几个星期前我买了一台U1253B(Ole dmultimeter)。它有一些奇怪的行为。当从欧姆切换到mV时,仪表读数将达到1200 mV,这个值会慢慢向上爬,直到显示OL。切换回欧姆
显示1000欧姆的电阻向上爬,直到仪表切换范围。 然后它在高阻力范围内非常快地到达OL。切换回mV会产生相同的行为。 我需要切换到伏特并返回到mV才能正常工作。从安培开关切换到脉冲发生器有时会使仪表处于安培模式。这几乎就像旋转开关有问题。 在这一系列的万用表之前,我曾经记得曾经读过这种问题。 以上来自于谷歌翻译 以下为原文 I got a U1253B (the Ole dmultimeter ) a few weeks ago. It has some strange behavior. When switching from ohms to mV the meter will read something like 1200 mV and this value will slowly creep upwards until it displays OL. Switching back to ohms shows a resistance in the order of 1000 ohm that creeps upwards until the meter switches ranges . then it goes very quickly to OL on the highes resistance range. Switching back to mV gives the same behavior. I need to switch to volts and back to mV before it behaves correctly. Switching form ampere to pulse generator sometimes leaves the meter in ampere mode. It's almost like the rotary switch has issues. I vaguele remeber having read this kind of problem before with this series of multimeters. |
1个回答
你好,不幸的是,听起来这个单位有缺陷。
我建议您将设备送回安捷伦。 希望该装置仍在保修期内。 如果您还有其他问题,请转发至bid_support@agilent.com 以上来自于谷歌翻译 以下为原文 Hello, Unfortunately it sounds like the unit is defective. I would advise you to send the unit back to Agilent. Hopefully the unit is still under warranty. if you have further questions please forward to bid_support@agilent.com |
只有小组成员才能发言,加入小组>>
2111 浏览 1 评论
1873 浏览 1 评论
1727 浏览 5 评论
2599 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1571 浏览 4 评论
519浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
374浏览 0评论
1434浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
285浏览 0评论
2267浏览 0评论
GMT+8, 2024-5-14 14:27 , Processed in 1.233004 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
