ST意法半导体
直播中
武妹
7年用户 169经验值
私信 关注
[问答]
LSM9Ds1如何自检
我怎么知道自我测试,每个人启用自检后的程序是什么,以及我必须使用哪种数据进行进一步分析,以及如何进行自我测试。
#自我测试
以上来自于谷歌翻译
以下为原文
How may i know about self-test, what is the procedure after enable self-test for each one, and what kind of data will there that i have to use for further analysis, and how.
#self-test
回帖(3)
刘珊珊
2019-5-23 14:16:08
你好
不应该是ST_DATA FIRST,减去NOST_DATA吗?
以上来自于谷歌翻译
以下为原文
Hi
Shouldnt it be the ST_DATA FIRST , minus the NOST_DATA??
举报
彭瑾
2019-5-23 14:29:15
Zalesky.Arie
,,我也想知道它是'NOST_DATA - ST_DATA'还是'ST_DATA - NOST_DATA'。我在一个似乎没问题的传感器上测试了这个程序,并且'MAG_NOST_DATA - MAG_ST_DATA'的结果对于每个轴都是正的(即,如果我测试的传感器正在工作,则与所提到的公式相矛盾).Best,
大卫
 注意:原始帖子包含大量线程对话,只能迁移到第9级
以上来自于谷歌翻译
以下为原文
As
Zalesky.Arie
‌, I am also wondering if it is 'NOST_DATA - ST_DATA' or 'ST_DATA - NOST_DATA'. I tested the procedure on a sensor that seems ok, and the results for 'MAG_NOST_DATA - MAG_ST_DATA' are positive for each axis (i.e. in contradiction to the mentioned formula if the sensor I tested is working).Best,
David
Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level
举报
周芳卿
2019-5-23 14:36:15
大家好,
对于LSM9DS1磁力仪自测,你最好使用
http://www.st.com/content/ccc/resource/technical/document/application_note/69/d7/05/fe/a9/3e/4b/ea/DM00136626.pdf/files/DM00136626.pdf/jcr:内容/翻译/ en.DM00136626.pdf
 包括限制,因为LSM9DS1包含LIS3MDL磁力计。
问候,
切赫
以上来自于谷歌翻译
以下为原文
Hello all,
for LSM9DS1 magnetometer selftest you better use
http://www.st.com/content/ccc/resource/technical/document/application_note/69/d7/05/fe/a9/3e/4b/ea/DM00136626.pdf/files/DM00136626.pdf/jcr:content/translations/en.DM00136626.pdf
including the limits since LSM9DS1 contains LIS3MDL magnetometer.
Regards,
Petr
举报
更多回帖
