赛灵思
直播中
李红霞
8年用户 155经验值
私信 关注
[问答]
使用ZYBO板在VIVADO中使用AXI4 BFM仿真接口创建外设IP时收到错误消息
问候,
因此,我在创建IP外设并在VIVADO中使用ZYBO板单击“使用AXI4 BFM仿真接口验证外设IP”选项时收到此错误消息。
我只想看到AXI接口的模拟我甚至没有它的逻辑,我创建了一个虚拟项目,并直接进入“工具”中的“创建和包IP”选项。
这个错误就是这个......
[BD 41-541]无法在锁定块上设置参数。
块'master_0'被锁定,因为:* IP'myip_v1_0_bfm_1_master_0_0'需要一个或多个强制许可,但未找到有效许可。
但是,许可检查点可能会阻止在某些工具流中使用此IP。请从“工具/报告”菜单中选择“报告IP状态”,或运行Tcl命令“report_ip_status”以获取更多信息。
[BD 41-245] set_property error  - 无法在锁定块上设置参数。
我正在使用的Vivado版本是v2015.2(64位)
提前感谢您提供给我的任何帮助。
以上来自于谷歌翻译
以下为原文
Greetings,
So, I'm receiving this error message when creating an IP peripheral and clicking in the option "verify peripheral IP using AXI4 BFM Simulation Interface" in VIVADO using a ZYBO board. I only wanted to see the simulation for the AXI interface I dont even have a logic for it, I created a dummy project and went straight to the "Create and Package IP" option in "Tools". The error is this one...
[BD 41-541] Parameter cannot be set on a locked block. The block 'master_0' is locked, because : * IP 'myip_v1_0_bfm_1_master_0_0' requires one or more mandatory licenses but no valid licenses were found. However license checkpoints may prevent use of this IP in some tool flows.
Please select 'Report IP Status' from the 'Tools/Report' menu or run Tcl command 'report_ip_status' for more information.
[BD 41-245] set_property error - Parameter cannot be set on a locked block. The block 'master_0' is locked, because: * IP 'myip_v1_0_bfm_1_master_0_0' requires one or more mandatory licenses but no valid licenses were found. However license checkpoints may prevent use of this IP in some tool flows.
The Vivado version I'm using is v2015.2 (64-bit)
Thank you in advance for any help yo guys could provide for me.
回帖(1)
王晋
2019-4-12 15:29:16
嗨,
我建议通过编辑和打包来创建自定义IP。
稍后将自定义IP添加到IP目录时,将其连接到AXI BFM作为peripehral。
AXI 4 BFM IP核需要许可证。
这将有助于您模拟与AXI 4互连相对应的IP。
请注意,您可能需要相应地调整测试平台。
您是否尝试使用Zynq BFM IP核?
它可能有所帮助。
问候
普利文
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
-----------------------不要忘记回答,kudo,并接受为解决方案.-------------
以上来自于谷歌翻译
以下为原文
Hi,
I would suggest to create the custom IP by editing and packaging it. Later when the custom IP is added to IP catalog connect it to AXI BFM as peripehral. AXI 4 BFM IP core needs license for sure.
This will help you simulate the IP alognwith AXI 4 interconnect.
Note that you may have to tweak testbench accordingly.
Did you try using Zynq BFM IP core instead? It may help.
Regards
Praveen
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
Don’t forget to reply, kudo, and accept as solution.
举报
更多回帖
