嗨,大家好。
当我在vivado 2013.4中运行xc7z015clg485时,它会报告 '错误:[通用17-69]命令失败:您的设备许可证'xc7z015'仅用于评估或试用目的。 此许可证禁用比特流创建。 请运行Xilinx许可证配置管理器以获取有关确定系统许可的功能和设备的帮助。 执行时 “write_bitstream -force system_wrapper.bit” “ 虽然我的PC上的许可证可以成功运行xc7z020和xc7z030但是它无法完成xc7z015的“生成比特流”。在license.xilinx.com中我找不到xc7z015的许可证,我在哪里可以获得许可证 对于xc7z015? 以上来自于谷歌翻译 以下为原文 Hi Every One. when I run xc7z015clg485 in vivado 2013.4,it reports 'ERROR: [Common 17-69] Command failed: Your license for device 'xc7z015' is setup for evaluation or trial purposes only. Bitstream creation is disabled for this license. Please run the Xilinx License Configuration Manager for assistance in determining which features and devices are licensed for your system. while executing"write_bitstream -force system_wrapper.bit "'Though the license in my PC can ran the xc7z020 and xc7z030 successfully, it can't finish the "generate bitstream" for xc7z015.In the license.xilinx.com I can't find the license for xc7z015,Where can I get the license for xc7z015? |
1 条评论
8个回答
嗨,
以下是此必需的补丁: 问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 在原帖中查看解决方案 ar58986_Vivado_2013_4_prelimin_rev1.zip 29 KB 以上来自于谷歌翻译 以下为原文 Hi, Here is the required patch for this: Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post ar58986_Vivado_2013_4_preliminary_rev1.zip 29 KB |
嗨,
这取决于您的许可证类型,请参考以下相关链接帮助并获得建议的新许可证。 http://forums.xilinx.com/t5/New-Users-Forum/WARNING-Bitgen-26-bitgen-only-supports-DRC-on-this-device/m-p/396781#M7488 Reagards, Vanitha。 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 Hi, It depends on your license type, please refer if below relavant link helps and get new license as proposed. http://forums.xilinx.com/t5/New-Users-Forum/WARNING-Bitgen-26-bitgen-only-supports-DRC-on-this-device/m-p/396781#M7488 Reagards, Vanitha. --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
感谢您的回复,但该链接无法解决我的问题。我的许可证成功生成比特流xc7z020和xc7z030,仅在xc7z015失败。
以上来自于谷歌翻译 以下为原文 Thank you for the reply,but the link does not solve my problem.my license generate bitstream xc7z020 and xc7z030 successfully,only fail at xc7z015. |
嗨,
您使用的是Vivado webpack许可吗? 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Are you using Vivado webpack license? Thanks -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,
以下是此必需的补丁: 问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- ar58986_Vivado_2013_4_prelimin_rev1.zip 29 KB 以上来自于谷歌翻译 以下为原文 Hi, Here is the required patch for this: Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- ar58986_Vivado_2013_4_preliminary_rev1.zip 29 KB |
请注意,一旦公布,该补丁将在答复记录58986中提供。
计划很快发布。 谢谢, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Please note that this patch will be available in the Answer Record 58986 once this is publically released. This is planned to be released shortly. Thanks, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
嗨,
这个问题在AR#58986中讨论过,现在已公开。 http://www.xilinx.com/support/answers/58986.htm 问候, Achutha -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- -------------- 以上来自于谷歌翻译 以下为原文 Hi, This issue is discussed in the AR #58986 and it is public now. http://www.xilinx.com/support/answers/58986.htm Regards, Achutha --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2178 浏览 7 评论
2616 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2211 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
448浏览 1评论
1540浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2184浏览 0评论
516浏览 0评论
1658浏览 0评论
GMT+8, 2024-5-13 15:22 , Processed in 1.481473 second(s), Total 107, Slave 86 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
