赛灵思
直播中
刘婷婷
8年用户 219经验值
私信 关注
[问答]
Micro u***或JTAG用于编程FPGA
如果我们使用u*** circiut或只是一个简单的JTAG连接来编程自己设计的电路板,包含Virtex 6 FPGA和连接到FPGA的BPI存储器,我们想要分配。
有人有推荐吗?
无论如何是ML605板的CPLD Coolrunner 2(用于并行到串行转换)和USB控制器CY7C68013A的程序可用于重用设计?
以上来自于谷歌翻译
以下为原文
Hello we want to devide if we use the u*** circiut or just a simple JTAG connection to program an own designed board containing an Virtex 6 FPGA and a BPI memory connected to the FPGA.
Anyone got a recommendation?
Anyway is the program of the CPLD Coolrunner 2 (for parallel to serial conversion) of the ML605 board and the USB controller CY7C68013A available to reuse the design?
回帖(4)
李森
2019-2-20 10:36:14
如原理图所示,不允许实现ML605上的USB-JTAG电路。
如果您必须包含USB-JTAG电路,请购买Digilent JTAG-SMT1模块,该模块完全支持Xilinx软件,并且最终是一种更便宜,更容易实施的解决方案。
注意:我强烈建议您不要在电路板上实现USB-JTAG电路,因为单位成本可能不适合添加,如果您希望客户使用它,那么他们将不得不下载并安装1+
GB软件套件。
------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。太多结果?
尝试添加网站:www.xilinx.com
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Implementing the USB-JTAG circuit that is on the ML605 is not allowed as noted on the schematics.  If you must include a USB-JTAG circuit then please purchase the Digilent JTAG-SMT1 module which is fully support in the Xilinx software and is ultimately a cheaper and easier solution to implement.
Note: I would strongly encourage you to not implement a USB-JTAG circuit on your boards as the per-unit cost likely does not justify the addition and if you want your customers to use it then they will have to download and install a 1+GB software suite.
------Have you tried typing your question into Google?  If not you should before posting.
Too many results?  Try adding site:www.xilinx.comView solution in original post
举报
刘瑞
2019-2-20 10:49:40
是否需要在没有JTAG编程电缆的用户的现场重新编程?
如果是这样,USB将比发布Platform Cable USB编程器更便宜,更容易。
如果只需要在制造期间进行编程,那么仅提供JTAG头并且没有USB电路会便宜得多。
不确定ML605的设计,但如果您使用基于FX2LP的USB控制器进行JTAG和双向数据传输,您可以考虑使用FPGALink。
以上来自于谷歌翻译
以下为原文
Does it need to be reprogrammed in the field by users who don't have a JTAG programming cable? If so, USB will be cheaper and easier than giving out Platform Cable USB programmers.
If programming only needs to be done during manufacture, it would be far cheaper to just provide a JTAG header and no USB circuitry.
Not sure about the ML605 design but if you're after a USB controller based on the FX2LP for JTAG and bidirectional data transmission, you could consider FPGALink.
举报
鄢蓉
2019-2-20 10:57:20
是。
但我仍在搜索xilinx cpld的位文件。
将是符合条件的。
顺便问一下,有谁知道如何在ml605板上访问?
以上来自于谷歌翻译
以下为原文
Yes. But i still search for the bitfile of the xilinx cpld. Would be mich conformtable.
By the Way does anyone know how ist could be accessed on the ml605 Board ?
举报
李森
2019-2-20 11:11:37
GB软件套件。
如果没有,你应该在发布之前。太多结果?
以上来自于谷歌翻译
以下为原文
举报
更多回帖
