RK3328 Android
请问怎样在RK3328 Android10上对es7243进行调试呢?有哪些调试步骤?
回帖(1)
2022-3-9 14:34:55
一、es7243电路图。
二、修改的部分,解决没有mclk的问题。
commit b86b0275bf898fcc61abd48c776186e901bceac7
Author: xxx @192.168.2.82:xxx/xxx.git>
Date: Mon Jun 7 10:02:10 2021 +0800
es7243 recording function is ok now .
diff --git a/kernel/arch/arm64/boot/dts/rockchip/rk3328.dtsi b/kernel/arch/arm64/boot/dts/rockchip/rk3328.dtsi
index db9df63..5d9cb89 100755
--- a/kernel/arch/arm64/boot/dts/rockchip/rk3328.dtsi
+++ b/kernel/arch/arm64/boot/dts/rockchip/rk3328.dtsi
@@ -242,8 +242,8 @@
compatible = "rockchip,rk3328-i2s", "rockchip,rk3066-i2s";
reg = <0x0 0xff010000 0x0 0x1000>;
interrupts = ;
- clocks = <&cru SCLK_I2S1>, <&cru HCLK_I2S1_8CH>;
- clock-names = "i2s_clk", "i2s_hclk";
+ clocks = <&cru SCLK_I2S1>, <&cru HCLK_I2S1_8CH>,<&cru SCLK_I2S1_OUT>;
+ clock-names = "i2s_clk", "i2s_hclk","i2s_mclk";
dmas = <&dmac 14>, <&dmac 15>;
dma-names = "tx", "rx";
resets = <&cru SRST_I2S1>, <&cru SRST_I2S1_H>;
@@ -1080,8 +1080,8 @@
compatible = "rockchip,rk3328-codec";
reg = <0x0 0xff410000 0x0 0x1000>;
rockchip,grf = <&grf>;
- clocks = <&cru PCLK_ACODEC>, <&cru SCLK_I2S1>;
- clock-names = "pclk", "mclk";
+ clocks = <&cru PCLK_ACODEC>, <&cru SCLK_I2S1>, <&cru SCLK_I2S1_OUT>;
+ clock-names = "pclk", "mclk","i2s1_mclk";
status = "disabled";
diff --git a/kernel/sound/soc/codecs/rk3328_codec.c b/kernel/sound/soc/codecs/rk3328_codec.c
old mode 100644
new mode 100755
index 5a4184a..6c5cbde
--- a/kernel/sound/soc/codecs/rk3328_codec.c
+++ b/kernel/sound/soc/codecs/rk3328_codec.c
@@ -42,6 +42,9 @@
#define RK3328_GRF_SOC_CON10 (0x0428)
#define INITIAL_FREQ (11289600)
+extern int es7243_standby(void);
+extern int es7243_start(void);
struct rk3328_codec_priv {
struct regmap *regmap;
struct regmap *grf;
@@ -50,6 +53,7 @@ struct rk3328_codec_priv {
unsigned int sclk;
int spk_depop_time; /* msec */
+struct clk *i2s1_mclk;
static const struct reg_default rk3328_codec_reg_defaults[] = {
{ CODEC_RESET, 0x03 },
@@ -322,13 +326,29 @@ static int rk3328_hw_params(struct snd_pcm_substream *substream,
static int rk3328_pcm_startup(struct snd_pcm_substream *substream,
struct snd_soc_dai *dai)
- return rk3328_codec_open_playback(dai->component);
+ printk("rn rk3328_pcm_startup substream->stream=%d rn",substream->stream);
+ if(substream->stream == SNDRV_PCM_STREAM_PLAYBACK)
+ return rk3328_codec_open_playback(dai->component);
+ else {
+ printk("%s--es7243_start---n",__func__);
+ clk_prepare_enable(i2s1_mclk);
+ clk_set_rate(i2s1_mclk, INITIAL_FREQ);
+ es7243_start();
+ return 0;
static void rk3328_pcm_shutdown(struct snd_pcm_substream *substream,
- rk3328_codec_close_playback(dai->component);
+ printk("rn rk3328_pcm_shutdown substream->stream=%d rn",substream->stream);
+ rk3328_codec_close_playback(dai->component);
+ else {
+ printk("%s--es7243_standbyn",__func__);
+ es7243_standby();
+ clk_disable_unprepare(i2s1_mclk);
static const struct snd_soc_dai_ops rk3328_dai_ops = {
@@ -473,9 +493,11 @@ static int rk3328_platform_probe(struct platform_device *pdev)
rk3328_analog_output(rk3328, 0);
rk3328->mclk = devm_clk_get(&pdev->dev, "mclk");
+ i2s1_mclk = devm_clk_get(&pdev->dev, "i2s1_mclk");
if (IS_ERR(rk3328->mclk))
return PTR_ERR(rk3328->mclk);
ret = clk_prepare_enable(rk3328->mclk);
if (ret)
return ret;
三、测试命令 tinycap /sdcard/rec0.wav -D 0 -d 0 –c 2 –r 44100 –b 16 –p 1024 –n 3
四、es7243驱动在附件,下载地址
一、es7243电路图。
@@ -242,8 +242,8 @@
interrupts = ;
old mode 100644
new mode 100755
@@ -42,6 +42,9 @@
struct regmap *grf;
unsigned int sclk;
+ else {
+ es7243_start();
+ return 0;
+ else {
+ es7243_standby();
if (ret)
return ret;
四、es7243驱动在附件,下载地址
举报
