ST意法半导体
直播中
cherry1989
13年用户 1021经验值
擅长:嵌入式技术
私信 关注
[问答]
NUCLEO F207ZG TIM6定时器使用CMSIS延迟怎么办
我需要在不使用 HAL 库的情况下执行一些任务。我正在使用 CMSIS。
首先,我设置了一个带定时器的闪烁 LED。
我按照附图对时钟进行了编程。tiM6 的源时钟应为 60 MHz,但 LED 的行为与 30 MHz 相同。它以一半的速度闪烁。
当我预计有 500 毫秒的延迟时,LED 会保持亮起(或熄灭)1 秒。我不明白这个因素 2 从何而来。
我究竟做错了什么?
这是代码
  • #include
  • #include "STM32f2xx.h"
  • #if !defined(__SOFT_FP__) && defined(__ARM_FP)
  •   #warning "FPU is not initialized, but the project is compiling for an FPU. Please initialize the FPU before use."
  • #endif
  • static void SystemClock_Config();
  • void TIM6Config (void);
  • void Delay_us (uint16_t us);
  • void Delay_ms (uint16_t ms);
  • int main(void)
  •    // uint32_t i;
  •         SystemClock_Config();
  •     //NVIC_SetPriority
  •     RCC->AHB1ENR |= RCC_AHB1ENR_GPIOBEN;
  •     GPIOB->MODER |= 0x01 << GPIO_MODER_MODER14_Pos;
  •     GPIOB->OSPEEDR |= 0x01 << 29;
  •     //uart (not yet implemented, to be completed)
  •     //ENABLE PORT D AND USART 3
  •     RCC->AHB1ENR |= RCC_AHB1ENR_GPIODEN;
  •     RCC->APB1ENR |= RCC_APB1ENR_USART3EN;
  •     GPIOD->AFR[1] |= (7<<0); //ALTERNATE PD8
  •     GPIOD->AFR[1] |= (7<<4); //ALTERNATE PD9
  •     GPIOD->OSPEEDR |= (3<<16) | (3<<18); //HIGH SPEED FOR PD8 AND PD9
  •         TIM6Config ();
  •         /* Loop forever */
  •         while(1) {
  •                 GPIOB->ODR ^= GPIO_ODR_ODR_14;
  •                 Delay_ms (500);
  • #define PLL_M_SETTING 8
  • #define PLL_N_SETTING 240
  • #define PLL_P_SETTING 0 //PLLP = 2
  •         // Start HSE in Bypass Mode
  •         RCC->CR |= RCC_CR_HSEBYP;
  •         RCC->CR |= RCC_CR_HSEON;
  •         while(!(RCC->CR & RCC_CR_HSERDY));
  •         RCC->CFGR |= RCC_CFGR_HPRE_DIV1;
  •         RCC->CFGR |= RCC_CFGR_PPRE1_DIV4;
  •         RCC->CFGR |= RCC_CFGR_PPRE2_DIV2;
  •         RCC->PLLCFGR |= (PLL_M_SETTING << 0) | (PLL_N_SETTING << 6) | (PLL_P_SETTING << 16) | (RCC_PLLCFGR_PLLSRC_HSE);
  •         RCC->CR |= RCC_CR_PLLON;
  •         while(!(RCC->CR & RCC_CR_PLLRDY));
  •         RCC->CFGR |= RCC_CFGR_SW_PLL;
  •         while ((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_PLL);
  •         SystemCoreClockUpdate();
  • // 1. Enable Timer clock
  •         RCC->APB1ENR |= (1<<4);  // Enable the timer6 clock
  • // 2. Set the prescalar and the ARR
  •         TIM6->PSC = 60-1;  //   1 MHz ~~ 1 uS delay
  •         TIM6->ARR = 0xffff;  // MAX ARR value
  • // 3. Enable the Timer, and wait for the update Flag to set
  •         TIM6->CR1 |= (1<<0); // Enable the Counter
  •         while (!(TIM6->SR & (1<<0)));
  •         TIM6->CNT = 0;
  •         while (TIM6->CNT < us);
  •         for (uint16_t i=0; i        {
  •                 Delay_us (1000); // delay of 1 ms
回帖(1)
崔丹
2022-12-20 10:02:11
如有疑问,请读出相关寄存器的内容并观察。
RCC->PLLCFGR 的默认值不为零,因此在这个 OR 之后它包含的内容与您假设的不同。
还要确保在切换系统时钟源之前更改 FLASH 延迟。
举报
更多回帖
