用的新唐m483芯片,想对700k左右的信号通过pwm触发进行eadc采样通过pdma输出,后续用来做带通滤波和傅里叶变化。
求大佬指点,adc的采样率部分如何设置才能满足700k信号采集的需要,看到官方文档中提到最高采样率可以达到5.14M,。
#include
#include "NuMicro.h"
#include "arm_math.h"
#define PLL_CLOCK 192000000
#define ADC_SAMPLE_RATE 6
#define SAMPLE_NUM 512
#define NUM_ADC_CHANNELS 1
#define PDMA_CH 2
int16_t adcValues[SAMPLE_NUM] = {0};
float32_t fft_out[SAMPLE_NUM];
uint32_t ifft_flag = 0;
uint32_t i;
float32_t DSPCal
time;
uint32_t g_u32SampleModuleNum = 0;
float32_t output[SAMPLE_NUM];
float32_t temp_output[SAMPLE_NUM];
float32_t amplitudes[SAMPLE_NUM/2];
float32_t frequencies[SAMPLE_NUM/2];
volatile uint32_t AdcInput;
float32_t AdcInput_float;
uint32_t status;
float32_t *inputF32, *outputF32;
float32_t firStateF32[SAMPLE_NUM+5];
arm_rfft_fast_instance_f32 S;
arm_fir_instance_f32 iir_inst;
volatile uint32_t g_u32AdcIntFlag;
volatile uint32_t g_u32AdcIntFlag, g_u32COVNUMFlag = 0;
volatile uint32_t g_u32IsTestOver = 0;
void SYS_Init(void)
PF->MODE = ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
CLK_SetCoreClock(PLL_CLOCK);
CLK->PCLKDIV = (CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2);
CLK_EnableModuleClock(UART0_MODULE);
CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1));
CLK_EnableModuleClock(EPWM0_MODULE);
CLK_SetModuleClock(EPWM0_MODULE, CLK_CLKSEL2_EPWM0SEL_PCLK0, 0);
CLK_EnableModuleClock(EADC_MODULE);
CLK_SetModuleClock(EADC_MODULE, 0, CLK_CLKDIV0_EADC(8));
CLK_EnableModuleClock(PDMA_MODULE);
SYS->GPB_MFPH = ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk);
SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
PB->MODE = ~(GPIO_MODE_MODE6_Msk | GPIO_MODE_MODE7_Msk);
SYS->GPB_MFPL = ~(SYS_GPB_MFPL_PB6MFP_Msk | SYS_GPB_MFPL_PB7MFP_Msk);
SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB6MFP_EADC0_CH6 | SYS_GPB_MFPL_PB7MFP_EADC0_CH7);
GPIO_DISABLE_DIGITAL_PATH(PB, BIT7|BIT6);
SYS->GPB_MFPL = (SYS->GPB_MFPL (~SYS_GPB_MFPL_PB5MFP_Msk));
SYS->GPB_MFPL |= SYS_GPB_MFPL_PB5MFP_EPWM0_CH0;
void UART0_Init()
UART_Open(UART0, 115200);
void EPWM0_Init()
uint16_t TimeBASE=1000;
EPWM_ConfigOutputChannel(EPWM0, 0, TimeBASE, 50);
EPWM_Start(EPWM0, EPWM_CH_0_MASK);
EPWM_EnableADCTrigger(EPWM0,0,EPWM_TRG_ADC_EVEN_COMPARE_DOWN);
EPWM_SET_OUTPUT_LEVEL(EPWM0, BIT0, EPWM_OUTPUT_HIGH, EPWM_OUTPUT_LOW, EPWM_OUTPUT_NOTHING, EPWM_OUTPUT_NOTHING);
EPWM_EnableOutput(EPWM0, BIT0);
void PDMA_Init()
PDMA_Open(PDMA,BIT2);
PDMA_SetTransferCnt(PDMA,PDMA_CH, PDMA_WIDTH_16, SAMPLE_NUM);
PDMA_SetTransferAddr(PDMA,PDMA_CH, (uint32_t) EADC->DAT[g_u32SampleModuleNum], PDMA_SAR_FIX, (uint32_t)adcValues, PDMA_DAR_INC);
PDMA_SetTransferMode(PDMA,PDMA_CH, PDMA_EADC0_RX, FALSE, 0);
PDMA_SetBurstType(PDMA,PDMA_CH, PDMA_REQ_SINGLE, PDMA_BURST_4);
PDMA_EnableInt(PDMA,PDMA_CH, PDMA_INT_TRANS_DONE);
NVIC_EnableIRQ(PDMA_IRQn);
void ReloadPDMA()
void PDMA_IRQHandler(void)
status = PDMA_GET_INT_STATUS(PDMA);
if(status PDMA_INTSTS_ABTIF_Msk)
if(PDMA_GET_ABORT_STS(PDMA) PDMA_ABTSTS_ABTIF2_Msk)
g_u32IsTestOver = 2;
PDMA_CLR_ABORT_FLAG(PDMA,PDMA_ABTSTS_ABTIF2_Msk);
else if(status PDMA_INTSTS_TDIF_Msk)
if(PDMA_GET_TD_STS(PDMA) PDMA_TDSTS_TDIF2_Msk)
g_u32IsTestOver = 1;
PDMA_CLR_TD_FLAG(PDMA,PDMA_TDSTS_TDIF2_Msk);
else
printf("unknown interrupt !!n");
void GetAdcData()
EADC_Open(EADC, EADC_CTL_DIFFEN_SINGLE_END);
EADC_ConfigSampleModule(EADC, g_u32SampleModuleNum, EADC_EPWM0TG0_TRIGGER,2);
if (SYS->CSERVER SYS_CSERVER_VERSION_Msk) /* M480LD */
EADC_ENABLE_SAMPLE_MODULE_PDMA(EADC, 1<
