 FAN6208MY FAIRCHI SOP-8 FAN7602CMX FAIRCHI SO-8 FCPF11N60 FAIRCHI TO-220F FDP18N50 FAIRCHI TO-220 FDPF12N60NZ FAIRCHI TO-220F FDPF5N60NZ FAIRCHI TO-220F FDPF9N50NZ FAIRCHI TO-220F FDS4435 FAIRCHI SOP-8 FOD817C300 FAIRCHI DIP-4 FQPF13N50C FAIRCHI TO-220F FQPF2N60C FAIRCHI TO-220F FQPF6N80C FAIRCHI TO-220F HFA08SD60STRPBF VISHAY D-PAK HFA08TB60PBF VISHAY TO-220A HFA30TA60CSTRLPBF VISHAY TO-263 ICE2HS01G INFINEON DSS0-20 ICE2PCS01G INFINEON SOIC-8 ICE2PCS02 INFINEON DIP-8 ICE2PCS02G INFINEON SOIC-8 ICE2QS03G INFINEON SIOC-8 ICE3B0565J INFINEON DIP-8 ICE3PCS01G INFINEON SO-14 IKP20N60T INFINEON TO-220A IKW15N120H3 INFINEON TO-247 IKW15T120 INFINEON TO-247 IKW25N120H3 INFINEON TO-247 IKW25T120 INFINEON TO-247 IKW30N60H3 INFINEON TO-247A IKW30N60T INFINEON TO-247 IKW40N120H3 INFINEON TO-3P IKW40N60H3 INFINEON TO-247 IKW75N60H3 INFINEON TO-247 IPA50R140CP INFINEON TO-220 IPA50R190CE INFINEON TO-220 IPA50R199CP INFINEON TO-220F IPA50R280CE INFINEON TO-220F IPA50R299CP INFINEON TO-220F IPA50R380CE INFINEON TO-220F IPA50R520CP INFINEON TO-220F IPA50R800CE INFINEON TO22O IPA60R125C6 INFINEON TO-220F IPA60R160C6 INFINEON TO-220 IPA60R190P6 INFINEON TO-220 IPA60R250CP INFINEON TO-220F IPA60R280C6 INFINEON TO-220 IPA60R380E6 INFINEON TO-220F IPA65R190E6 INFINEON TO-220F IPB015N04NG INFINEON TO263-3 IPB022N04LG INFINEON TO-263 IPB042N10N3G INFINEON TO-263- IPB048N06LG INFINEON TO-263 IPB054N08N3G INFINEON TO-263 IPB200N25N3G INFINEON TO-263 IPD060N03LG INFINEON D-PAK IPD06N03LAG INFINEON TO-252 IPD320N20N3G INFINEON TO-252 IPD65R600E6 INFINEON TO-252 IPP023N04NG INFINEON TO-220 IPP024N06N3G INFINEON TO-220 IPP030N10N3G INFINEON TO-220 IPP032N06N3G INFINEON TO-220A IPP040N06N3G INFINEON TO-220 IPP041N04NG INFINEON TO-220A IPP042N03LG INFINEON TO-220 IPP057N08N3G INFINEON TO-220A IPP05CN10NG INFINEON TO-220 IPP075N15N3G INFINEON TO-220A IPP096N03LG INFINEON TO-220 IPP200N15N3G INFINEON TO-220 IPP200N25N3G INFINEON TO-220A IPP50R199CP INFINEON TO-220 IPP50R250CP INFINEON TO-220A IPP530N15N3G INFINEON TO-220 IPP60R099C6 INFINEON TO-220A IPP60R125CP INFINEON TO-220 IPP60R160C6 INFINEON TO-220 IPP60R165CP INFINEON TO-220 IPP60R190C6 INFINEON TO-220 IPP60R190E6 INFINEON TO-220 IPP60R199CP INFINEON TO-220 IPP60R380C6 INFINEON TO-220 IPP60R520E6 