ST意法半导体
直播中
孙云云
8年用户 135经验值
私信 关注
[问答]
L6470超频?
你好
我们想要对L6470(10MHz而不是OSCIN的8MHz)进行超频以增加最大RPM。决议将会减少,这是明确的,但是还有其他风险吗?
问候
迈克尔
以上来自于谷歌翻译
以下为原文
Hi
We want to overclock the L6470 (10MHz instead of 8MHz at OSCIN) to increase maximum RPM. The resolution will be reduced, this is clear, but is there any other risk to do so?
Regards
Michael
回帖(1)
刘璐
2019-4-25 15:48:05
亲爱的迈克尔,
L6470H使用系统时钟产生许多时序,其中一些时钟与器件安全操作密切相关。
该设备设计坚固耐用,可以容忍标称值的小变化,但25%的变化超出限制。
亲切的问候
恩里科
以上来自于谷歌翻译
以下为原文
Dear Michael,
The system clock is used by the L6470H to generates many timings and some of them are critically related to the device safe operation.
The device is designed to be robust and small variations from nominal value are tolerated, but a variation of 25% exceeds the limit.
Kind Regards
Enrico
举报
更多回帖
