嗨,
我已经在运行Virtualbox映像的Centos 6.5上安装了Vivado Webpack 2014.4。 我已经使用“sudo xsetup”运行设置并选择安装电缆驱动程序。 安装过程中未插入USB电缆。 安装完成后,我插入USB线并设置Virtualbox以捕获设备。 在aLinux终端中,我通过运行检查USB电缆是否可检测到: [adminuser @ localhost~] $ lsu***Bus 001 Device 001:ID 1d6b:0001 Linux Foundation 1.1 root hubBus 001 Device 002:ID 03fd:0008 Xilinx,Inc。[adminuser @ localhost~] $ 但是,在Vivado - >硬件管理器 - >打开目标,我得到下面的屏幕。 我无法转到下一页。 有人可以提出什么问题吗? 谢谢,Neo 以上来自于谷歌翻译 以下为原文 Hi, I have installed Vivado Webpack 2014.4 on Centos 6.5 running in a Virtualbox image. I have run the setup using "sudo xsetup" and selected to install cable drivers as well. The USB cable is not plugged in during installation. After installation, I plugged in the USB cable and set Virtualbox to capture the device. In a Linux terminal, I checked the USB cable is detectable by running: [adminuser@localhost ~]$ lsu*** Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 002: ID 03fd:0008 Xilinx, Inc. [adminuser@localhost ~]$ However, in Vivado -> Hardware Manager -> open target, I get the screen below. I am unable to move to the next page. Can someone advise what is the problem? Thanks, Neo |
5个回答
嗨,
电缆是否连接到某个电路板? 你可以连接并尝试检测吗? 你能尝试通过IMPACT(如果有的话)连接并检查吗? 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Is the cable connected to some board? Can you connect and try to detect? Can you try connecting through IMPACT(if you have one) and check? Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.View solution in original post |
嗨,
电缆是否连接到某个电路板? 你可以连接并尝试检测吗? 你能尝试通过IMPACT(如果有的话)连接并检查吗? 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Is the cable connected to some board? Can you connect and try to detect? Can you try connecting through IMPACT(if you have one) and check? Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
嗨athandr,
是的,有效。 一旦我连接到电路板(通电),我就可以在扫描链中看到FPGA。 我明天会添加更新,看它是否也适用于petalinux。 谢谢, 新 以上来自于谷歌翻译 以下为原文 Hi athandr, Yeah that worked. Once I connect to a board (powered up), I can see the FPGA in the scan chain. I will add update tomorrow to see if it will work in petalinux also. Thanks, Neo |
嗨,
当然......很高兴听到...... 通常一旦连接电路板并检测到硬件管理器也应显示电缆和xilinx设备。 但是,这应该仅在支持的操作系统中有效。 查看支持的操作系统的发行说明。 如果有帮助,请将此标记为解决方案。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Sure...Glad to hear that... generally once you connect the board and detect the hardware manager should show the cable and the xilinx device also. This should however work in supported operating systems only. Check the release notes for the supported operating systems. please mark this as a solution in case it helped. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
嗨,
我也可以petalinux-boot到Linux登录界面。 谢谢。 新 以上来自于谷歌翻译 以下为原文 Hi , I can petalinux-boot to Linux login screen as well. Thanks. Neo |
只有小组成员才能发言,加入小组>>
2177 浏览 7 评论
2615 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2084 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2207 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
444浏览 1评论
1539浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2183浏览 0评论
513浏览 0评论
1656浏览 0评论
GMT+8, 2024-5-8 21:12 , Processed in 1.154295 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