INFINEON TO-220 IPW60R070C6 INFINEON TO-247 IPW60R070P6 INFINEON TO-247 IPW60R099C6 INFINEON TO-247 IPW60R099CP INFINEON TO-247 IPW60R125CP INFINEON TO-247 IPW60R165CP INFINEON TO-247 IPW60R190C6 INFINEON TO-247 IPW60R190E6 INFINEON TO-247 IPW60R280C6 INFINEON TO-247 IPW65R041CFD INFINEON TO-247 IPW65R080CFD INFINEON TO-247 IR1166STRPBF IR S0-8 IR11682STRPBF IR SO-8 IR1168STRPBF IR SOP-8 IR2101STRPBF IR SO-8 IR2103STRPBF IR SO-8 IR2104STRPBF IR SOIC-8 IR2110PBF IR DIP-14 IR2113STRPBF IR SOIC-16 IR2166S IR SOIC-16 IR2301STRLPBF IR SO-8 IR2301STRPBF IR SO-8 IR4104SPBF IR D2-PAK IRF1010NSTRLPBF IR D2-PAK IRF1018EPBF IR TO-220A IRF1404PBF IR TO-220A IRF2804PBF IR TO-220A IRF2807PBF IR TO-220A IRF3205PBF IR TO-220A IRF3710PBF IR TO-220A IRF3808PBF IR TO-220A IRF4905PBF IR TO-220A IRF5210PBF IR TO-220A IRF530NPBF IR TO-220A IRF540NPBF IR TO-220A IRF620PBF VISHAY TO-220A IRF6217TRPBF IR S0-8 IRF624PBF VISHAY TO-220A IRF630NPBF IR TO-220A IRF634PBF VISHAY TO-220A IRF640NPBF IR TO-220A IRF640PBF VISHAY TO-220 IRF644PBF VISHAY TO-220A IRF6604TR1 IR SURFACE IRF6715MTRPBF IR SOT-263 IRF740PBF VISHAY TO-220A IRF7490TRPBF IR SO-8 IRF7821TRPBF IR SOP-8 IRF7832ZTRPBF IR SOP-8 IRF830APBF VISHAY TO-220A IRF830PBF VISHAY TO-220A IRF840APBF VISHAY TO-220 IRF840PBF VISHAY TO-220A IRF840STRLPBF VISHAY TO-263 IRF9530NPBF IR TO-220A IRF9530PBF VISHAY TO-220A IRF9540NPBF IR TO-220A IRF9Z24NPBF IR TO-220A IRF9Z34NPBF IR TO-220A IRFB20N50KPBF VISHAY TO-220A IRFB260NPBF IR TO-220 IRFB31N20DPBF IR TO-220A IRFB3206GPBF IR TO-220 IRFB3206PBF IR TO-220A IRFB3207PBF IR TO-220A IRFB3307PBF IR TO-220A IRFB4110GPBF IR TO-220 IRFB4110PBF IR TO-220A IRFB4115PBF IR TO-220A IRFB4410ZPBF IR TO-220A IRFB4610PBF IR TO-220A IRFB52N15DPBF IR TO-220A IRFB7440PBF IR TO-220A IRFB7446PBF IR TO-220A IRFBE30PBF VISHAY TO-220A IRFBG30PBF VISHAY TO-220A IRFD110PBF VISHAY DIP-4 IRFH5300TRPBF IR PQFN IRFHM830TRPBF IR FQPF IRFL110TRPBF VISHAY SOT-223 IRFL210TRPBF VISHAY SOT-223 IRFP064NPBF IR TO-247A IRFP140NPBF IR TO-247 IRFP150MPBF IR TO-247 IRFP150NPBF IR TO-247A IRFP240PBF VISHAY TO-247 IRFP250MPBF IR TO-247 IRFP250NPBF IR TO-247 IRFP260NPBF IR TO-247 IRFP350PBF VISHAY TO-247 IRFP4368PBF IR TO-247 IRFP4468PBF IR TO-247 IRFP450PBF VISHAY TO-247A IRFP4568PBF IR TO-247 IRFP460BPBF