你好,
我使用的是ISE 13。1(3月):Xilinx_ISE_DS_Lin_13.1_O.40d.1.1& ISE 13。1(4月):Xilinx_ISE_DS_Update_13.1_O.40e.2.1 Linux平台:CentOS 5.6(RHEL 5.6克隆) 运行物理综合...... FATAL_ERROR:1 :: 78:1.3 - 物理综合失败。 流程将终止。 有关此问题的技术支持,请通过http://www.xilinx.com/support连接此项目打开WebCase。 /home/cad/xilinx/ISE13.1/ISE_DS/ISE/bin/lin64/unwrapped/map:符号查找错误:/home/cad/xilinx/ISE13.1/ISE_DS/ISE//lib/lin64/libXst2_Core.so :undefined symbol:_ZN5boost7archive6detail17basic_oserializerD2Evmake [2]:*** [map]错误127 这似乎从昨天开始发生。 任何建议都将被评估。 谢谢 麦克风 以上来自于谷歌翻译 以下为原文 Hello, I am using ISE 13.1 (March): Xilinx_ISE_DS_Lin_13.1_O.40d.1.1 & ISE 13.1 (April): Xilinx_ISE_DS_Update_13.1_O.40e.2.1 Linux Platform: CentOS 5.6 (RHEL 5.6 Clone) Running physical synthesis... FATAL_ERROR:1::78:1.3 - Physical Synthesis Failed. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support. /home/cad/xilinx/ISE13.1/ISE_DS/ISE/bin/lin64/unwrapped/map: symbol lookup error: /home/cad/xilinx/ISE13.1/ISE_DS/ISE//lib/lin64/libXst2_Core.so: undefined symbol: _ZN5boost7archive6detail17basic_oserializerD2Evmake[2]: *** [map] Error 127 This seems to have started happening since yesterday. Any suggestions will be apprciated. Thanks Mike |
2个回答
嗨迈克,
在错误消息的正文中已经给出了一个建议: ...请通过http://www.ilinx.com/support所附的此项目打开一个WebCase .... 谢谢, 叶夫根 以上来自于谷歌翻译 以下为原文 Hi Mike, One suggestion is already given in the body of the error message: ...please open a WebCase with this project attached at http://www.xilinx.com/support.... Thanks, Evgeni |
是的,请打开一个网页,查看致命错误。
作为临时解决方法,请尝试禁用-register_duplication,-logic_opt或两者。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Yes, please open a webcase for the Fatal Error to be investigated. As a temporary work around, try disabling -register_duplication, -logic_opt or both. ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2178 浏览 7 评论
2615 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2084 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2207 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
445浏览 1评论
1539浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2183浏览 0评论
515浏览 0评论
1657浏览 0评论
GMT+8, 2024-5-9 22:30 , Processed in 1.289270 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
