`` 硬件平台:iTOP-4412精英版 ; iTOP-4412全能版 软件版本: Android4.4.4源码 iTOP-4412精英版 iTOP-4412全能版 硬件修改: ①精英版,将R27去掉(这是一个0欧姆电阻),在R28上焊上0欧姆电阻; ②全能版,将R97去掉(这是一个0欧姆电阻),在R98上焊上0欧姆电阻; 软件修改: 在内核源码中打开 arch/arm/mach-exynos/mach-itop4412.c文件 1. rst = EXYNOS4_GPC1(1),//RK30SDK_WIFI_GPIO_RESET_N,//RK30_PIN3_PD0, //MUST set to pin num in target system 修改为: // .rst = EXYNOS4_GPC1(1),//RK30SDK_WIFI_GPIO_RESET_N,//RK30_PIN3_PD0, //MUST set to pin num in target system .rst = EXYNOS4_GPZ(5), 2. //MT66XX SYSRST if(gpio_request(EXYNOS4_GPC1(1), "GPC1_1")) { printk(KERN_ERR "failed to request GPC1_1 for MT6620 SYSRST control "); } 修改为: //MT66XX SYSRST // if(gpio_request(EXYNOS4_GPC1(1), "GPC1_1")) // { // printk(KERN_ERR "failed to request GPC1_1 for MT6620 SYSRST control "); // } if(gpio_request(EXYNOS4_GPZ(5), "WIFI_PWDN")) { printk(KERN_ERR "failed to request GPC1_1 for MT6620 SYSRST control "); } 3. s3c_gpio_cfgpin(EXYNOS4_GPC1(0), S3C_GPIO_OUTPUT); s3c_gpio_cfgpin(EXYNOS4_GPC1(1), S3C_GPIO_OUTPUT); gpio_direction_output(EXYNOS4_GPC1(0), 0); gpio_direction_output(EXYNOS4_GPC1(1), 0); gpio_free(EXYNOS4_GPC1(0)); gpio_free(EXYNOS4_GPC1(1)); 修改为: s3c_gpio_cfgpin(EXYNOS4_GPC1(0), S3C_GPIO_OUTPUT); s3c_gpio_cfgpin(EXYNOS4_GPZ(5), S3C_GPIO_OUTPUT); gpio_direction_output(EXYNOS4_GPC1(0), 0); gpio_direction_output(EXYNOS4_GPZ(5), 0); gpio_free(EXYNOS4_GPC1(0)); gpio_free(EXYNOS4_GPZ(5)); 修改完之后,make clean一下,然后重新编译内核和android。这样就会解决wifi和can不能共用或者wifi和RFID不能共用的问题。 ``
10 个讨论
好贴要赞
写的很好,看过,多谢分享
你正在撰写讨论
1575 浏览 0 评论
5258 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9771 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2948 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2372 浏览 1 评论
浏览过的版块 |
GMT+8, 2025-12-14 21:28 , Processed in 0.847021 second(s), Total 56, Slave 48 queries .
2057
