我正在尝试建立一个 CAN 中断基础
通信系统,似乎从未调用过 IRQ 处理程序。
调试器通过 CAN1_TX 然后返回到主函数,因此永远不会调用 IRq。
USART 输出:
[2020-12-08_21:19:01:191] 50 岁之后。
[2020-12-08_21:19:01:191]SYSCLK:100000000Hz
[2020-12-08_21:19:01:191]HCLK:50000000Hz
[2020-12-08_21:19:01:191]PCLK1:25000000Hz
[2020-12-08_21:19:01:191]PCLK2:50000000Hz
[2020-12-08_21:19:01:191] TX 呼叫之前。
[2020-12-08_21:19:01:191] TX 呼叫后。
[2020-12-08_21:19:01:191] 程序结束。
主要的:
- #include "main.h"
- #include
- #include
- tiM_HandleTypeDef htim2;
- UART_HandleTypeDef huart2;
- FDCAN_HandleTypeDef CAN1;
- void SystemClock_Config_HSE(uint16_t Clock_Freq);
- static void MX_GPIO_Init(void);
- static void MX_USART2_UART_Init(void);
- static void MX_TIM2_Init(void);
- void GPIO_Init(void);
- void CAN1_Init(void);
- void CAN1_TX(void);
- void CAN1_RX(void);
- void CAN_Filter_Config(void);
- void HAL_FDCAN_TxEventFifoCallback(FDCAN_HandleTypeDef *hfdcan, uint32_t BufferIndexes);
- void HAL_FDCAN_RxFifo0Callback(FDCAN_HandleTypeDef *hfdcan, uint32_t RxFifo0ITs);
- void HAL_FDCAN_ErrorCallback(FDCAN_HandleTypeDef *hfdcan);
- char *user_data = "Hello world, I made it using STM32 ARM Cortex M7!rn";
- char msg[100];
- int main(void)
- HAL_Init();
- SystemClock_Config_HSE(SYS_CLOCK_FREQ_50_MHZ);
- MX_GPIO_Init();
- GPIO_Init();
- MX_USART2_UART_Init();
- MX_TIM2_Init();
- user_data = " AFTER 50.rn";
- if (HAL_UART_Transmit(&huart2,(uint8_t*)user_data,strlen(user_data), HAL_MAX_DELAY) != HAL_OK)
- Error_Handler();
- memset(msg,0,sizeof(msg));
- sprintf(msg,"SYSCLK : %ldHzrn",HAL_RCC_GetSysClockFreq());
- HAL_UART_Transmit(&huart2,(uint8_t*)msg,strlen(msg),HAL_MAX_DELAY);
- sprintf(msg,"HCLK : %ldHzrn",HAL_RCC_GetHCLKFreq());
- sprintf(msg,"PCLK1 : %ldHzrn",HAL_RCC_GetPCLK1Freq());
- sprintf(msg,"PCLK2 : %ldHzrn",HAL_RCC_GetPCLK2Freq());
- CAN1_Init();
- CAN_Filter_Config();
- if (HAL_FDCAN_Start(&CAN1) != HAL_OK)
- Error_Handler();
- if (HAL_FDCAN_ConfigInterruptLines(&CAN1, FDCAN_IT_TX_COMPLETE | FDCAN_IT_RX_BUFFER_NEW_MESSAGE, FDCAN_INTERRUPT_LINE0) != HAL_OK)
- Error_Handler();
- if (HAL_FDCAN_ActivateNotification(&CAN1, FDCAN_IT_TX_COMPLETE | FDCAN_IT_TX_FIFO_EMPTY | FDCAN_IT_TX_EVT_FIFO_FULL | FDCAN_IT_TX_EVT_FIFO_NEW_DATA | FDCAN_IT_BUS_OFF | FDCAN_IT_RX_BUFFER_NEW_MESSAGE | FDCAN_IT_RX_FIFO0_NEW_MESSAGE | FDCAN_IT_RX_FIFO1_NEW_MESSAGE, FDCAN_TX_BUFFER0 | FDCAN_TX_BUFFER1) != HAL_OK)
- Error_Handler();
- user_data = " BEFORE TX CALL.rn";
- Error_Handler();
- CAN1_TX();
- user_data = " After TX call.rn";
- Error_Handler();
- uint8_t Loop_Count = 0;
- while (Loop_Count < 5)
- Loop_Count++;
- user_data = " END of program.rn";
- Error_Handler();
- RCC_OscInitTypeDef OSC_Init;
- RCC_ClkInitTypeDef clk_init;
- uint8_t FLatency = 0;
- HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
- __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE0);
- while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
- OSC_Init.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- OSC_Init.HSEState = RCC_HSE_ON;
- OSC_Init.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
- OSC_Init.PLL.PLLState = RCC_PLL_ON;
- OSC_Init.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- switch(Clock_Freq)
- case SYS_CLOCK_FREQ_50_MHZ:
- OSC_Init.PLL.PLLM = 1;
- OSC_Init.PLL.PLLN = 25;
- OSC_Init.PLL.PLLP = 2;
- OSC_Init.PLL.PLLQ = 3;
- OSC_Init.PLL.PLLR = 2;
- clk_init.ClockType = RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK |
- RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2 |
- RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
- clk_init.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- clk_init.SYSCLKDivider = RCC_SYSCLK_DIV2;
- clk_init.AHBCLKDivider = RCC_HCLK_DIV1;
- clk_init.APB3CLKDivider = RCC_APB3_DIV1;
