检查这个相关的ARshttps://www.xilinx.com/support/answers/53486.html
谢谢和RegardsBalkrishan -----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
check this related ARs
Thanks and Regards
Balkrishan
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
以上来自于谷歌翻译
以下为原文
Thanks and Regards
Balkrishan
举报
