VSA软件中不再支持E4440A + VXI硬件配置作为测量硬件配置。
没有方法可以添加此配置。
可以手动将E4440A配置为外部下变频器。
虽然VSA无法在此配置中控制E4440A,但您可以将VSA配置为根据外部下变频器显示正确的信息。
http://wireless.agilent.com/wireless/helpfiles/89600B/WebHelp/89600_CSH.htm#../Subsystems/gui/content/dlg_input_usercorrection_frequencyconverter.htm
以上来自于谷歌翻译
以下为原文
The E4440A + VXI hardware configuration is no longer supported as a measurement hardware configuration in the VSA software. There is no method to add this configuration. It is possible to manually configure the E4440A as an external downconverter. While the VSA will not control the E4440A in this configuration you can configure the VSA to display the correct information based on the external downconverter. http://wireless.agilent.com/wireless/helpfiles/89600B/WebHelp/89600_CSH.htm#../Subsystems/gui/content/dlg_input_usercorrection_frequencyconverter.htm
没有方法可以添加此配置。
以上来自于谷歌翻译
以下为原文
举报
