我想对使用过的Agilent 8753ES进行快速检查。
它有006和011选项,因此没有内置测试装置。有人能告诉我a)R接收器的最大输入电平是否满意? (前面板表示最小电平为-35 dBm)b)A和B接收器的最大输入电平,以确保满意的操作。 我知道损坏阈值是+20 dBm,但0.1 dB压缩点会低很多。 我猜测这些接收器的最大输入是否能够通过0.1 dB的压缩点来设置令人满意的操作,但可能并非如此。 另外,鉴于这是一款升级到006选项的3 GHz型号,信号源是6 GHz,还是3 GHz停止? 特别是,如果我想在3.5或4 GHz使用它,85046A是否可以作为85047A的廉价替代品,或者如果没有85047A中的倍频器,系统是否会在3.00000 GHz以上运行? PS,有趣的是将8753系列中耦合器的带宽与现有的耦合器进行比较。 Minicicuits或我能找到的任何人都没有什么能够覆盖如此宽的频率范围。 戴夫 以上来自于谷歌翻译 以下为原文 I want to do a quick sanity check on a used Agilent 8753ES. It has option 006 and 011, so has no test set built in. Can anyone tell me a) The maximum input levels to the R receiver for satisfactory operation? (The front panel says the minimum level is -35 dBm) b) The maximum input level to the A and B receivers for satisfactory operation. I know the damage thresholds are +20 dBm, but the 0.1 dB compression points are going to be a lot lower. I am guessing the maximum inputs to these receivers for satisfactory operation is going to be set by the 0.1 dB compression point, but maybe that is not so. Also, given this is a 3 GHz model that has been upgraded to option 006, will the source go to 6 GHz, or does it stop at 3 GHz? In particular, if I wanted to use it at 3.5 or 4 GHz, would an 85046A do as a cheap substitute for an 85047A, or would the system simply not operate above 3.00000 GHz without the frequency doubler in an 85047A? PS, it is interesting to compare the bandwidth of the couplers in the 8753 series to those available today. There is nothing from Minicicuits, or anyone I can find, that covers such a wide frequency range. Dave |
6个回答
要迁移,sourceId:117545 以上来自于谷歌翻译 以下为原文 to be migrated, sourceId: 117545 |
dB / dB可能是一个错字,如果我没记错的话应该是dB / 10 dB,但规格是基于参考指南中的动态精度曲线。 如果您进行被动测量,则校准后不应更改功率,R通道的线性度无关紧要。 但是,低于5 dBm端口功率(在分离器电路20 dB损耗后约为-15 dB R信道功率),几乎没有线性误差。 R通道的填充比A / B大约10 dB,因此等效电平为0 dBm测试端口(约-16 dB A / B功率电平)。 以上来自于谷歌翻译 以下为原文 dB/dB is probably a typo, it should be dB/10 dB if I remember correctly, but the spec is actualy based on the dynamic accuracy curve found in the ref guide. If you are making passive measurements, you shouldn't change power after calibration and the linearity of the R channel doesn't matter. However, below 5 dBm port power (about -15 dB R channel power after the 20 dB loss of the splitter circuit), there is virtually no linearity error. The R channel is padded about 10 dB more than the A/B, so the equivalent level would be 0 dBm test port (about -16 dB A/B power level). |
脑洞大赛9 发表于 2018-10-23 16:19 > {quote:title = Dr_joel写道:} {quote}> dB / dB可能是一个错字,如果我没记错的话应该是dB / 10 dB,但规格是基于参考指南中的动态精度曲线实际的 。 嗨Joel,>如果您正在进行被动测量,则校准后不应更改功率,R通道的线性度无关紧要。 但是,低于5 dBm端口功率(在分离器电路20 dB损耗后约为-15 dB R信道功率),几乎没有线性误差。 你有没有忘记那里的“m”,R输入端口的平均值为-15 dBm,几乎没有线性误差,或者我误解了你? 我很欣赏如果功率没有改变,R通道的线性度无关紧要。 > R通道的填充比A / B大约10 dB,因此等效电平为0 dBm测试端口(约-16 dB A / B功率电平)。 再说一遍,你在A和B接收器端口上说-16 dBm几乎没有线性误差吗? 