CAN_HandleTypeDef hcan1;
CAN_HandleTypeDef hcan2;
/* CAN1 init func
tion */
void MX_CAN1_Init(void)
/* USER CODE BEGIN CAN1_Init 0 */
/* USER CODE END CAN1_Init 0 */
/* USER CODE BEGIN CAN1_Init 1 */
/* USER CODE END CAN1_Init 1 */
hcan1.Instance = CAN1;
hcan1.Init.Prescaler = 9;
hcan1.Init.Mode = CAN_MODE_NORMAL;
hcan1.Init.SyncJumpWidth = CAN_SJW_1TQ;
hcan1.Init.TimeSeg1 = CAN_BS1_13TQ;
hcan1.Init.TimeSeg2 = CAN_BS2_2TQ;
hcan1.Init.TimeTriggeredMode = DISABLE;
hcan1.Init.AutoBusOff = ENABLE;
hcan1.Init.AutoWakeUp = ENABLE;
hcan1.Init.AutoRetransmission = DISABLE;
hcan1.Init.ReceiveFifoLocked = DISABLE;
hcan1.Init.TransmitFifoPriority = DISABLE;
if (HAL_CAN_Init( hcan1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN CAN1_Init 2 */
/* USER CODE END CAN1_Init 2 */
/* CAN2 init function */
void MX_CAN2_Init(void)
/* USER CODE BEGIN CAN2_Init 0 */
/* USER CODE END CAN2_Init 0 */
/* USER CODE BEGIN CAN2_Init 1 */
/* USER CODE END CAN2_Init 1 */
hcan2.Instance = CAN2;
hcan2.Init.Prescaler = 9;
hcan2.Init.Mode = CAN_MODE_NORMAL;
hcan2.Init.SyncJumpWidth = CAN_SJW_1TQ;
hcan2.Init.TimeSeg1 = CAN_BS1_13TQ;
hcan2.Init.TimeSeg2 = CAN_BS2_2TQ;
hcan2.Init.TimeTriggeredMode = DISABLE;
hcan2.Init.AutoBusOff = ENABLE;
hcan2.Init.AutoWakeUp = ENABLE;
hcan2.Init.AutoRetransmission = DISABLE;
hcan2.Init.ReceiveFifoLocked = DISABLE;
hcan2.Init.TransmitFifoPriority = DISABLE;
if (HAL_CAN_Init( hcan2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN CAN2_Init 2 */
/* USER CODE END CAN2_Init 2 */
static uint32_t HAL_RCC_CAN1_CLK_ENABLED=0;
void HAL_CAN_MspInit(CAN_HandleTypeDef* canHandle)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(canHandle->Instance==CAN1)
/* USER CODE BEGIN CAN1_MspInit 0 */
/* USER CODE END CAN1_MspInit 0 */
/* CAN1 clock enable */
HAL_RCC_CAN1_CLK_ENABLED++;
if(HAL_RCC_CAN1_CLK_ENABLED==1){
__HAL_RCC_CAN1_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
/**CAN1 GPIO Configuration
PD0 ------> CAN1_RX
PD1 ------> CAN1_TX
GPIO_InitStruct.Pin = GPIO_PIN_0;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOD, GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_1;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
__HAL_AFIO_REMAP_CAN1_3();
/* CAN1 interrupt Init */
HAL_NVIC_SetPriority(CAN1_RX0_IRQn, 6, 0);
HAL_NVIC_EnableIRQ(CAN1_RX0_IRQn);
/* USER CODE BEGIN CAN1_MspInit 1 */
