`这个是代码begindate_out<=tem_register(5); process(rst,clk) begin if rst='0'then tem_register<="000000"; counter<="000000"; in_counter<='0'; odd_bit <='0'; bit_temp<='0'; en_out<='0'; --各信号初始化 elsif(clk'event and clk ='1')then if in_en='1' then if counter="000000" then en_out<='0'; if ss='1' then tem_register<="111000"; --命令同步字产生 else tem_register<="000111"; --数据同步字产生 end if; elsif counter="100110"then if odd_bit='1'then tem_register(5)<='0'; else tem_register(5)<='1'; end if; elsif counter="100111" then if odd_bit='1'then tem_register(5)<='1'; else tem_register(5)<='0'; --奇偶校检的产生 end if; else tem_register(5 downto 1)<=tem_register(4 downto 0); if in_counter='0'then if date_in='1'then tem_register(0)<='1'; bit_temp<='0'; odd_bit<=not odd_bit; else tem_register(0)<='0'; bit_temp<='1'; --对输入数据进行编码 end if; else tem_register(0) <= bit_temp; end if; in_counter<=not in_counter; end if; counter<=counter+'1'; if counter="101000"then counter<="000000"; odd_bit <='0'; en_out<='1'; 这个是错误 vlog -work work -vopt E:/examples/yekai.v Model Technology ModelSim SE vlog 10.1a Compiler 2012.02 Feb 22 2012 ** Error: E:/examples/yekai.v(1): near "begin": syntax error, unexpected begin, expecting class 解决不了求帮忙 ` |
1个回答
大哥们给点建议啊
GMT+8, 2024-10-4 10:41 , Processed in 0.521940 second(s), Total 72, Slave 54 queries .
