Microchip
直播中
孙缅禧
7年用户 255经验值
私信 关注
[问答]
如何在比较模式下对***定时器进行选择?
PIC16(L)F18324/1834428.3比较模式本节中描述的比较模式功能可用于所有CCP模块,并且是相同的。比较模式使用16位timer0或16位Timer1/3/5资源。将CCPRxH:CCPRxL寄存器对的16位值与TMR1/3/5H:TMR1/3/5L寄存器对的16位值进行比较。当匹配发生时,会发生以下事件之一:·切换CCPx输出从数据表的上述部分中声明我可以在比较模式下使用16位定时器0资源。从数据表中看不出如何选择除定时器1之外的其他定时器。对如何选择16位Time0进行说明。与Timer 1相比,它提供了广泛的预缩放和后缩放选项,这对我来说更有用。
以上来自于百度翻译
      以下为原文
28.3 Compare Mode
The Compare mode function described in this section
is available and identical for all CCP modules.
Compare mode makes use of either the 16-bit Timer0
or the 16-bit Timer1/3/5 resource. The 16-bit value of
the CCPRxH:CCPRxL register pair is constantly
compared against the 16-bit value of the
TMR1/3/5H:TMR1/3/5L register pair. When a match
occurs, one of the following events can occur:
• Toggle the CCPx output
From the above section of the datasheet it states that I could use 16 Bit Timer 0 resource in compare mode.
It is not apparent from the datasheet how to select a different timer other than Timer 1.
Can someone please shed some light on how I can select  16 Bit Timer0 for this purpose. It would be more useful for me with it's wide range of pre-scale and post scale options when compared to Timer 1.
Thanks
Alan
回帖(1)
何圆
2019-6-28 09:21:25
汤姆,谢谢你。
以上来自于百度翻译
      以下为原文
    Tom,
Thanks man.
BR
Alan
举报
更多回帖
