TI论坛
直播中
王艳
7年用户 1276经验值
私信 关注
[问答]
AIC3254在“PurePath Wireless Configurator”中I2C配置寄存器P1_R9设置不成功是怎么回事?
  • 我们自己板子上,通过CC8530的“PurePath Wireless Configurator”(PWC)软件,I2C配置AIC3254寄存器,但唯独Page 1 / Register 9: Output Driver Power Control Register - 0x01 / 0x09 (P1_R9)设置为3F,AIC3254EVM-U CS中读出该寄存器的值为3C。但AIC3254EVM-U CS中可以正确设置该寄存器,即写入3F,读出也是3F,PWC中代码前后的寄存器都可以正确设置。不知什么原因?代码如下:
    # PIN RESET
    p Reset 1     # Release the reset pin
    # RESET
    w 30 00 00    # Select register page 0
    w 30 01 01    # I2C reset
    # CLOCK SETtiNGS
    w 30 0B 81    # Power up the NDAC divider with value 1
    w 30 0C 82    # Power up the MDAC divider with value 2
    w 30 0D 00    # Program OSR for DAC to 128 (MSB)
    w 30 0E 80    # Program OSR for DAC to 128 (LSB)
    w 30 12 81    # Power up the NADC divider with value 1
    w 30 13 82    # Power up the MADC divider with value 2
    w 30 14 80    # Program OSR for ADC to 128
    # DIGITAL INTERFACE
    w 30 1B 00    # I2S, 16-bit, BCLK and WCLK are inputs
    # PROCESSING BLOCK USAGE
    w 30 3C 08    # Select DAC processing block PRB_P8
    w 30 3D 01    # Select ADC processing block PRB_R1
    # ANALOG POWER SUPPLY
    w 30 00 01    # Select register page 1
    w 30 01 08    # Disable internal crude AVDD before powering up the internal AVDD LDO
    w 30 02 01    # Enable internal analog LDO, analog blocks powered
    w 30 0A 40    # Common mode set to 0.75V
    # MICPGA DELAY, REFERENCE CHARGING AND HEADPHONE DE-POP
    w 30 47 31    # MICPGA startup delay is 3 ms
    w 30 7B 01    # Reference charging time is 40 ms
    w 30 14 65    # HP driver power-up: 50 ms soft routing step time, 5.0 time constants, 6k resistance
    # AUDIO ROUTING
    w 30 0C 0C    # HPL routing: Left channel's DAC reconstruction filter's positive terminal
    w 30 0D 0C    # HPR routing: Right channel's DAC reconstruction filter's positive terminal
    w 30 0E 0A    # LOL routing: Left channel's DAC reconstruction filter output
    w 30 0F 0A    # LOR routing: Right channel's DAC reconstruction filter output
    w 30 00 00
    w 30 3F D4
    w 30 00 01
    w 30 34 40    # IN1L is routed to Left MICPGA with 10K resistance
    w 30 36 40    # CM1L is routed to Left MICPGA via CM1L with 10K resistance
    w 30 37 40    # IN1R is routed to Right MICPGA with 10K resistance
    w 30 39 40    # CM1R is routed to Right MICPGA via CM1R with 10K resistance
    w 30 09 3F
    w 30 00 00
    w 30 40 00
    # DC FILTER LEFT CHANNEL
    w 30 00 08    # Select register page 8
    w 30 18 7F    #                n0 + n1 * z^-1
    w 30 19 FF    #     H(z) = ----------------------
    w 30 1A 00    #               2^23 - d1 * z^-1
    w 30 1C 80    #
    w 30 1D 01    # The constants are defined as
    w 30 1E 00    #     n0 = 32767 * 256
    w 30 20 7F    #     n1 = -32767 * 256
    w 30 21 FC    #     d1 = 32768 * 256 * (1- 2^13)
    w 30 22 00    # This gives a filter with cutoff at approx. 1 Hz
    # DC FILTER RIGHT CHANNEL
    w 30 00 09    # Select register page 9
    w 30 20 7F    #                n0 + n1 * z^-1
    w 30 21 FF    #     H(z) = ----------------------
    w 30 22 00    #               2^23 - d1 * z^-1
    w 30 24 80    #
    w 30 25 01    # The constants are defined as
    w 30 26 00    #     n0 = 32767 * 256
    w 30 28 7F    #     n1 = -32767 * 256
    w 30 29 FC    #     d1 = 32768 * 256 * (1- 2^13)
    w 30 2A 00    # This gives a filter with cutoff at approx. 1 Hz
    谢谢!
回帖(2)
冯栋
2024-11-7 18:00:03
由于我没有EVM板,我无法帮你重现,既然可以使用AIC3254EVM-U CS修改,可能是软件的BUG。
举报
klysa
2024-11-8 09:16:00
这个问题可能是由于I2C通信协议中的时序问题或者寄存器值的写入顺序问题导致的。以下是一些建议和可能的解决方案:
1. 检查I2C时序:确保I2C通信时序符合AIC3254的规格要求。时序问题可能导致寄存器值写入不正确。
2. 检查寄存器值的写入顺序:确保在写入P1_R9寄存器之前,已经正确设置了寄存器页(Page 1)。如果寄存器页设置不正确,可能导致寄存器值写入不正确。
3. 检查PWC软件设置:确保PWC软件中的I2C配置正确,包括时钟频率、地址等。错误的配置可能导致寄存器值写入不正确。
4. 检查硬件连接:确保AIC3254和CC8530之间的I2C连接正确,包括线路连接和电源供应。硬件连接问题可能导致寄存器值写入不正确。
5. 检查代码逻辑:检查代码逻辑,确保在写入P1_R9寄存器之前,没有其他寄存器的写入操作影响了P1_R9寄存器的值。
6. 尝试使用不同的I2C库或驱动:如果可能,尝试使用不同的I2C库或驱动,以排除软件问题。
7. 检查AIC3254的数据手册:仔细阅读AIC3254的数据手册,确保对寄存器的写入操作符合规格要求。
通过以上步骤,希望能帮助您找到问题的原因并解决。如果问题仍然存在,建议联系AIC3254和CC8530的技术支持,以获取更专业的帮助。
举报
更多回帖
