你好
我使用Avnet Spartana6lx75t评估板 它使用了主串行spi(4x)配置模式和jtag(间接spi配置模式) 每件事情都很好,但突然间,当我想使用这块板时,我注意到jtag无法识别FPGA和SPI闪存 幸运的是我没有在spi flash上清理工厂MCS文件,我将M0,M1引脚更改为主串口spi模式 然后我注意到fpga完成了led开始,它开始正常工作 它确保fpga没问题,我主板上的所有电源都可以 我做了什么来找出问题所在 1 - 检查设备管理器中的Xilinx u***程序驱动程序(platforme cable u***2) 2-将编程速度从6M改为3M,1.5M,750k 3 - 我的编程器绿色LED指示灯亮(VCC和GND连接正确) 4 - 我试过另一台PC XP和7 5-I尝试了3版ISE(13.1 13.4,14) 6-I用spartan3板改变fpga板,我看到jtage链与我的程序员正常工作 7-I检查我的jtag链是否确保电气关闭(有一个跳线,你可以扩展你的jtag链认为FMC连接器) 8-我在程序员和fpga板之间使用了两条不同的电缆(电缆没问题) 解决了所有嫌疑人之后,我的问题仍未解决 你知道问题可能是什么吗? 没有人有任何想法? 以上来自于谷歌翻译 以下为原文 Hello I use Avnet Spartana6lx75t evaluation board It used master serial spi (4x)configuration mode with jtag (indirect spi config mode ) Every thing was good but suddenly when I wanted to use this board I notices jtag couldn’t not be able to recognize FPGA and SPI flash fortunately I didn’t clean factory MCS file on the spi flash , I changed M0 ,M1 pin to master serial spi mode then I notice fpga done led became on, it started to work properly it made a sure that fpga is ok , all the power led on my board is ok too what I made to find out what the problem is 1-checking the Xilinx u*** program driver in device manger(platforme cable u***2) 2- Changed speed of programing from 6M to 3M, 1.5M ,750k 3-my programmer green led is on( VCC and GND is connected properly ) 4-I tried with another PCs XP and 7 5-I tried with 3 version of ISE (13.1 13.4 ,14) 6-I change the fpga board with an spartan3 board and I saw jtage chain is work properly with my programmer 7-I check my jtag chain to be sure is electrically close(there is a jumper that you can extend your jtag chain thought FMC connector ) 8- I used two different cable between my programmer and fpga board (cable is ok) After solving all suspects my problem is still not solved Do you know what problem could be No one have any idea ? |
1个回答
你好
只有小组成员才能发言,加入小组>>
2164 浏览 7 评论
2607 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2080 浏览 9 评论
3152 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2196 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
425浏览 1评论
1526浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2178浏览 0评论
511浏览 0评论
1644浏览 0评论
GMT+8, 2024-4-26 10:26 , Processed in 1.068167 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