戴夫 以上来自于谷歌翻译 以下为原文 > {quote:title=Dr_joel wrote:}{quote} > dB/dB is probably a typo, it should be dB/10 dB if I remember correctly, but the spec is actualy based on the dynamic accuracy curve found in the ref guide. Hi Joel, > If you are making passive measurements, you shouldn't change power after calibration and the linearity of the R channel doesn't matter. However, below 5 dBm port power (about -15 dB R channel power after the 20 dB loss of the splitter circuit), there is virtually no linearity error. Did you forget an "m" there, and mean -15 dBm on the R-input port with virtually no linearity error, or have I mis-understood you? I appreciate if the power is not changed, the linearity of the R-channel doesn't matter. > The R channel is padded about 10 dB more than the A/B, so the equivalent level would be 0 dBm test port (about -16 dB A/B power level). Again, are you saying -16 dBm on the A and B receiver ports with virtually no linearity error? Dave |
60user7 发表于 2018-10-23 16:37 戴夫,如果你看一下在线服务手册,性能测试部分将回答你关于所有三个端口的线性误差和幅度和相位压缩误差的所有问题。 85046中的耦合器具有高于3.4 GHz的弱点,因此您的测量结果将是有问题的。 85047测试装置基本上添加了标准装置中的端口耦合器。 对于B和C型号,它有一个倍增器。 问候,戴夫 以上来自于谷歌翻译 以下为原文 Dave, If you look at the on line service manual, in the performance test section will answer all your questions concerning linearity error and compression error in both amplitude and phase for all three ports. The couplers in the 85046 have weakness above 3.4 GHz therefore you measurements will be questionable. The 85047 test set basically added the port couplers found in a standard unit. It had a doubler in it for the B and C models. Regards, Dave |
小佳99 发表于 2018-10-23 16:46 > {quote:title = dhamilton写道:} {quote}> 85046中的耦合器在3.4 GHz以上有弱点,因此您的测量结果会有问题。 85047测试装置基本上添加了标准装置中的端口耦合器。 对于B和C型号,它有一个倍增器。 >在85046中Dave the -bridges-(让我们在这里准确)最初设计用于1.3 GHz 8505,后来进行了扩展以获得3 GHz的性能。 所以它们完全超过3 Ghz。 85047A的桥接器采用全新设计,运行速度可达6 GHz。 对于第一版RF PNA,它们被拉伸至9 Ghz。 后来,进行了重大的重新设计,将它们拉得更远,首先是20 GHz(对于PNA-L),然后是26.5 GHz(对于PNA和PNA-X中的Ref桥)。 所有这些都是桥梁,而不是耦合器。 85046桥是等值的惠斯通,具有6 dB的损耗和耦合。 85047桥是不等腿的小麦,具有16 dB耦合和1.57 dB(标称)损耗。 有关桥梁的更多细节,你知道在哪里看......(第83页显示了85047桥梁的精美图片)。 以上来自于谷歌翻译 以下为原文 > {quote:title=dhamilton wrote:}{quote} > The couplers in the 85046 have weakness above 3.4 GHz therefore you measurements will be questionable. The 85047 test set basically added the port couplers found in a standard unit. It had a doubler in it for the B and C models. > Dave the -bridges- (let's be precise here) in the 85046 were originally designed for the 1.3 GHz 8505, and later stretched to get 3 GHz performance. So they fall apart completely above 3 Ghz. The bridges in teh 85047A are of a completely new design, and operate well to 6 GHz. They were stretched to 9 Ghz for the first version of the RF PNA. Later, there was a significant redesign that stretched them much farther, first to 20 GHz (for the PNA-L) and then to 26.5 GHz (for the Ref Bridge in the PNA and PNA-X). All of these are bridges, not couplers. The 85046 bridges are equal value wheatstone with 6 dB loss and couplng. The 85047 bridges are unequal leg wheatsones with 16 dB coupling and 1.57 dB (nominal) loss. For more detail on the bridges, you know where to look... (pg 83 shows a nice picture of the 85047 bridge). |
只有小组成员才能发言,加入小组>>
2100 浏览 1 评论
1856 浏览 1 评论
1714 浏览 5 评论
2582 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1561 浏览 4 评论
504浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1412浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2259浏览 0评论
GMT+8, 2024-4-26 18:58 , Processed in 1.014291 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