VISHAY TO-247 IRFP460LCPBF VISHAY TO-247 IRFP460PBF VISHAY TO-247A IRFP4668PBF IR TO-247 IRFP90N20DPBF IR TO-247A IRFP9140NPBF IR TO-247 IRFP9240PBF VISHAY TO-247 IRFR024NTRPBF IR D-PAK IRFR120NTRPBF IR D-PAK IRFR12N25DTRLP IR D-PAK IRFR220NTRPBF IR D-PAK IRFR5305TRPBF IR D-PAK IRFR9024NTRPBF IR D-PAK IRFR9220NPBF VISHAY TO-252 IRFR9220PBF VISHAY DPAK IRFR9220TRPBF VISHAY DPAK IRFS31N20DPBF IR D2-PAK IRFU430APBF VISHAY TO-251 IRFU9120NPBF IR TO-251 IRFZ14PBF VISHAY TO-220A IRFZ24NPBF IR TO-220A IRFZ34NPBF IR TO-220A IRFZ44NPBF IR TO-220A IRGPS40B120UPBF IR TO-247 IRL2203NPBF IR TO-220A IRLML2402TRPBF IR SOT-23 IRLML2502TRPBF IR SOT-23 IRLML2803TRPBF IR SOT-23 IRLML5103TRPBF IR SOT-23 IRLML5203TRPBF IR SOT-23 IRLML6302TRPBF IR SOT-23 IRLML6401TRPBF IR SOT-23 IRLML6402TRPBF IR SOT-23 IRLR024NTRPBF IR TO-252 IRLR120NTRPBF IR TO-252 IRLR2905TRPBF IR TO-252 IRLR3705ZPBF IR TO-252 IRLR8726TRPBF IR TO-252 IRLU024NPBF IR TO-251 IRS2168DSTRPBF IR SO-16 IRS21864STRPBF IR SOIC-14 ISL6752AAZA-T INTERSI SOP-16 ISL85415FRZ-T INTERSI DFN-12 ISL9R1560P2 FAIRCHI TO-220A KA7500CDTF FAIRCHI SOP-16 KA7805ETU FAIRCHI TO-220A KA7806ETU FAIRCHI TO-220 KA7808ETU FAIRCHI TO-220 KA7809ETU FAIRCHI TO-220 KA7812ETU FAIRCHI TO-220 KA7815ETU FAIRCHI TO-220 KSP94BU FAIRCHI TO-92 L4981A-1LF/ ST DIP-20 L4981AD013TR ST SO-20 L6561-4LF/ ST DIP-8 L6561D013TR ST SO-8 L6562ADTR ST SOIC-8 L6562DTR-5BLF/ ST SO-8 L6571AD013TR ST SOIC-8 L6591TR ST SO-16 L6599ADTR ST SO-16 L6599DTR-2LF/ ST SO-16 L7809CV 薄片 ST TO-220 L78L05ACUTR ST SOT-89 L7912CV(薄片) ST TO-220 L7915CV ST TO-220 LD1117ASTR ST SOT-223 LM2904DR2G ON SO-8 LM317MDT-TR ST TO-252 LM324DR2G ON SOP-14 LM324DT ST SOP-14 LM339DR2G ON SO-14 LM339DT ST SOP-14 LM358DR ti SO-8 LM358DR2G ON SO-8 LM393DR2G ON SO-8 LM393DT ST SOP-8 LM431BCM3X NS SOT23-3 MAX489EPD+ MAXIM DIP-14 MB10M 创品兴 DIP-4 MBR1100RLG ON DO-41 MBR1545CTG ON TO-220A MBR20200CTG ON TO-220A MBR2545CTG ON TO-220A MBR60200PT PANJIT TO-3P MBRA340T3G ON DO-214A MBRF20100CTG FIRST TO-220F MBRS130LT3G ON SMB MBRS260T3G ON SMB MBRS340T3G ON SMC-2 MC14538BDR2G ON SO-16 MC33262DR2G ON SO-8 MC33272ADR2G ON SO-8 MC78L05ACPRAG ON TO-92 MDD1502RH MAGNACH DPAK MDD4N60RH MAGNACH DPAK MDF12N50TH MAGNACH TO-220F MDF13N50BTH MAGNACH TO-220F MDF13N50TH MAGNACH TO-220F