是德科技
直播中
陈迎研
8年用户 102经验值
私信 关注
[问答]
在34932A上读取多个通道的最佳方法是什么?
设置DMM以读取一组34932A矩阵通道的最佳方法是什么?ROUT:CLOSE似乎一次只设置一个开关对。
我们必须在组中的每个开关对之后进行DMM读取,还是有办法像mux模块那样扫描一组通道?
以上来自于谷歌翻译
     以下为原文
  What's the best way to setup the DMM to read a group of 34932A matrix channels?
The ROUT:CLOSE appears to only set one switch pair at a time.  Must we do a DMM read after each switch pair in the group, or is there a way to scan a set of channels like we can with the mux modules?
回帖(2)
郝汉
2019-5-16 14:43:31
ROUT:CLOSE(@)命令采用频道列表,因此您可以同时关闭多个频道。
但是,您无法使用矩阵卡扫描通道。
但是,您可以定义ROUT:CLOS(@ch_list>),MEAS ...,ROUT ... MEAS序列,并根据需要重复使用。
见ROUT:SEQ:DEFine。
这样,您就可以有效地扫描您正在使用的矩阵卡通道的组合。
这是唯一有意义的方法,因为有很多可能的矩阵通道组合。
以上来自于谷歌翻译
     以下为原文
  The ROUT:CLOSE (@) command takes a channel list so you can close multiple channels at the same time.   However you can't scan channels with a matrix card.   However you can define a ROUT:CLOS (@ch_list>), MEAS...,ROUT...MEAS sequence and resuse that as often as you want.   See ROUT:SEQ:DEFine.  This way you can effectively scan the combinations of matrix card channels that you are using.  That is the only way that makes sense since there are so many possible combinations of matrix channels.
举报
陈迎研
2019-5-16 15:00:49
你能把PEAS放在序列字符串中吗?
以上来自于谷歌翻译
     以下为原文
  Can you put MEAS in a seqence string?
举报
更多回帖