/* USER CODE END CAN1_MspInit 1 */
else if(canHandle->Instance==CAN2)
/* USER CODE BEGIN CAN2_MspInit 0 */
/* USER CODE END CAN2_MspInit 0 */
/* CAN2 clock enable */
__HAL_RCC_CAN2_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/**CAN2 GPIO Configuration
PB5 ------> CAN2_RX
PB6 ------> CAN2_TX
GPIO_InitStruct.Pin = GPIO_PIN_5;
HAL_GPIO_Init(GPIOB, GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_6;
__HAL_AFIO_REMAP_CAN2_ENABLE();
/* CAN2 interrupt Init */
HAL_NVIC_SetPriority(CAN2_RX1_IRQn, 6, 0);
HAL_NVIC_EnableIRQ(CAN2_RX1_IRQn);
/* USER CODE BEGIN CAN2_MspInit 1 */
/* USER CODE END CAN2_MspInit 1 */
void HAL_CAN_MspDeInit(CAN_HandleTypeDef* canHandle)
/* USER CODE BEGIN CAN1_MspDeInit 0 */
/* USER CODE END CAN1_MspDeInit 0 */
/* Peripheral clock disable */
HAL_RCC_CAN1_CLK_ENABLED--;
if(HAL_RCC_CAN1_CLK_ENABLED==0){
__HAL_RCC_CAN1_CLK_DISABLE();
PD0 ------> CAN1_RX
PD1 ------> CAN1_TX
HAL_GPIO_DeInit(GPIOD, GPIO_PIN_0|GPIO_PIN_1);
/* CAN1 interrupt Deinit */
HAL_NVIC_DisableIRQ(CAN1_RX0_IRQn);
/* USER CODE BEGIN CAN1_MspDeInit 1 */
/* USER CODE END CAN1_MspDeInit 1 */
/* USER CODE BEGIN CAN2_MspDeInit 0 */
/* USER CODE END CAN2_MspDeInit 0 */
__HAL_RCC_CAN2_CLK_DISABLE();
PB5 ------> CAN2_RX
PB6 ------> CAN2_TX
HAL_GPIO_DeInit(GPIOB, GPIO_PIN_5|GPIO_PIN_6);
/* CAN2 interrupt Deinit */
HAL_NVIC_DisableIRQ(CAN2_RX1_IRQn);
/* USER CODE BEGIN CAN2_MspDeInit 1 */
/* USER CODE END CAN2_MspDeInit 1 */
//CAN1 初始化
void bsp_can1_init(void)
/*过滤器 CAN1过滤器范围0-13 ,CAN2过滤器范围14-27*/
CAN_FilterTypeDef sFilterConfig;
sFilterConfig.FilterBank = 0;
sFilterConfig.FilterMode = CAN_FILTERMODE_IDMASK;
sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT;
sFilterConfig.FilterIdHigh = 0x0000;
sFilterConfig.FilterIdLow = 0x0000;
sFilterConfig.FilterMaskIdHigh = 0x0000;
sFilterConfig.FilterMaskIdLow = 0x0000;
sFilterConfig.FilterFIFOAssignment = CAN_RX_FIFO0;
sFilterConfig.FilterActivation = ENABLE;
sFilterConfig.SlaveStartFilterBank = 14;
if (HAL_CAN_ConfigFilter( hcan1, sFilterConfig) != HAL_OK)
/* Filter configuration Error */
Error_Handler();
// FilterConfig_Scale32_Null( hcan1,0);//不过滤
// FilterConfig_Scale32_IdMask_StandardIdOnly( hcan1,1,(uint16_t *)StdIdArray);//单标准ID
// Filter_Scale32_IdMask_ExtendIdOnly( hcan1,2,(uint32_t *)ExtIdArray);//单扩展ID
// Filter_Scale32_IdMask_StandardId_ExtendId_Mix( hcan1,3,(uint16_t *)StdIdArray,(uint32_t *)ExtIdArray);//标准ID + 扩展ID