MDF13N65BTH MAGNACH TO-220F MDF18N50TH MAGNACH TO-220F MDF2N60TH MAGNACH TO-220F MDF4N60TH MAGNACH TO-220F MDF5N50FTH MAGNACH TO-220F MDF5N50TH MAGNACH TO-220F MDF8N60TH MAGNACH TO-220F MDF9N60TH MAGNACH TO-220F MDI4N60TH MAGNACH IPAK MDP9N50TH MAGNACH TO-220 MDS3652URH MAGNACH SOIC-8 MIC29300-5.0WT MICREL TO-220- MIC29302WT MICREL TO-220- MIC4424YM TR MICREL SO-8 MIC4427YMMTR MICREL MINI SO MIC44F19YML TR MICREL 8-MLF MJD112T4G ON TO-252 MJE172G ON TO-225 MJE182G ON TO-225 MJE243G ON TO-225 MJE253G ON TO-225- MJE340G ON TO-225 MJE350G ON TO-225 MMBT2222ALT1G ON SOT-23 MMBT2907ALT1G ON SOT-23 MMBT3904LT1G ON SOT-23 MMBT3906LT1G ON SOT-23 MMBT4401LT1G ON SOT-23 MMBT4403LT1G ON SOT-23 MMSD4148T1G ON SOD-123 MMSZ5241BT1G ON SOD-123 MOC3021M FAIRCHI DIP-6 MPSA42 ST TO-92 MUR1100ERLG ON DO-41 MUR120RLG ON DO-41 MUR1520G ON TO-220 MUR1540G ON TO-220A MUR1560G ON TO-220A MUR160RLG ON DO-41 MUR1620CTG ON TO-220A MUR1620CTRG ON TO-220- MUR1640CTG ON TO-220A MUR1660CTG ON TO-220A MUR180ERLG ON AXIAL L MUR220RLG ON DO-41 MUR260RLG ON DO-41 MUR3020WTG ON TO-247 MUR3020WTPBF VISHAY TO-247A MUR3040WTG ON TO-247 MUR3060WTG ON T0-247 MUR4100ERLG ON DO-201A MUR420RLG ON DO-201A MUR460RLG ON DO-201A MUR8100EG ON TO-220A MUR820G ON TO-220A MUR860 GD TO-220A MUR860G ON TO-220A MURA120T3G ON SMA MURA220T3G ON SMA MURD620CTT4G ON D-PAK MURS120T3G ON SMB MURS160T3G ON SMB MURS260T3G ON DO-214 MURS320T3G ON SMC-2 MURS340T3G ON SMC MURS360T3G ON SMC NC7WZ17P6X FAIRCHI SC70-6 NCP1014AP065G ON DIP-7 NCP1200D60R2G ON TO NCP1252ADR2G ON S0-8 NCP1271D65R2G ON SOIC-8 NCP1337DR2G ON SOIC-7 NCP1377BDR2G ON SO-8 NCP1377DR2G ON SOP-8 NCP1380BDR2G ON SOP-8 NCP1396ADR2G ON SO-16 NCP1397ADR2G ON SOP-16 NCP1608BDR2G ON SO-8 NCP1653ADR2G ON SO-8 NDF04N60ZG ON TO-220F NDF04N60ZH ON TO--220 NSS60201LT1G ON SOT-23 NTR4101PT1G ON SOT-23 PMBT2907A NXP SOT-23 PSMN005-75P NXP TO-220 PSMN2R0-30PL NXP TO-220A PZTA28 FAIRCHI SOT-223 RHRP1560 FAIRCHI TO-220A RHRP1560_F102 FSC TO--220 RJK03290PB RENESAS LFPAK S3D-E3/57T VISHAY DO-214A SCS210AGC ROHM TO-220A SFR9214TF FAIRCHI DPAK SG3525ADWR2G ON SOP-16 SG3525ANG ON DIP-16 SG3525AP ST SOP-16 SI7336ADP VISHAY SO-8 SIHG20N50C-E3 VISHAY TO-247 SN65HVD485ED TI SO-8 SPA06N80C3 INFINEON TO-220F SPA07N60C3 INFINEON TO-220F SPA08N80C3 INFINEON