一种解决方案是将您的IP(自定义逻辑)作为AXI主机,可以在总线上启动AXI读取。
因此,它可以访问与Microblaze相同的地址空间。
在这种情况下,BRAM起始地址将为0x00010000。
要了解如何创建自定义AXI母版,您可以参考以下AR:http://www.xilinx.com/support/answers/37425.htm
以上来自于谷歌翻译
以下为原文
One solution is to make your IP (custom logic) as an AXI master which can initiate AXI reads on the bus. Thus, it can access the same address space as Microblaze does. In that case the BRAM starting address will be 0x00010000.
To learn how to create the custom AXI master, you can refer to the following AR:
以上来自于谷歌翻译
以下为原文
举报