/*波特率重新调整*/
CAN_Baud_Process(250, hcan1);
/* Start the CAN peripheral */
if (HAL_CAN_Start( hcan1) != HAL_OK)
/* Start Error */
Error_Handler();
/* Activate CAN RX notification */
if (HAL_CAN_ActivateNotification( hcan1, CAN_IT_RX_FIFO0_MSG_PENDING) != HAL_OK)
/* Notification Error */
Error_Handler();
// /* Activate CAN BUSOFF notification ###################################*/
// if (HAL_CAN_ActivateNotification( hcan1, CAN_IT_BUSOFF) != HAL_OK)
// /* Notification Error */
// Error_Handler();
// /* Activate CAN TX notification */
// if (HAL_CAN_ActivateNotification( hcan1, CAN_IT_TX_MAILBOX_EMPTY) != HAL_OK)
// Error_Handler();
//CAN2 初始化
void bsp_can2_init(void)
sFilterConfig.FilterBank = 14;
sFilterConfig.FilterFIFOAssignment = CAN_RX_FIFO1;
Error_Handler();
// FilterConfig_Scale32_Null( hcan2,14);//不过滤
// FilterConfig_Scale32_IdMask_StandardIdOnly( hcan1,15,(uint16_t *)StdIdArray);//单标准ID
// Filter_Scale32_IdMask_ExtendIdOnly( hcan1,16,(uint32_t *)ExtIdArray);//单扩展ID
// Filter_Scale32_IdMask_StandardId_ExtendId_Mix( hcan1,17,(uint16_t *)StdIdArray,(uint32_t *)ExtIdArray);//标准ID + 扩展ID
/*波特率重新调整*/
CAN_Baud_Process(250, hcan2);
if (HAL_CAN_Start( hcan2) != HAL_OK)
/* Start Error */
Error_Handler();
if (HAL_CAN_ActivateNotification( hcan2, CAN_IT_RX_FIFO1_MSG_PENDING) != HAL_OK)
Error_Handler();
// if (HAL_CAN_ActivateNotification( hcan2, CAN_IT_BUSOFF) != HAL_OK)
// Error_Handler();
// if (HAL_CAN_ActivateNotification( hcan2, CAN_IT_TX_MAILBOX_EMPTY) != HAL_OK)
// Error_Handler();
* @brief Rx FIFO 0 full callback.
* @param hcan pointer to a CAN_HandleTypeDef structure that contains
* the configuration information for the specified CAN.
* @retval None
void HAL_CAN_RxFifo0MsgPendingCallback(CAN_HandleTypeDef *hcan)
//CAN1 -FIFO0 接收处理
if (HAL_CAN_GetRxMessage(hcan, CAN_RX_FIFO0, bsp_can1.RxMessage, bsp_can1.RxData) != HAL_OK) {
Error_Handler();
uint32_t r_std_id = bsp_can1.RxMessage.StdId;
uint32_t r_ext_id = bsp_can1.RxMessage.ExtId;
printf("CAN1->0x%03X, 0x%08X, %02X, %02X, %02X, %02X, %02X, %02X, %02X, %02Xrn",
r_std_id, r_ext_id,
bsp_can1.RxData[0], bsp_can1.RxData[1], bsp_can1.RxData[2], bsp_can1.RxData[3],
bsp_can1.RxData[4], bsp_can1.RxData[5], bsp_can1.RxData[6], bsp_can1.RxData[7]);
bsp_can1.RxMessage.StdId = 0;
bsp_can1.RxMessage.ExtId = 0;
* @brief Rx FIFO 1 message pending callback.