TO-220F SPA11N60C3 INFINEON TO-220F SPA11N65C3 INFINEON TO220F SPA11N80C3 INFINEON TO-220F SPA15N60CFD INFINEON TO-220F SPA17N80C3 INFINEON TO-220F SPA20N60C3 INFINEON TO-220F SPA21N50C3 INFINEON TO-220F SPB04N60C3 INFINEON TO-263 SPB11N60C3 INFINEON TO-263- SPB17N80C3 INFINEON D2PAK SPB18P06PG INFINEON D2PAK SPD02N60C3 INFINEON DPAK SPD02N80C3 INFINEON TO-252 SPD06N80C3 INFINEON TO-252 SPP02N60C3 INFINEON TO-220 SPP03N60C3 INFINEON TO-220A SPP04N80C3 INFINEON TO-220 SPP07N60C3 INFINEON TO-220A SPP11N60C3 INFINEON TO-220 SPP11N60CFD INFINEON TO-220A SPP11N65C3 INFINEON SPP11N80C3 INFINEON TO-220 SPP16N50C3 INFINEON TO-220 SPP17N80C3 INFINEON TO-220- SPP20N60C3 INFINEON TO-220 SPP21N50C3 INFINEON TO-220 SPP24N60C3 INFINEON TO-220A SPU01N60C3 INFINEON TO-251 SPU02N60C3 INFINEON TO-251 SPW11N80C3 INFINEON TO-247 SPW17N80C3 INFINEON TO-247 SPW20N60C3 INFINEON TO-247 SPW24N60C3 INFINEON TO-247 SPW32N50C3 INFINEON TO-247 SPW35N60C3 INFINEON TO-247 SPW47N60C3 INFINEON TO-247 SPW47N60CFD INFINEON TO-247 SS24T3G ON SMB SS26T3G ON SMB SSL4101T NXP SO-16 STB160N75F3 ST TO-263 STD10NM60N ST D-PAK STD11NM60N ST D-PAK STF20NM65N ST TO-220 STF22NM60N ST TO-220F STF26NM60N ST TO-220F STF28NM50N ST TO-220F STM32F103C8T6 ST LFQP-48 STM8S103F3P6 ST TSSOP-2 STP10NK60ZFP ST TO-220F STP12NM50FP ST TO-220F STP22NM60N ST TO-220A STP3NK80Z ST TO-220 STP4NK60ZFP ST TO-220F STP4NK80ZFP ST TO-220F STP5NK50Z ST TO-220A STP60NF06L ST TO-220 STP75NF75 ST TO-220 STP9NK50ZFP ST TO-220F STPS10LCD100CFP ST TO-220F STPS20150CFP ST TO-220F STPS20150CT ST TO-220A STPS20170CT ST TO-220 STPS2045CTC ST TO-220 STPS20H100CT ST TO-220A STPS20L60CG-TR ST TO STPS20L60CT ST TO-220A STPS20S100CT ST TO-220A STPS2L60A ST DO-214A STPS30120CT ST TO-220A STPS30150CT ST TO-220A STPS3045CT ST TO-220A STPS30H100CT ST TO-220A STPS30H60CFP ST TO-220F STPS30L30CT ST TO-220A STPS30L45CT ST TO-220A STPS30L45CW ST TO-247 STPS4045CW ST TO-247 STPS6045CW ST TO-247 STTH1002CT ST TO-220 STTH110/N ST DO-41 STTH15R06D ST TO-220A STTH1602CT ST TO-220A STTH2002CFP ST TO-220F STTH2002CT ST TO--220 STTH2003CFP ST TO-220F STTH302 ST DO-201A STTH30R04D ST TO-220A STTH3L06U ST DO-214A STTH4L06RL ST DO-201A STTH6003CW ST TO-247 STTH60RL03CW ST TO-247 STTH8L06FP ST TO-220F STTH8R06D ST TO-220A STTH8S06D