实际上DCM旨在消除IBUFG延迟,以便CLKFB引脚匹配
焊盘输入(1)的定时而不是CLK0输入(2)。
BUFG延迟实际上是相当的
比IBUFG延迟大一点,但它在反馈回路中被删除。
在
Spartan 6我认为有些选项会影响基于DCM的绝对延迟
是否要删除输入延迟(我相信时钟向导指的是
这是“系统同步”,意味着来自DCM的时钟与“系统”相匹配
输入板上的时钟)。
所以我很确定绘图是准确的。
- Gabor
- Gabor
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Actually the DCM is designed to remove the IBUFG delay so that the CLKFB pin matches the
timing of the pad input (1) rather than the CLK0 input (2). The BUFG delay is actually quite a
bit larger than the IBUFG delay, but it is removed by virue of being in the feedback loop. In
Spartan 6 I believe there are options that affect the absolute delay through the DCM based
on whether or not you want to remove the input delay (I believe the clocking wizard refers to
this as "system synchronous" meaning that the clock from the DCM matches the "system"
clock at the input pad).
So I'm pretty sure that the drawing is accurate.
-- Gabor
-- GaborView solution in original post
BUFG延迟实际上是相当的
在
输入板上的时钟)。
所以我很确定绘图是准确的。
- Gabor
- Gabor
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
-- Gabor
举报
