嗨,AD1CHS寄存器有4个不同的字段,这些字段可以相互独立地设置。其他寄存器中有一些控件,用于确定来自MUXA或MUXB的信号是否被测量,或者测量值是否在MUXA和MUXB之间交替:参见:AD1CON2.ALTS=0;总是使用选择的信道输入对于MUX A,在这种情况下,在AD1CHS.CH0SB中设置并不重要。AD1CHS.CH0SB=17并不意味着“没有输入”,而是来自另一个外围设备的输入,而不是模拟输入引脚。无论如何,如果MUXB的信号没有测量,这无关紧要。而且,AD1CHS寄存器中的设置不影响模拟或数字输入引脚缓冲器的性能,这由ANSA、ANSB和ANSC寄存器控制。
以上来自于百度翻译
以下为原文
Hi,
The AD1CHS register have 4 different fields that may be set independently of each other.
There are controls in other registers that determine whether signal from MUXA or MUXB are measured, or if measurements alternate between MUXA and MUXB:
See: AD1CON2.ALTS = 0; Always uses channel input selected for MUX A.
When this is the case, setting in AD1CHS.CH0SB do not matter.
AD1CHS.CH0SB = 17 do not mean 'No input', it is an input from another peripheral that is not an analog input pin. This do not matter if the signal from MUXB is not measured anyway.
Also, settings in AD1CHS register do not influence the properties of analog or digital input pin buffers, this is controlled by ANSA, ANSB and ANSC registers.
Regards,
Mysil
以上来自于百度翻译
以下为原文
Hi,
Regards,
Mysil
举报