ST TO-220A STTH8S06FP ST TO-220F STW19NM50N ST TO-247 STW26NM60N ST TO-247 STW45NM60 ST TO-247 STW9NK90Z ST TO-247 T3027 国产 SOT-23- TB6819FG TOSHIBA SSOP-16 TC4426ACOA MICROCH SOP-8 TDA4863-2G INFINEON SO-8 TEA1713T/N2 NXP SO-24 TEA1716T NXP SOP-24 TEA1733T/N1+118 NXP SO-8 TEA1751T/N1+518 NXP SO-16 TEA1761T/N2/DG+118 NXP SO-8 TEA1791T/N118 NXP SO-8 TEA1792TS NXP TSOP-6 TEA1795T/N1 NXP SOP-8 TIP31C ST TO-220 TK10A60D(QM) TOSHIBA TO-220F TK12A60U TOSHIBA TO-220F TK20D60T TOSHIBA TO-220 TK4A60D TOSHIBA TO-220 TK6A60D TOSHIBA TO-220F TL494CDR TI SO-16 TPS40057PWPR TI HTSSOP- TSM103WAIDT ST SO-8 UC2842BD1R2G ON SO-8 UC2843BD1R2G ON SO-8 UC2844BNG ON DIP-8 UC2845BD1R2G ON SO-8 UC2846DWTR TI SOP-16 UC2846N TI DIP-16 UC3825DWTR TI SOIC-16 UC3842BD1R2G ON SO-8 UC3843BD1013TR ST SO-8 UC3843BD1R2G ON SO-8 UC3843BNG ON DIP-8 UC3844BD1R2G ON SO-8 UC3844BNG ON DIP-8 UC3845BD1R2G ON SO-8 UC3845BN-3LF/ ST DIP-8 UC3854BDWTR TI SOP-16 UC3854BN TI DIP-16 UC3875N TI DIP-20 UCC27201DR TI 8-SON UCC27324DR TI SOIC-8 UCC27423DGNR TI SOIC-8 UCC27524DR TI SO-8 UCC28019ADR TI S0-8 UCC28051DR TI SOIC-16 UCC28061DR TI SOIC-16 UCC28070PWR TI TSSOP20 UCC28950PWR TI TSSOP-2 UCC2897APWR TI TSSOP-2 UCC28C43DR TI SO-8 UCC3818ADR TI SOIC-16 UCC3818APW TI SOIC-16 UCC3895N TI DIP-20 UCC3895PWG4 TI TSSOP-2 V40100C-E3/4W VISHAY TO-220 VIPER12ADIP-E ST DIP-8 VS-15ETH06PBF VISHAY TO-220A VS-15MQ040NTRPBF VISHAY SMA VS-19TQ015PBF VISHAY TO-220A VS-30WQ10FNTRPBF VISHAY D-PAK VS-32CTQ030STRLPBF VISHAY D2-PAK VS-42CTQ030PBF VISHAY TO-220A VS-42CTQ030STRLPBF VISHAY D2-PAK XL4013E1 XLSEMI TO-252 ZXGD3003E6TA DIODES SOT23-6 BP3316D BPS DIP-8 BP3319M BPS SOP-8 BP9833D BPS DIP-8 BP9912A BPS TO-92 BP3211 BPS SOP-8 BP2831A BPS SOP-8 BP2326A BPS SOP-8 BP1808 BPS SOP-8 BP9918A BPS SOT23 BP9918B BPS SOT23 BP1361 BPS SOT89-5 BP5136H BPS SOP-8 更多型号可联系 联系人:朱先生(只做原装正品)手机:13530770369 QQ:2898294465 |
相关推荐 |
BP86211D 12V/0.5A家用电器方案DEMO资料分析(电路原理图及BOM)
1491 浏览 0 评论
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
2509 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
1256 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
1717 浏览 0 评论
3527 浏览 3 评论
/9
GMT+8, 2025-12-8 19:01 , Processed in 0.749683 second(s), Total 55, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1597
