我注意到使用通道21和22的34901A的DC电流测量功能的BLDL Pro Range / Ref下拉菜单包括Auto,10mA,100mA和1A范围,但没有提到+/-功能。
我想测量两种极性的电流。 这是工作还是我必须使用我自己用户提供的分流电阻配置为电压输入的通道? 谢谢 以上来自于谷歌翻译 以下为原文 I noticed that the BLDL Pro Range/Ref pulldown menu for the DC Current measurement function of the 34901A using channels 21 and 22 includes Auto, 10mA, 100mA, and 1A ranges but makes no mention of +/- capability. I want to measure current of both polarities. Will this work or must I use a channel configured as a voltage input with my own user supplied shunt resistor? Thanks |
3个回答
是的它可以测量+/-您不需要选择不同的范围或任何东西。
每个范围都是+/-范围,它在数据记录器中没有标记。 对不起任何困扰 以上来自于谷歌翻译 以下为原文 Yes it can measure +/- you don't need to select a different range or anything. Each range is a +/- range, it's just not labeled that way in datalogger. Sorry for any confustion |
我正在使用一个5mohm的分流电阻来测量34972A上1.5v电源的小电流。
我似乎有110A的boggus ADC结果。 我应该如何配置我的缩放增益以获得正确的结果。 我的设置是自动量程,当前结果应该高于1A。 如果(使用此分流电阻器)预期电流在mA范围内,如果它高于1A,则配置也应该不同吗? 以上来自于谷歌翻译 以下为原文 I am using a shunt resistor of 5mohm to measure small current on a 1.5v supply on the 34972A. I seem to have boggus ADC result of 110A. How should I configure my scaled gain to get the right result. My setting is on Autorange and current result should be above 1A. Also should configuration be different if (with this shunt resistor) expected current is in the mA range, than if it is above 1A? |
我不太清楚你在做什么。
如果使用外部分流电阻,则应测量该电阻上的压降,然后将该值除以已知的分流电阻值以计算电流。 您应该使用34972A上的直流电压功能。 使用M x + B缩放,B = 0并且M = 1 /(5e + 6)。 将5 Mohm与电路串联是对电路的巨大破坏,除非它有Gohms的电阻。 以上来自于谷歌翻译 以下为原文 I'm not quite clear on what you are doing. If you are using an external shunt resistor, you should be measuring the voltage drop across that resistor and then divide that value by the known shunt resistance value to calculate the current. You should be using the DC voltage function on the 34972A. Using the M x + B scaling, B=0 and M = 1/(5e+6). Putting 5 Mohm in series with your circuit is a huge disruption to the circuit unless it has Gohms of resistance. |
只有小组成员才能发言,加入小组>>
2100 浏览 1 评论
1856 浏览 1 评论
1714 浏览 5 评论
2582 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1561 浏览 4 评论
504浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1412浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2259浏览 0评论
GMT+8, 2024-4-26 22:42 , Processed in 1.141242 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
