您好,我正在尝试弄清楚如何使用E8363B进行S22测量。
我的被测设备是100欧姆双轴,但我的网络分析仪是50欧姆。
我的测试设置是一个50欧姆到100欧姆变压器的SMA插孔。
连接到变压器的电缆连接到被测设备。
有人打开三轴,加载和缩短我用于校准。
目前正在进行1.校准到ECAL的SMA插孔,50欧姆2.打开校正3.打开端口Z转换为100欧姆。
4.启用夹具选择。
5.使用开路或短路执行端口扩展。
6.连接到被测设备。
根据操作的顺序,我可以得到截然不同的答案。
我不确定什么是正确的。
我引用了这个帖子。
关于Impedanze Zin和S11关系的探讨
以上来自于谷歌翻译
以下为原文
Hello,
I am trying to figure out how to make a S22 measurement with a E8363B.
My device under test is 100 ohm twinax, but my network analyzer is 50 ohm.
My test setup is an SMA jack to a 50 ohm to 100 ohm transformer. The cable attached to the transformer goes to the device under test.
Someone made a triax open, load and short for me to use for calibra
tion.
Currently doing
1. Calibrate at the SMA jack to the ECAL, 50 ohms
2. Turn on Corrections
3. Turn on port Z converstion to 100 ohm.
4. Enable Fixture Selections.
5. Perform Port Extension with either open or short.
6. Connect to the device under test.
Depending on the order of operation I can get vastly different answers. I'm not sure what is the right one.
I have referenced this thread.
Enquiry on Impedanze Zin and S11 relationship
