我用的液晶屏驱动IC是ILI9325,用原子哥的TFT显示实验是没问题的,只是对初始化有些疑问,请高人解答,不甚感激,如下:
疑问: LCD_WriteReg(0x00e7,0x0010); LCD_WriteReg(0x0093,0x0003); LCD_WriteReg(0x0097,0x0110); LCD_WriteReg(0x0098,0x0110); 看ILI9325的DATASHEET,里面是没有Re7,R93,R97,R98这几个命令的,不知原子哥用用在这里是何用意?请帮忙看一下,谢谢。 if(DeviceCode==0x9325||DeviceCode==0x9328)//ILI9325 { LCD_WriteReg(0x00e7,0x0010); LCD_WriteReg(0x0000,0x0001);//开启内部时钟 LCD_WriteReg(0x0001,0x0100); LCD_WriteReg(0x0002,0x0700);//电源开启 //LCD_WriteReg(0x0003,(1<<3)|(1<<4) ); //65K RGB //DRIVE TABLE(寄存器 03H) //BIT3=AM BIT4:5=ID0:1 //AM ID0 ID1 FUNCAtiON // 0 0 0 R->L D->U // 1 0 0 D->U R->L // 0 1 0 L->R D->U // 1 1 0 D->U L->R // 0 0 1 R->L U->D // 1 0 1 U->D R->L // 0 1 1 L->R U->D 正常就用这个. // 1 1 1 U->D L->R LCD_WriteReg(0x0003,(1<<12)|(3<<4)|(0<<3) );//65K LCD_WriteReg(0x0004,0x0000); LCD_WriteReg(0x0008,0x0207); LCD_WriteReg(0x0009,0x0000); LCD_WriteReg(0x000a,0x0000);//display setting LCD_WriteReg(0x000c,0x0001);//display setting LCD_WriteReg(0x000d,0x0000);//0f3c LCD_WriteReg(0x000f,0x0000); //电源配置 LCD_WriteReg(0x0010,0x0000); LCD_WriteReg(0x0011,0x0007); LCD_WriteReg(0x0012,0x0000); LCD_WriteReg(0x0013,0x0000); delay_ms(50); LCD_WriteReg(0x0010,0x1590); LCD_WriteReg(0x0011,0x0227); delay_ms(50); LCD_WriteReg(0x0012,0x009c); delay_ms(50); LCD_WriteReg(0x0013,0x1900); LCD_WriteReg(0x0029,0x0023); LCD_WriteReg(0x002b,0x000e); delay_ms(50); LCD_WriteReg(0x0020,0x0000); LCD_WriteReg(0x0021,0x013f); delay_ms(50); //伽马校正 LCD_WriteReg(0x0030,0x0007); LCD_WriteReg(0x0031,0x0707); LCD_WriteReg(0x0032,0x0006); LCD_WriteReg(0x0035,0x0704); LCD_WriteReg(0x0036,0x1f04); LCD_WriteReg(0x0037,0x0004); LCD_WriteReg(0x0038,0x0000); LCD_WriteReg(0x0039,0x0706); LCD_WriteReg(0x003c,0x0701); LCD_WriteReg(0x003d,0x000f); delay_ms(50); LCD_WriteReg(0x0050,0x0000); //水平GRAM起始位置 LCD_WriteReg(0x0051,0x00ef); //水平GRAM终止位置 LCD_WriteReg(0x0052,0x0000); //垂直GRAM起始位置 LCD_WriteReg(0x0053,0x013f); //垂直GRAM终止位置 LCD_WriteReg(0x0060,0xa700); LCD_WriteReg(0x0061,0x0001); LCD_WriteReg(0x006a,0x0000); LCD_WriteReg(0x0080,0x0000); LCD_WriteReg(0x0081,0x0000); LCD_WriteReg(0x0082,0x0000); LCD_WriteReg(0x0083,0x0000); LCD_WriteReg(0x0084,0x0000); LCD_WriteReg(0x0085,0x0000); LCD_WriteReg(0x0090,0x0010); LCD_WriteReg(0x0092,0x0000); LCD_WriteReg(0x0093,0x0003); LCD_WriteReg(0x0095,0x0110); LCD_WriteReg(0x0097,0x0000); LCD_WriteReg(0x0098,0x0000); //开启显示设置 LCD_WriteReg(0x0007,0x0133); LCD_WriteReg(0x0020,0x0000); LCD_WriteReg(0x0021,0x013f); } |
3个回答
注释掉后,在LCD显示实验也是正常的,但不知其它实验有无影响,因为9025DATASHEET是无这些命令的。。
没问题就用着吧.
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
758 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
483 浏览 1 评论
325 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
268 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
644 浏览 2 评论
1405浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
53浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
102浏览 3评论
创建了两个task如果一个优先级高 一个优先级低,高优先级的那个一直在做,什么时候会调度到低优先级的呢?
93浏览 3评论
65浏览 3评论
GMT+8, 2024-5-14 11:25 , Processed in 0.905938 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