- clk_init.APB1CLKDivider = RCC_APB1_DIV2;
- clk_init.APB2CLKDivider = RCC_APB2_DIV1;
- clk_init.APB4CLKDivider = RCC_APB4_DIV1;
- FLatency = FLASH_ACR_LATENCY_0WS;
- break;
- default:
- return;
- if (HAL_RCC_OscConfig(&OSC_Init) != HAL_OK)
- Error_Handler();
- if(HAL_RCC_ClockConfig(&clk_init, FLatency) != HAL_OK)
- Error_Handler();
- HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
- CAN1.Instance = FDCAN1;
- CAN1.Init.FrameFormat = FDCAN_FRAME_CLASSIC;
- CAN1.Init.Mode = FDCAN_MODE_EXTERNAL_LOOPBACK; // EXTERNAL Means FDCAN treats its own transmitted messages as received
- // messages
- CAN1.Init.AutoRetransmission = ENABLE;
- CAN1.Init.TransmitPause = DISABLE;
- CAN1.Init.ProtocolException = DISABLE;
- // Setting values for 500k bps
- CAN1.Init.NominalPrescaler = 3;
- CAN1.Init.NominalSyncJumpWidth = 1;
- CAN1.Init.NominalTimeSeg1 = 2;
- CAN1.Init.NominalTimeSeg2 = 2;
- CAN1.Init.DataPrescaler = 3;
- CAN1.Init.DataSyncJumpWidth = 1;
- CAN1.Init.DataTimeSeg1 = 2;
- CAN1.Init.DataTimeSeg2 = 2;
- CAN1.Init.MessageRAMOffset = 0;
- CAN1.Init.StdFiltersNbr = 10;
- CAN1.Init.ExtFiltersNbr = 0;
- CAN1.Init.RxBuffersNbr = 64;
- CAN1.Init.RxFifo0ElmtsNbr = 64;
- CAN1.Init.RxFifo0ElmtSize = FDCAN_DATA_BYTES_32;
- CAN1.Init.RxFifo1ElmtsNbr = 64;
- CAN1.Init.RxFifo1ElmtSize = FDCAN_DATA_BYTES_32;
- CAN1.Init.RxBufferSize = FDCAN_DATA_BYTES_32;
- CAN1.Init.TxBuffersNbr = 32;
- CAN1.Init.TxEventsNbr = 32;
- CAN1.Init.TxFifoQueueElmtsNbr = 32;
- CAN1.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
- CAN1.Init.TxElmtSize = FDCAN_DATA_BYTES_16;
- if (HAL_FDCAN_Init(&CAN1) != HAL_OK)
- Error_Handler();
- FDCAN_TxHeaderTypeDef TX_Header;
- uint8_t CAN_Msg_Ptr[5] = {'H', 'E', 'L', 'L', 'R'};
- TX_Header.DataLength = 1;
- TX_Header.Identifier = 0x7DF;
- TX_Header.IdType = FDCAN_STANDARD_ID;
- TX_Header.TxFrameType = FDCAN_DATA_FRAME;
- TX_Header.ErrorStateIndicator = FDCAN_ESI_ACTIVE;
- TX_Header.BitRateSwitch = FDCAN_BRS_OFF;
- TX_Header.FDFormat = FDCAN_CLASSIC_CAN;
- //TX_Header.TxEventFifoControl = FDCAN_NO_TX_EVENTS;
- TX_Header.TxEventFifoControl = FDCAN_STORE_TX_EVENTS;
- TX_Header.MessageMarker = 0x00;
- if( HAL_FDCAN_AddMessageToTxBuffer(&CAN1, &TX_Header, CAN_Msg_Ptr, FDCAN_TX_BUFFER0) != HAL_OK)
- Error_Handler();
- //while(HAL_FDCAN_IsTxBufferMessagePending(&CAN1, FDCAN_TX_BUFFER0));
- FDCAN_FilterTypeDef CAN1_Filter_Init;
- CAN1_Filter_Init.IdType = FDCAN_STANDARD_ID;
- CAN1_Filter_Init.FilterIndex = 0;
- CAN1_Filter_Init.FilterType = FDCAN_FILTER_MASK;
- CAN1_Filter_Init.FilterConfig = FDCAN_FILTER_TO_RXBUFFER;
- CAN1_Filter_Init.FilterID1 = 0x0000;
- CAN1_Filter_Init.FilterID2 = 0x0000;
- CAN1_Filter_Init.RxBufferIndex = 0;
- CAN1_Filter_Init.IsCalibrationMsg = 0;
- if (HAL_FDCAN_ConfigFilter(&CAN1, &CAN1_Filter_Init) != HAL_OK)
- Error_Handler();
- user_data = " FIFO CAN Message transmitted.rn";
- Error_Handler();
- void HAL_FDCAN_TxBufferCompleteCallback(FDCAN_HandleTypeDef *hfdcan, uint32_t BufferIndexes)
- user_data = " Buffer CAN Message transmitted.rn";
- Error_Handler();
- FDCAN_RxHeaderTypeDef RX_Header;
- uint8_t Rcvd_msg[5];
- if( HAL_FDCAN_GetRxMessage(&CAN1, FDCAN_RX_FIFO0, &RX_Header, Rcvd_msg) != HAL_OK)
- Error_Handler();
- sprintf(msg,"Message received : %srn",Rcvd_msg);
- void HAL_FDCAN_RxBufferNewMessageCallback(FDCAN_HandleTypeDef *hfdcan)
- if( HAL_FDCAN_GetRxMessage(&CAN1, FDCAN_RX_BUFFER0, &RX_Header, Rcvd_msg) != HAL_OK)
- Error_Handler();
- user_data = "CAN BUS ERRORrn";
- HAL_UART_Transmit(&huart2,(uint8_t*)user_data,strlen(user_data), HAL_MAX_DELAY);
- while(1)
- HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_14);
- HAL_Delay(500);
- HAL_Delay(500);
