综合技术交流
直播中
汪潇潇
7年用户 827经验值
私信 关注
[问答]
MM32SPIN系统单片机高级定时器输入捕获没办法进入TIM_CC_IRQH中断的原因?
MM32SPIN系统单片机高级定时器输入捕获  没办法进入tiM_CC_IRQH中断void Remote_1(void)
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);//使能GPIOB时钟
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_7);//GPIOB4复用为TIM1
        //GPIO
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//下拉输入
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
void Remote_Init(uint16_t period, uint8_t prescaler)
        TIM_TimeBaseInitTypeDef TIM_StructInit;
        TIM_ICInitTypeDef  TIM_ICInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
        TIM_TimeBaseStructInit(&TIM_StructInit);
        TIM_StructInit.TIM_Period = period;
        TIM_StructInit.TIM_Prescaler = prescaler;
        TIM_StructInit.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_StructInit.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_StructInit.TIM_RepetitionCounter = 0;
        TIM_TimeBaseInit(TIM1, &TIM_StructInit);
        //TIM1输入捕获参数设置
        TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;//CC2S=01 选择输入端 IC2映射到TI1上
        TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;//上升沿捕获
        TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;//映射到TI1上
        TIM_ICInitStructure.TIM_ICFilter = 0x0;
        TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;//配置输入分频,不分频
        TIM_ICInit(TIM1, &TIM_ICInitStructure);
        TIM_ARRPreloadConfig(TIM1, ENABLE);
        TIM_ITConfig(TIM1,TIM_IT_CC2 | TIM_IT_Update, ENABLE);
        TIM_CtrlPWMOutputs(TIM1, ENABLE);
    TIM_Cmd(TIM1, ENABLE);
void Remote_2(void)
    NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_InitStructure.NVIC_IRQChannel = TIM1_BRK_UP_TRG_COM_IRQn;//定时中断3
        NVIC_InitStructure.NVIC_IRQChannelPriority = 1;//中断优先级
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//使能中断
        NVIC_Init(&NVIC_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQn;//定时中断3
        NVIC_InitStructure.NVIC_IRQChannelPriority = 0;//中断优先级
void TIM1_BRK_UP_TRG_COM_IRQHandler(void)
        if(TIM_GetITStatus(TIM1, TIM_IT_Update) != RESET)//溢出中断
                LED3_TOGGLE();
                TIM_ClearITPendingBit(TIM1, TIM_IT_Update);  //清除TIMx更新中断标志
void TIM1_CC_IRQHandler(void)
        if(TIM_GetITStatus(TIM1, TIM_IT_CC2) != RESET)//捕获中断
                LED2_TOGGLE();
                TIM_ClearITPendingBit(TIM1, TIM_IT_CC2);  //清除TIMx更新中断标志
回帖(1)
陈勇
2024-7-26 17:06:37
在分析MM32SPIN系统单片机高级定时器输入捕获无法进入TIM_CC_IRQH中断的原因之前,我们先了解一下相关的硬件和软件配置。以下是可能的原因和解决方案:
1. **中断使能未开启**:确保在初始化定时器时,已经使能了输入捕获中断。例如,使用`TIM_ITConfig(TIMx, TIM_IT_CC1, ENABLE)`来使能输入捕获中断。
2. **NVIC配置问题**:检查是否已经正确配置了NVIC(嵌套向量中断控制器),以便在中断发生时能够正确响应。使用`NVIC_Init()`函数配置相应的中断通道。
3. **输入捕获模式配置错误**:确保定时器的输入捕获模式已经正确配置。使用`TIM_ICInit()`函数配置输入捕获模式,例如`TIM_ICInitTypeDef TIM_ICInitStructure;`。
4. **GPIO配置问题**:检查GPIO的配置是否正确。根据您的代码片段,您已经配置了GPIOB的第4脚为复用功能,并将其配置为TIM1的输入。确保这个配置是正确的,并且与您的硬件设计相匹配。
5. **定时器时钟配置问题**:确保定时器的时钟已经正确配置。使用`RCC_APB2PeriphClockCmd()`或`RCC_APB1PeriphClockCmd()`(取决于您的定时器在哪个APB总线上)来使能定时器时钟。
6. **中断服务函数未正确编写**:确保您的中断服务函数已经正确编写,并且已经注册到中断向量表中。例如,使用`void TIM1_CC_IRQHandler(void)`作为中断服务函数,并在初始化代码中使用`NVIC_SetVectorTable()`将其注册到中断向量表中。
7. **硬件问题**:如果以上软件配置都正确,但问题仍然存在,可能是硬件连接问题。检查输入捕获引脚的硬件连接,确保没有短路或断路。
8. **软件逻辑问题**:检查您的代码逻辑,确保在触发输入捕获中断之前,定时器已经正确启动。使用`TIM_Cmd(TIMx, ENABLE)`来启动定时器。
综上所述,要解决MM32SPIN系统单片机高级定时器输入捕获无法进入TIM_CC_IRQH中断的问题,需要从硬件配置、软件配置和代码逻辑等方面进行排查。希望这些建议能帮助您找到问题所在并解决它。
举报
更多回帖