* @retval None
void HAL_CAN_RxFifo1MsgPendingCallback(CAN_HandleTypeDef *hcan)
//CAN2 -FIFO1 接收处理
if (HAL_CAN_GetRxMessage(hcan, CAN_RX_FIFO1, bsp_can2.RxMessage, bsp_can2.RxData) != HAL_OK) {
Error_Handler();
uint32_t r_std_id = bsp_can2.RxMessage.StdId;
uint32_t r_ext_id = bsp_can2.RxMessage.ExtId;
printf("CAN2->0x%03X, 0x%08X, %02X, %02X, %02X, %02X, %02X, %02X, %02X, %02Xrn",
r_std_id, r_ext_id,
bsp_can2.RxData[0], bsp_can2.RxData[1], bsp_can2.RxData[2], bsp_can2.RxData[3],
bsp_can2.RxData[4], bsp_can2.RxData[5], bsp_can2.RxData[6], bsp_can2.RxData[7]);
bsp_can2.RxMessage.StdId = 0;
bsp_can2.RxMessage.ExtId = 0;
/* NOTE : This function Should not be modified, when the callback is needed,
the HAL_CAN_RxFifo1MsgPendingCallback could be implemented in the
user file
* @brief CAN1 发送数据
* @param StdId 标准ID,不使用则传0
* @param ExtId 扩展ID,不使用则传0
* @param pData 发送数据
* @param Len 发送长度
uint8_t CAN1_SendNormalData(uint16_t StdId,uint32_t ExtId, uint16_t Len)
HAL_StatusTypeDef HAL_RetVal;
uint8_t FreeTxNum = 0;
bsp_can1.TxMessage.StdId = StdId;
bsp_can1.TxMessage.ExtId = ExtId;
if(ExtId)bsp_can1.TxMessage.IDE = CAN_ID_EXT;
else bsp_can1.TxMessage.IDE = CAN_ID_STD;
bsp_can1.TxMessage.TransmitGlobalTime = DISABLE;
bsp_can1.TxMessage.RTR = CAN_RTR_DATA;//使用标准帧
if(Len > 8 || !Len)return 1;
bsp_can1.TxMessage.DLC = Len;
FreeTxNum = HAL_CAN_GetTxMailboxesFreeLevel( hcan1);
while(0 == FreeTxNum)
osDelay(1);
if(0 == FreeTxNum)
return 2;
HAL_RetVal = HAL_CAN_AddTxMessage( hcan1, bsp_can1.TxMessage, bsp_can1.TxData, bsp_can1.TxMailbox);
if(HAL_RetVal != HAL_OK)
return 2;
return 0;
/*** @brief CAN2 发送数据
* @param pData 发送数据
* @param Len 发送长度
uint8_t CAN2_SendNormalData(uint16_t StdId,uint32_t ExtId, uint16_t Len)
bsp_can2.TxMessage.StdId = StdId;
bsp_can2.TxMessage.ExtId = ExtId;
if(ExtId)bsp_can2.TxMessage.IDE = CAN_ID_EXT;
else bsp_can2.TxMessage.IDE = CAN_ID_STD;
bsp_can2.TxMessage.TransmitGlobalTime = DISABLE;
bsp_can2.TxMessage.RTR = CAN_RTR_DATA;//使用标准帧
bsp_can2.TxMessage.DLC = Len;
FreeTxNum = HAL_CAN_GetTxMailboxesFreeLevel( hcan2);
osDelay(1);
if(0 == FreeTxNum)
return 2;
HAL_RetVal = HAL_CAN_AddTxMessage( hcan2, bsp_can2.TxMessage, bsp_can2.TxData, bsp_can2.TxMailbox);
return 2;
return 0;
主函数:
void myTask02_Fun(void *argument)
/* USER CODE BEGIN myTask02_Fun */
/* Infinite loop */
for(;;)
//printf("test...rn");
FAN_PR_4_Toggle();
++bsp_can1.TxData[0];
CAN1_SendNormalData(0x11,0x0,4);
++bsp_can2.TxData[0];
CAN2_SendNormalData(0x22,0x0,8);
osDelay(1000);
/* USER CODE END myTask02_Fun */
经过调试发现CAN2发送的数据都卡在发送邮箱里面;
配置过滤器的时候,使用CAN1句柄,也是接收不到数据。
通过查看寄存器,发送错误寄存器ESR的LEC值一直是101 (显性位错),在发送是TEC的值是变化的,接收数据时REC的值也是变化的。
现在不知道如何处理,就只有CAN2有这问题,CAN1的收发是完全没问题的。
